[petsc-users] Using edge-weights for partitioning
Fande Kong fdkong.jd at gmail.com
Sun Aug 30 17:44:15 CDT 2020
I agreed, Barry.
A year ago, I enabled edge-weights and vertex weights for only ParMETIS and
PTScotch. I did not do the same thing for Chaco, Party, etc.
It is straightforward to do that, and I could add an MR if needed.
Fande,
On Sun, Aug 30, 2020 at 4:20 PM Barry Smith <bsmith at petsc.dev> wrote:
> On Aug 30, 2020, at 7:33 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> So, if ParMETIS gives different edge cut as it is expected,
>> MatPartitioningGetUseEdgeWeights and MatPartitioningSetUseEdgeWeights works
>> correctly. Why can't CHACO?
> Chaco does not support using edge weights.
>   The package interfaces  that do not support edge weights should error if
> one requests partitioning with edge weights. Not everyone is born with the
> innate knowledge that the Chaco PETSc interface doesn't support edge
> weights.
> https://gitlab.com/petsc/petsc/-/merge_requests/3119
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200830/2976a67a/attachment-0001.html>
