[petsc-users] Error building petsc4py using intel compilers and mpi
Thu Aug 27 13:55:36 CDT 2020
On Thu, Aug 27, 2020 at 2:50 PM Blaise A Bourdin <bourdin at lsu.edu> wrote:
> Hi,
> I am trying to build firedrake using intel compilers, mpi, and python. I
> compiled petsc using the following options, and petsc4py is installed by
> firedrake-install (see the compilation options below)
> ./configure     --with-mpi-dir=$MPI_HOME     --CFLAGS='-std=c11
> -D_GNU_SOURCE'     --CXXFLAGS=''     --FFLAGS=''     --COPTFLAGS='-O3
> -xCASCADELAKE -g'     --FOPTFLAGS='-O3 -xCASCADELAKE -g'
> --CXXOPTFLAGS='-O3 -xCASCADELAKE -g'     --with-c++-support
> --with-c-support --with-fortran     --with-fortran-bindings=0
> --with-cxx-dialect=C++11     --download-ptscotch     --download-hdf5=
> https://support.hdfgroup.org/ftp/HDF5/releases/hdf5-1.10/hdf5-1.10.4/src/hdf5-1.10.4.tar.bz2
>     --download-hypre     --download-superlu_dist     --download-metis
> --download-parmetis     --download-scalapack     --download-mumps
>  --download-chaco     --download-ml     --download-eigen=
> https://github.com/eigenteam/eigen-git-mirror/archive/3.3.3.tar.gz
> --download-sowing=0
> Here is what I get when trying to import petsc4py:
> (firedrake) mef90:firedrake$ python3
> Python 3.7.7 (default, Jun 26 2020, 05:10:03)
> [GCC 7.3.0] :: Intel(R) Corporation on linux
> Type "help", "copyright", "credits" or "license" for more information.
> Intel(R) Distribution for Python is brought to you by Intel Corporation.
> Please check out: https://software.intel.com/en-us/python-distribution
> >>> import petsc4py
> >>> petsc4py.init()
> Traceback (most recent call last):
>   File "<stdin>", line 1, in <module>
>   File
> "/home/blaise/Development/firedrake/lib/python3.7/site-packages/petsc4py/__init__.py",
> line 42, in init
>     PETSc = petsc4py.lib.ImportPETSc(arch)
>   File
> "/home/blaise/Development/firedrake/lib/python3.7/site-packages/petsc4py/lib/__init__.py",
> line 29, in ImportPETSc
>     return Import('petsc4py', 'PETSc', path, arch)
>   File
> line 73, in Import
>     module = import_module(pkg, name, path, arch)
>   File
> line 58, in import_module
>     with f: return imp.load_module(fullname, f, fn, info)
>   File "/share/apps/intel-2020.2/intelpython3/lib/python3.7/imp.py", line
> 242, in load_module
>     return load_dynamic(name, filename, file)
> 342, in load_dynamic
>     return _load(spec)
>   File "<frozen importlib._bootstrap>", line 696, in _load
>   File "<frozen importlib._bootstrap>", line 670, in _load_unlocked
>   File "<frozen importlib._bootstrap>", line 583, in module_from_spec
>   File "<frozen importlib._bootstrap_external>", line 1043, in
> create_module
>   File "<frozen importlib._bootstrap>", line 219, in
> _call_with_frames_removed
> ImportError:
> /home/blaise/Development/firedrake/lib/python3.7/site-packages/petsc4py/lib/RHEL7-intel2020.2-impi-firedrake/
> PETSc.cpython-37m-x86_64-linux-gnu.so: undefined symbol:
> PetscPartitionerInitializePackage
I have this symbol:
master $:/PETSc3/petsc/petsc-dev$ nm -o
arch-master-debug/lib/libpetsc.dylib | grep
arch-master-debug/lib/libpetsc.dylib: 0000000000e07f90 T
_PetscPartitionerInitializePackage
Can you run
  nm -o
PETSc.cpython-37m-x86_64-linux-gnu.so |
grep PetscPartitionerInitializePackage
     Matt
> The relevant part of the firedrake-install.log are below.
> 2020-08-27 12:48:23,861 INFO   Installing petsc4py/
> 2020-08-27 12:48:23,882 DEBUG  Running command
> '/home/blaise/Development/firedrake/bin/python -m pip install
> --no-binary mpi4py,randomgen,islpy --no-deps -vvv --ignore-installed
> petsc4py/'
> 2020-08-27 12:50:32,017 DEBUG  Using pip 20.2.2 from
> /home/blaise/Development/firedrake/lib/python3.7/site-packages/pip (python
> 3.7)
> Non-user install because user site-packages disabled
> Created temporary directory: /tmp/pip-ephem-wheel-cache-5540399x
> Created temporary directory: /tmp/pip-req-tracker-jo7ho6yz
> Initialized build tracking at /tmp/pip-req-tracker-jo7ho6yz
> Created build tracker: /tmp/pip-req-tracker-jo7ho6yz
> Entered build tracker: /tmp/pip-req-tracker-jo7ho6yz
> Created temporary directory: /tmp/pip-install-e3u5z76o
> Processing ./petsc4py
>   Created temporary directory: /tmp/pip-req-build-r3agmgty
>   Added file:///home/blaise/Development/firedrake/src/petsc4py to build
> tracker '/tmp/pip-req-tracker-jo7ho6yz'
>     Running setup.py (path:/tmp/pip-req-build-r3agmgty/setup.py) egg_info
> for package from file:///home/blaise/Development/firedrake/src/petsc4py
>     Created temporary directory: /tmp/pip-pip-egg-info-dctmtwx0
>     Running command python setup.py egg_info
>     running egg_info
>     creating /tmp/pip-pip-egg-info-dctmtwx0/petsc4py.egg-info
>     writing /tmp/pip-pip-egg-info-dctmtwx0/petsc4py.egg-info/PKG-INFO
>     writing dependency_links to
> /tmp/pip-pip-egg-info-dctmtwx0/petsc4py.egg-info/dependency_links.txt
>     writing requirements to
> /tmp/pip-pip-egg-info-dctmtwx0/petsc4py.egg-info/requires.txt
>     writing top-level names to
> /tmp/pip-pip-egg-info-dctmtwx0/petsc4py.egg-info/top_level.txt
>     writing manifest file
> '/tmp/pip-pip-egg-info-dctmtwx0/petsc4py.egg-info/SOURCES.txt'
>     reading manifest file
>     reading manifest template 'MANIFEST.in'
>   Source in /tmp/pip-req-build-r3agmgty has version 3.13.0, which
> satisfies requirement petsc4py==3.13.0 from
>   Removed petsc4py==3.13.0 from
> file:///home/blaise/Development/firedrake/src/petsc4py from build tracker
> Building wheels for collected packages: petsc4py
>   Created temporary directory: /tmp/pip-wheel-0o0xldo2
>   Building wheel for petsc4py (setup.py): started
>   Destination directory: /tmp/pip-wheel-0o0xldo2
>   Running command /home/blaise/Development/firedrake/bin/python -u -c
> 'import sys, setuptools, tokenize; sys.argv[0]
> = '"'"'/tmp/pip-req-build-r3agmgty/setup.py'"'"';
> __file__='"'"'/tmp/pip-req-build-r3agmgty/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"',
> open)(__file__);code=f.read().replace('"'"'\r\n'"'"',
> '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))'
> bdist_wheel -d /tmp/pip-wheel-0o0xldo2
>   running bdist_wheel
>   running build
>   running build_src
>   cythonizing 'petsc4py.PETSc.pyx' -> 'petsc4py.PETSc.c'
> /home/blaise/Development/firedrake/lib/python3.7/site-packages/Cython/Compiler/Main.py:369:
> FutureWarning: Cython directive 'language_level' not set, using 2 for now
> (Py2). This will change in a later release! File: include/petsc4py/PETSc.pxd
>     tree = Parsing.p_module(s, pxd, full_module_name)
>   cythonizing 'libpetsc4py/libpetsc4py.pyx' -> 'libpetsc4py/libpetsc4py.c'
> /tmp/pip-req-build-r3agmgty/src/libpetsc4py/libpetsc4py.pyx
>   running build_py
>   creating build
>   creating build/lib.linux-x86_64-3.7
>   creating build/lib.linux-x86_64-3.7/petsc4py
>   copying src/PETSc.py -> build/lib.linux-x86_64-3.7/petsc4py
>   copying src/__init__.py -> build/lib.linux-x86_64-3.7/petsc4py
>   copying src/__main__.py -> build/lib.linux-x86_64-3.7/petsc4py
>   creating build/lib.linux-x86_64-3.7/petsc4py/lib
>   copying src/lib/__init__.py -> build/lib.linux-x86_64-3.7/petsc4py/lib
>   creating build/lib.linux-x86_64-3.7/petsc4py/include
>   creating build/lib.linux-x86_64-3.7/petsc4py/include/petsc4py
>   copying src/include/petsc4py/numpy.h ->
>   copying src/include/petsc4py/petsc4py.h ->
>   copying src/include/petsc4py/petsc4py.PETSc.h ->
>   copying src/include/petsc4py/petsc4py.PETSc_api.h ->
>   copying src/include/petsc4py/petsc4py.i ->
>   copying src/include/petsc4py/PETSc.pxd ->
>   copying src/include/petsc4py/__init__.pxd ->
>   copying src/include/petsc4py/__init__.pyx ->
>   copying src/PETSc.pxd -> build/lib.linux-x86_64-3.7/petsc4py
>   copying src/lib/petsc.cfg -> build/lib.linux-x86_64-3.7/petsc4py/lib
>   running build_ext
>   PETSC_DIR:    /opt/HPC/petsc-maint
>   PETSC_ARCH:   RHEL7-intel2020.2-impi-firedrake
>   version:      3.13.4 release
>   integer-size: 32-bit
>   scalar-type:  real
>   precision:    double
>   language:     CONLY
>   compiler:
> /share/apps/intel-2020.2/compilers_and_libraries/linux/mpi/intel64/bin/mpiicc
>   linker:
>   building 'PETSc' extension
>   creating build/temp.linux-x86_64-3.7
>   creating build/temp.linux-x86_64-3.7/RHEL7-intel2020.2-impi-firedrake
>   creating build/temp.linux-x86_64-3.7/RHEL7-intel2020.2-impi-firedrake/src
> -pthread -B /share/apps/intel-2020.2/intelpython3/compiler_compat
> -Wl,--sysroot=/ -std=c11 -D_GNU_SOURCE -fPIC -O3 -xCASCADELAKE -g -fPIC
> -L/opt/HPC/petsc-maint/RHEL7-intel2020.2-impi-firedrake/lib
> -I/opt/HPC/petsc-maint/RHEL7-intel2020.2-impi-firedrake/include
> -I/share/apps/intel-2020.2/compilers_and_libraries/linux/mpi/intel64/include
> -I/opt/HPC/petsc-maint/RHEL7-intel2020.2-impi-firedrake/include/eigen3
> -I/opt/HPC/petsc-maint/include -Isrc/include
> -I/home/blaise/Development/firedrake/lib/python3.7/site-packages/numpy/core/include
> -I/home/blaise/Development/firedrake/include
> -I/share/apps/intel-2020.2/intelpython3/include/python3.7m -c src/PETSc.c
> -o build/temp.linux-x86_64-3.7/RHEL7-intel2020.2-impi-firedrake/src/PETSc.o
>   In file included from
> /home/blaise/Development/firedrake/lib/python3.7/site-packages/numpy/core/include/numpy/ndarrayobject.h(12),
>                    from
> /home/blaise/Development/firedrake/lib/python3.7/site-packages/numpy/core/include/numpy/arrayobject.h(4),
>                    from src/include/petsc4py/numpy.h(11),
>                    from src/petsc4py.PETSc.c(612),
>                    from src/PETSc.c(4):
> /home/blaise/Development/firedrake/lib/python3.7/site-packages/numpy/core/include/numpy/ndarraytypes.h(84):
> warning #2650: attributes ignored here
>                         NPY_CHAR NPY_ATTR_DEPRECATE("Use NPY_STRING"),
>   In file included from src/petsc4py.PETSc.c(619),
>   src/include/initpkg.h(23): warning #266: function
> "PetscPartitionerInitializePackage" declared implicitly
>       ierr = PetscPartitionerInitializePackage();CHKERRQ(ierr);
>   In file included from src/PETSc.c(4):
>   src/petsc4py.PETSc.c(294008): warning #266: function
> "PetscPartitionerReset" declared implicitly
>       __pyx_t_1 =
> __pyx_f_8petsc4py_5PETSc_CHKERR(PetscPartitionerReset(__pyx_v_self->part));
> if (unlikely(__pyx_t_1 == ((int)-1))) __PYX_ERR(54, 55, __pyx_L1_error)
> src/libpetsc4py.c
> -o build/temp.linux-x86_64-3.7/RHEL7-intel2020.2-impi-firedrake/src/libpetsc4py.o
>                    from
>                    from src/libpetsc4py/libpetsc4py.c(612),
>                    from src/libpetsc4py.c(6):
>   creating
> build/lib.linux-x86_64-3.7/petsc4py/lib/RHEL7-intel2020.2-impi-firedrake
> -Wl,--sysroot=/ -std=c11 -D_GNU_SOURCE -fPIC -O3 -xCASCADELAKE -g -shared
> -L/share/apps/intel-2020.2/intelpython3/lib
> -Wl,-rpath=/share/apps/intel-2020.2/intelpython3/lib -Wl,--no-as-needed
> -Wl,--sysroot=/
> -Wl,-rpath,/opt/HPC/petsc-maint/RHEL7-intel2020.2-impi-firedrake/lib
> -lpetsc -o
> build/lib.linux-x86_64-3.7/petsc4py/lib/RHEL7-intel2020.2-impi-firedrake/
>   writing build/lib.linux-x86_64-3.7/petsc4py/lib/petsc.cfg
>   installing to build/bdist.linux-x86_64/wheel
>   running install
>   running install_lib
>   creating build/bdist.linux-x86_64
>   creating build/bdist.linux-x86_64/wheel
>   creating build/bdist.linux-x86_64/wheel/petsc4py
>   copying build/lib.linux-x86_64-3.7/petsc4py/PETSc.py ->
>   copying build/lib.linux-x86_64-3.7/petsc4py/__init__.py ->
>   copying build/lib.linux-x86_64-3.7/petsc4py/__main__.py ->
>   creating build/bdist.linux-x86_64/wheel/petsc4py/lib
>   copying build/lib.linux-x86_64-3.7/petsc4py/lib/__init__.py ->
>   copying build/lib.linux-x86_64-3.7/petsc4py/lib/petsc.cfg ->
>   creating
> build/bdist.linux-x86_64/wheel/petsc4py/lib/RHEL7-intel2020.2-impi-firedrake
>   copying
> -> build/bdist.linux-x86_64/wheel/petsc4py/lib/RHEL7-intel2020.2-impi-firedrake
>   creating build/bdist.linux-x86_64/wheel/petsc4py/include
>   creating build/bdist.linux-x86_64/wheel/petsc4py/include/petsc4py
>   copying build/lib.linux-x86_64-3.7/petsc4py/include/petsc4py/numpy.h ->
>   copying build/lib.linux-x86_64-3.7/petsc4py/include/petsc4py/petsc4py.h
> -> build/bdist.linux-x86_64/wheel/petsc4py/include/petsc4py
>   copying
> build/lib.linux-x86_64-3.7/petsc4py/include/petsc4py/petsc4py.PETSc.h ->
>   copying
> build/lib.linux-x86_64-3.7/petsc4py/include/petsc4py/petsc4py.PETSc_api.h
>   copying build/lib.linux-x86_64-3.7/petsc4py/include/petsc4py/petsc4py.i
>   copying build/lib.linux-x86_64-3.7/petsc4py/include/petsc4py/PETSc.pxd
>   copying
> build/lib.linux-x86_64-3.7/petsc4py/include/petsc4py/__init__.pxd ->
>   copying
> build/lib.linux-x86_64-3.7/petsc4py/include/petsc4py/__init__.pyx ->
>   copying build/lib.linux-x86_64-3.7/petsc4py/PETSc.pxd ->
>   running install_egg_info
>   running egg_info
>   creating petsc4py.egg-info
>   writing petsc4py.egg-info/PKG-INFO
>   writing dependency_links to petsc4py.egg-info/dependency_links.txt
>   writing requirements to petsc4py.egg-info/requires.txt
>   writing top-level names to petsc4py.egg-info/top_level.txt
>   writing manifest file 'petsc4py.egg-info/SOURCES.txt'
>   reading manifest file 'petsc4py.egg-info/SOURCES.txt'
>   Copying petsc4py.egg-info to
> build/bdist.linux-x86_64/wheel/petsc4py-3.13.0-py3.7.egg-info
>   running install_scripts
>   adding license file "LICENSE.rst" (matched pattern "LICEN[CS]E*")
>   creating build/bdist.linux-x86_64/wheel/petsc4py-3.13.0.dist-info/WHEEL
>   creating
> '/tmp/pip-wheel-0o0xldo2/petsc4py-3.13.0-cp37-cp37m-linux_x86_64.whl' and
> adding 'build/bdist.linux-x86_64/wheel' to it
>   adding 'petsc4py/PETSc.pxd'
>   adding 'petsc4py/PETSc.py'
>   adding 'petsc4py/__init__.py'
>   adding 'petsc4py/__main__.py'
>   adding 'petsc4py/include/petsc4py/PETSc.pxd'
>   adding 'petsc4py/include/petsc4py/__init__.pxd'
>   adding 'petsc4py/include/petsc4py/__init__.pyx'
>   adding 'petsc4py/include/petsc4py/numpy.h'
>   adding 'petsc4py/include/petsc4py/petsc4py.PETSc.h'
>   adding 'petsc4py/include/petsc4py/petsc4py.PETSc_api.h'
>   adding 'petsc4py/include/petsc4py/petsc4py.h'
>   adding 'petsc4py/include/petsc4py/petsc4py.i'
>   adding 'petsc4py/lib/__init__.py'
>   adding 'petsc4py/lib/petsc.cfg'
>   adding 'petsc4py/lib/RHEL7-intel2020.2-impi-firedrake/
> PETSc.cpython-37m-x86_64-linux-gnu.so'
>   adding 'petsc4py-3.13.0.dist-info/LICENSE.rst'
>   adding 'petsc4py-3.13.0.dist-info/METADATA'
>   adding 'petsc4py-3.13.0.dist-info/WHEEL'
>   adding 'petsc4py-3.13.0.dist-info/top_level.txt'
>   adding 'petsc4py-3.13.0.dist-info/RECORD'
>   removing build/bdist.linux-x86_64/wheel
>   Building wheel for petsc4py (setup.py): finished with status 'done'
>   Created wheel for petsc4py:
> filename=petsc4py-3.13.0-cp37-cp37m-linux_x86_64.whl
> size=4287046 sha256=95604a089946004038f4268d38948c35a5372a2cedaa9df21e354d68231cb99a
>   Stored in directory:
> /tmp/pip-ephem-wheel-cache-5540399x/wheels/88/a6/a9/78aff17157d1fedc3a047afc3f1c84462e68ea89775758cd2e
> Successfully built petsc4py
> Installing collected packages: petsc4py
> Successfully installed petsc4py-3.13.0
> Removed build tracker: '/tmp/pip-req-tracker-jo7ho6yz'
> Any idea?
> Blaise
> A.K. & Shirley Barton Professor of  Mathematics
> Adjunct Professor of Mechanical Engineering
> Adjunct of the Center for Computation & Technology
> Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803,
> USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 Web
> http://www.math.lsu.edu/~bourdin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200827/0800065f/attachment-0001.html>
