[petsc-users] PetscFV and TS implicit
Thibault Bridel-Bertomeu
thibault.bridelbertomeu at gmail.com
Tue Aug 25 02:06:51 CDT 2020
Hello everyone,
Barry, I followed your recommendations and came up with the pieces of code
that are in the attached PDF - mostly pages 1 & 3 are important, page 2 is
almost entirely commented.
I tried to use DMCreateColoring as the doc says it may produce a more
accurate coloring, however it is not implemented for a Plex yet hence the
call to Matcoloringcreate that you will see. I left the test DMHascoloring
in case in a later release PETSc allows for the generation of the coloring
from a Plex.
Also, you'll see in the input file that contrary to what you suggested I am
using the jacobi PC. It is simply because it appears that the way I
compiled my PETSc does not support a PC LU or PC CHOLESKY (per the seg
fault print in the console). Do I need scalapack or mumps or something else
Altogether this implementation works and produces results that are correct
physically speaking. Now I have to try and increase the CFL number a lot to
see how robust this approach is.
All in all, what do you think of this implementation, is it what you had in
mind ?
Thank you for your help,
Thibault
Le lun. 24 août 2020 à 22:16, Barry Smith <bsmith at petsc.dev> a écrit :
> On Aug 24, 2020, at 2:20 PM, Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
> Good evening everyone,
> Thanks Barry for your answer.
> Le lun. 24 août 2020 à 18:51, Barry Smith <bsmith at petsc.dev> a écrit :
>> On Aug 24, 2020, at 11:38 AM, Thibault Bridel-Bertomeu <
>> Thank you Barry for taking the time to go through the code !
>> I indeed figured out this afternoon that the function related to the
>> matrix-vector product is always handling global vectors. I corrected mine
>> so that it compiles, but I have a feeling it won't run properly without a
>> preconditioner.
>> Anyways you are right, my PetscJacobianFunction_JFNK() aims at doing some
>> basic finite-differencing ; user->RHS_ref is my F(U) if you see the system
>> as dU/dt = F(U). As for the DMGlobalToLocal() it was there mainly because I
>> had not realized the vectors I was manipulating were global.
>> I will take your advice and try with just the SNESSetUseMatrixFree.
>> I haven't quite fully understood what it does "under the hood" though:
>> just calling SNESSetUseMatrixFree(snes,PETSC_TRUE,PETSC_FALSE) before the
>> TSSolve call is enough to ensure that the implicit matrix is computed ?
>> Does it use the function we set as a RHS to build the matrix ?
>> All it does is "replace" the A matrix with one automatically created
>> for the job using MatCreateMFFD(). It does not touch the B matrix, it does
>> not build the matrix but yes if does use the function to provide to do the
>> differencing.
> OK, thank you. This MFFD Matrix is then called by the TS to construct the
> linear system that will be solved to advance the system of equations, right
>> To create the preconditioner I will do as you suggest too, thank you.
>> This matrix has to be as close as possible to the inverse of the implicit
>> matrix to ensure that the eigenvalues of the system are as close to 1 as
>> possible. Given the implicit matrix is built "automatically" thanks to the
>> SNES matrix free capability, can we use that matrix as a starting point to
>> the building of the preconditioner ?
>> No the MatrixFree doesn't build a matrix, it can only do matrix-vector
>> products with differencing.
> My bad, wrong word. Yes of course it's all matrix-free hence it's just a
> functional, however maybe the inner mechanisms can be accessed and used for
> Probably not, it really only can do matrix-vector products.
> You were talking about the coloring capabilities in PETSc, is that where
>> it can be applied ?
>> Yes you can use that. See MatFDColoringCreate() but since you are
>> using a DM in theory you can use -snes_fd_color and PETSc will manage
>> everything for you so you don't have to write any code for Jacobians at
>> all. Again it uses your function to do differences using coloring to be
>> efficient to build the Jacobian for you.
> I read a bit about the coloring you are mentioning. As I understand it, it
> is another option to have a matrix-free Jacobian behavior during the
> Newton-Krylov iterations, right ? Either we use the SNESSetUseMatrixFree()
> alone, then it works using "basic" finite-differencing, or we use the
> SNESSetUseMatrixFree + MatFDColoringCreate
> & SNESComputeJacobianDefaultColor as an option to SNESSetJacobian to access
> the finite-differencing based on coloring. Is that right ?
> Then if i come back to my preconditioner problem ... once you have set-up
> the implicit matrix with one or the other aforementioned matrix-free ways,
> how would you go around setting up the preconditioner ? In a matrix-free
> way too, or rather as a real matrix that we assemble ourselves this time,
> as you seemed to mean with the previous MatAij DMCreateMatrix ?
> Sorry if it seems like I am nagging, but I would really like to understand
> how to manipulate the matrix-free methods and structures in PETSc to run a
> time-implicit finite volume computation, it's so promising !
> There are many many possibilities as we discussed in previous email,
> most with various limitations.
> When you use -snes_fd_color (or put code into the source like
> MatFDColoringCreate which is unnecessary a since you are doing the same
> thing as -snes_fd_color you get back the true Jacobian (approximated so in
> less digits than analytic) so you can use any preconditioner that you can
> use as if you built the true Jacobian yourself.
> I always recommend starting with -pc_type lu and making sure you are
> getting the correct answers to your problem and then worrying about the
> preconditioner. Faster preconditioner are JUST optimizations, nothing more,
> they should not change the quality of the solution to your PDE/ODE and you
> absolutely need to make sure your are getting correct quality answers
> before fiddling with the preconditioner.
> Once you have the solution correct and figured out a good preconditioner
> (assuming using the true Jacobian works for your discretization) then you
> can think about optimizing the computation of the Jacobian by doing it
> analytically finite volume by finite volume. But you shouldn't do any of
> that until you are sure that your implicit TS integrator for FV produces
> good numerical answers.
> Barry
> Thanks again,
> Thibault
>> Barry
>> Internally it uses SNESComputeJacobianDefaultColor() if you are
>> interested in what it does.
>> Thank you so much again,
>> Thibault
>> Le lun. 24 août 2020 à 15:45, Barry Smith <bsmith at petsc.dev> a écrit :
>>> I think the attached is wrong.
>>> <Untitled.png>
>>> The input to the matrix vector product for the Jacobian is always global
>>> vectors which means on each process the dimension is not the size of the
>>> DMGetLocalVector() it should be the VecGetLocalSize() of the
>>> DMGetGlobalVector()
>>> But you may be able to skip all this and have the DM create the shell
>>> matrix setting it sizes appropriately and you only need to supply the MATOP
>>> DMSetMatType(dm,MATSHELL);
>>> DMCreateMatrix(dm,&A);
>>> In fact, I also don't understand the PetscJacobianFunction_JFKN()
>>> function It seems to be doing finite differencing on the
>>> DMPlexTSComputeRHSFunctionFVM() assuming the current function value is in
>>> usr->RHS_ref. How is this different than just letting PETSc/SNES used
>>> finite differences to do the matrix-vector product. Your code seems rather
>>> complicated with the DMGlobalToLocal() which I don't understand what it is
>>> suppose to do there.
>>> I think you can just call
>>> TSGetSNES()
>>> SNESSetUseMatrixFree(snes,PETSC_TRUE,PETSC_FALSE);
>>> and it will set up an internal matrix that does the finite differencing
>>> for you. Then you never need a shell matrix.
>>> Also to create the preconditioner matrix B this should work
>>> DMSetMatType(dm,MATAIJ);
>>> DMCreateMatrix(dm,&B);
>>> no need for you to figure out the sizes.
>>> Note that both A and B need to have the same dimensions on each process
>>> as the global vectors which I don't think your current code has.
>>> Barry
>>> On Aug 24, 2020, at 12:56 AM, Thibault Bridel-Bertomeu <
>>> Barry, first of all, thank you very much for your detailed answer, I
>>> keep reading it to let it soak in - I might come back to you for more
>>> details if you do not mind.
>>> In the meantime, to fuel the conversation, I attach to this e-mail two
>>> pdfs containing the pieces of the code that regard what we are discussing.
>>> In the *timedisc.pdf, you'll find how I handle the initialization of the TS
>>> object, and in the *petscdefs.pdf you'll find the method that calls the
>>> TSSolve as well as the methods that are linked to the TS (the timestep
>>> adapt, the jacobian etc ...). [Sorry for the quality, I cannot do better
>>> than that sort of pdf ...]
>>> Based on what is in the structured code I sent you the other day, I
>>> rewrote the PetscJacobianFunction_JFNK. I think it should be all right, but
>>> although it compiles, execution raises a seg fault I think when I do
>>> ierr = TSSetIJacobian(ts, A, A, PetscIJacobian, user);
>>> saying that A does not have the right dimensions. It is quite new, I am
>>> still looking into where exactly the error is raised. What do you think of
>>> this implementation though, does it look correct in your expert eyes ?
>>> As for what we really discussed so far, it's that
>>> PetscComputePreconMatImpl that I do not know how to implement (with the
>>> derivative of the jacobian based on the FVM object).
>>> I understand now that what I am showing you today might not be the
>>> right way to go if one wants to really use the PetscFV, but I just wanted
>>> to add those code lines to the conversation to have your feedback.
>>> Thank you again for your help,
>>> Thibault
>>> Le ven. 21 août 2020 à 19:25, Barry Smith <bsmith at petsc.dev> a écrit :
>>>> On Aug 21, 2020, at 10:58 AM, Thibault Bridel-Bertomeu <
>>>> Thank you Barry for the tip ! I’ll make sure to do that when everything
>>>> is set.
>>>> What I also meant is that there will not be any more direct way to set
>>>> the preconditioner than to go through SNESSetJacobian after having
>>>> assembled everything by hand ? Like, in my case, or in the more general
>>>> case of fluid dynamics equations, the preconditioner is not a fun matrix to
>>>> assemble, because for every cell the derivative of the physical flux
>>>> jacobian has to be taken and put in the right block in the matrix - finite
>>>> element style if you want. Is there a way to do that with Petsc methods,
>>>> maybe short-circuiting the FEM based methods ?
>>>> Thibault
>>>> I am not sure what you mean but there are a couple of things that
>>>> may be helpful.
>>>> PCSHELL
>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCSHELL.html allows
>>>> you to build your own preconditioner (that can and often will use one or
>>>> more of its own Mats, and KSP or PC inside it, or even use another PETScFV
>>>> etc to build some of the sub matrices for you if it is appropriate), this
>>>> approach means you never need to construct a "global" PETSc matrix from
>>>> which PETSc builds the preconditioner. But you should only do this if the
>>>> conventional approach is not reasonable for your problem.
>>>> MATNEST
>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATNEST.html allows
>>>> you to build a global matrix by building parts of it separately and even
>>>> skipping parts you decide you don't need in the preconditioner.
>>>> Conceptually it is the same as just creating a global matrix and filling up
>>>> but the process is a bit different and something suitable for "multi
>>>> physics" or "multi-equation" type applications.
>>>> Of course what you put into PCSHELL and MATNEST will affect the
>>>> convergence of the nonlinear solver. As Jed noted what you put in the
>>>> "Jacobian" does not have to be directly the same mathematically as what you
>>>> put into the TSSetI/RHSFunction with the caveat that it does have to
>>>> appropriate spectral properties to result in a good preconditioner for the
>>>> "true" Jacobian.
>>>> Couple of other notes:
>>>> The entire business of "Jacobian" matrix-free or not (with for example
>>>> -snes_fd_operator) is tricky because as Jed noted if your finite volume
>>>> scheme has non-differential terms such as if () tests. There is a concept
>>>> of sub-differential for this type of thing but I know absolutely nothing
>>>> about that and probably not worth investigating.
>>>> In this situation you can avoid the "true" Jacobian completely (both
>>>> for matrix-vector product and preconditioner) and use something else as Jed
>>>> suggested a lower order scheme that is differentiable. This can work well
>>>> for solving the nonlinear system or not depending on how suitable it is for
>>>> your original "function"
>>>> 1) In theory at least you can have the Jacobian matrix-vector product
>>>> computed directly using DMPLEX/PETScFV infrastructure (it would apply the
>>>> Jacobian locally matrix-free using code similar to the code that evaluates
>>>> the FV "function". I do no know if any of this code is written, it will be
>>>> more efficient than -snes_mf_operator that evaluates the FV "function" and
>>>> does traditional differencing to compute the Jacobian. Again it has the
>>>> problem of non-differentialability if the function is not differential. But
>>>> it could be done for a different (lower order scheme) that is
>>>> differentiable.
>>>> 2) You can have PETSc compute the Jacobian explicitly coloring and
>>>> from that build the preconditioner, this allows you to avoid the hassle of
>>>> writing the code for the derivatives yourself. This uses finite differences
>>>> on your function and coloring of the graph to compute many columns of the
>>>> Jacobian simultaneously and can be pretty efficient. Again if the function
>>>> is not differential there can be issues of what the result means and will
>>>> it work in a nonlinear solver. SNESComputeJacobianDefaultColor
>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESComputeJacobianDefaultColor.html
>>>> 3) Much more outlandish is to skip Newton and Jacobians completely and
>>>> use the full approximation scheme SNESFAS
>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNESFAS/SNESFAS.html this
>>>> requires a grid hierarchy and appropriate way to interpolate up through the
>>>> grid hierarchy your finite volume solutions. Probably not worth
>>>> investigating unless you have lots of time on your hands and keen interest
>>>> in this kind of stuff https://arxiv.org/pdf/1607.04254.pdf
>>>> So to summarize, and Matt and Jed can correct my mistakes.
>>>> 1) Form the full Jacobian from the original "function" using analytic
>>>> approach use it for both the matrix-vector product and to build the
>>>> preconditioner. Problem if full Jacobian not well defined mathematically.
>>>> Tough to code, usually not practical.
>>>> 2) Do any matrix free (any way) for the full Jacobian and
>>>> a) build another "approximate" Jacobian (using any technique analytic
>>>> or finite differences using matrix coloring on a new "lower order"
>>>> "function") Still can have trouble if this original Jacobian is no well
>>>> defined
>>>> b) "write your own preconditioner" that internally can use anything
>>>> in PETSc that approximately solves the Jacobian. Same potential problems if
>>>> original Jacobian is not differential, plus convergence will depend on how
>>>> good your own preconditioner approximates the inverse of the true Jacobian.
>>>> 3) Use a lower Jacobian (computed anyway you want) for the
>>>> matrix-vector product and the preconditioner. The problem of
>>>> differentiability is gone but convergence of the nonlinear solver depends
>>>> on how well lower order Jacobian is appropriate for the original "function"
>>>> a) Form the "lower order" Jacobian analytically or with coloring
>>>> and use for both matrix-vector product and building preconditioner. Note
>>>> that switching between this and 2a is trivial.
>>>> b) Do the "lower order" Jacobian matrix free and provide your own
>>>> PCSHELL. Note that switching between this and 2b is trivial.
>>>> Barry
>>>> I would first try competing the "true" Jacobian via coloring, if that
>>>> works and give satisfactory results (fast enough) then stop.
>>>> Then I would do 2a/2b by writing my "function" using PETScFV and
>>>> writing the "lower order function" via PETScFV and use matrix coloring to
>>>> get the Jacobian from the second "lower order function". If this works well
>>>> (either with 2a or 3a or both) then stop or you can compute the "lower
>>>> order" Jacobian analytically (again using PetscFV) for a more efficient
>>>> evaluation of the Jacobian.
>>>> Thanks !
>>>> Thibault
>>>> Le ven. 21 août 2020 à 17:22, Barry Smith <bsmith at petsc.dev> a écrit :
>>>>> On Aug 21, 2020, at 8:35 AM, Thibault Bridel-Bertomeu <
>>>>> Le ven. 21 août 2020 à 15:23, Matthew Knepley <knepley at gmail.com> a
>>>>> écrit :
>>>>>> On Fri, Aug 21, 2020 at 9:10 AM Thibault Bridel-Bertomeu <
>>>>>>> Sorry, I sent too soon, I hit the wrong key.
>>>>>>> I wanted to say that context.npoints is the local number of cells.
>>>>>>> PetscRHSFunctionImpl allows to generate the hyperbolic part of the
>>>>>>> right hand side.
>>>>>>> Then we have :
>>>>>>> PetscErrorCode PetscIJacobian(
>>>>>>> TS ts, /*!< Time stepping object (see PETSc TS)*/
>>>>>>> PetscReal t, /*!< Current time */
>>>>>>> Vec Y, /*!< Solution vector */
>>>>>>> Vec Ydot, /*!< Time-derivative of solution vector */
>>>>>>> PetscReal a, /*!< Shift */
>>>>>>> Mat A, /*!< Jacobian matrix */
>>>>>>> Mat B, /*!< Preconditioning matrix */
>>>>>>> void *ctxt /*!< Application context */
>>>>>>> PETScContext *context = (PETScContext*) ctxt;
>>>>>>> HyPar *solver = context->solver;
>>>>>>> _DECLARE_IERR_;
>>>>>>> PetscFunctionBegin;
>>>>>>> solver->count_IJacobian++;
>>>>>>> context->shift = a;
>>>>>>> context->waqt = t;
>>>>>>> /* Construct preconditioning matrix */
>>>>>>> if (context->flag_use_precon) { IERR PetscComputePreconMatImpl(B,Y,
>>>>>>> context); CHECKERR(ierr); }
>>>>>>> PetscFunctionReturn(0);
>>>>>>> and PetscJacobianFunction_JFNK which I bind to the matrix shell,
>>>>>>> computes the action of the jacobian on a vector : say U0 is the state of
>>>>>>> reference and Y the vector upon which to apply the JFNK method, then the
>>>>>>> PetscJacobianFunction_JFNK returns shift * Y - 1/epsilon * (F(U0 +
>>>>>>> epsilon*Y) - F(U0)) where F allows to evaluate the hyperbolic flux (shift
>>>>>>> comes from the TS).
>>>>>>> The preconditioning matrix I compute as an approximation to the
>>>>>>> actual jacobian, that is shift * Identity - Derivative(dF/dU) where dF/dU
>>>>>>> is, in each cell, a 4x4 matrix that is known exactly for the system of
>>>>>>> equations I am solving, i.e. Euler equations. For the structured grid, I
>>>>>>> can loop on the cells and do that 'Derivative' thing at first order by
>>>>>>> simply taking a finite-difference like approximation with the neighboring
>>>>>>> cells, Derivative(phi) = phi_i - phi_{i-1} and I assemble the B matrix
>>>>>>> block by block (JFunction is the dF/dU)
>>>>>>> /* diagonal element */
>>>>>>> for (v=0; v<nvars; v++) { rows[v] = nvars*pg + v; cols[v] =
>>>>>>> nvars*pg + v; }
>>>>>>> ierr = solver->JFunction
>>>>>>> <http://hypar.github.io/a00144.html#a25c87c7c874c7e08981688fe6c51167b>
>>>>>>> (values,(u+nvars*p),solver->physics
>>>>>>> <http://hypar.github.io/a00144.html#a48e81a1806b5774943fd9a26e9a190f2>
>>>>>>> ,dir,0);
>>>>>>> _ArrayScale1D_
>>>>>>> <http://hypar.github.io/a00165.html#a1dab5f429ccd03c4a7fbb605d8ef75b6>
>>>>>>> (values,(dxinv*iblank),(nvars*nvars));
>>>>>>> ierr =
>>>>>>> MatSetValues(Pmat,nvars,rows,nvars,cols,values,ADD_VALUES); CHKERRQ(ierr);
>>>>>>> /* left neighbor */
>>>>>>> if (pgL >= 0) {
>>>>>>> nvars*pgL + v; }
>>>>>>> (values,(u+nvars*pL),solver->physics
>>>>>>> ,dir,1);
>>>>>>> _ArrayScale1D_
>>>>>>> (values,(-dxinv*iblank),(nvars*nvars));
>>>>>>> ierr =
>>>>>>> /* right neighbor */
>>>>>>> if (pgR >= 0) {
>>>>>>> nvars*pgR + v; }
>>>>>>> (values,(u+nvars*pR),solver->physics
>>>>>>> ,dir,-1);
>>>>>>> _ArrayScale1D_
>>>>>>> ierr =
>>>>>>> I do not know if I am clear here ...
>>>>>>> Anyways, I am trying to figure out how to do this shell matrix and
>>>>>>> this preconditioner using all the FV and DMPlex artillery.
>>>>>> Okay, that is very clear. We should be able to get the JFNK just with
>>>>>> -snes_mf_operator, and put the approximate J construction in
>>>>>> DMPlexComputeJacobian_Internal().
>>>>>> There is an FV section already, and we could just add this. I would
>>>>>> need to understand those entries in the pointwise Riemann sense that the
>>>>>> other stuff is now.
>>>>> Ok i had a quick look and if I understood correctly it would do the
>>>>> job. Setting the snes-mf-operator flag would mean however that we have to
>>>>> go through SNESSetJacobian to set the jacobian and the preconditioning
>>>>> matrix wouldn't it ?
>>>>> Thibault,
>>>>> Since the TS implicit methods end up using SNES internally the
>>>>> option should be available to you without requiring you to be calling the
>>>>> SNES routines directly
>>>>> Once you have finalized your approach and if for the implicit case
>>>>> you always work in the snes mf operator mode you can hardwire
>>>>> TSGetSNES(ts,&snes);
>>>>> in your code so you don't need to always provide the option
>>>>> -snes-mf-operator
>>>>> Barry
>>>>> There might be calls to the Riemann solver to evaluate the dRHS / dU
>>>>> part yes but maybe it's possible to re-use what was computed for the RHS^n ?
>>>>> In the FV section the jacobian is set to identity which I missed
>>>>> before, but it could explain why when I used the following :
>>>>> TSSetType(ts, TSBEULER);
>>>>> DMTSSetIFunctionLocal(dm, DMPlexTSComputeIFunctionFEM <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/DMPlexTSComputeIFunctionFEM.html#DMPlexTSComputeIFunctionFEM>, &ctx);
>>>>> DMTSSetIJacobianLocal(dm, DMPlexTSComputeIJacobianFEM <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/DMPlexTSComputeIJacobianFEM.html#DMPlexTSComputeIJacobianFEM>, &ctx);
>>>>> with my FV discretization nothing happened, right ?
>>>>> Thank you,
>>>>> Thibault
>>>>> Thanks,
>>>>>> Matt
>>>>>>> Le ven. 21 août 2020 à 14:55, Thibault Bridel-Bertomeu <
>>>>>>> thibault.bridelbertomeu at gmail.com> a écrit :
>>>>>> Hi,
>>>>>>>> Thanks Matthew and Jed for your input.
>>>>>>>> I indeed envision an implicit solver in the sense Jed mentioned -
>>>>>>>> Jiri Blazek's book is a nice intro to this concept.
>>>>>>>> Matthew, I do not know exactly what to change right now because
>>>>>>>> although I understand globally what the DMPlexComputeXXXX_Internal methods
>>>>>>>> do, I cannot say for sure line by line what is happening.
>>>>>>>> In a structured code, I have a an implicit FVM solver with PETSc
>>>>>>>> but I do not use any of the FV structure, not even a DM - I just use C
>>>>>>>> arrays that I transform to PETSc Vec and Mat and build my IJacobian and my
>>>>>>>> preconditioner and gives all that to a TS and it runs. I cannot figure out
>>>>>>>> how to do it with the FV and the DM and all the underlying "shortcuts" that
>>>>>>>> I want to use.
>>>>>>>> Here is the top method for the structured code :
>>>>>>>> int total_size = context.npoints * solver->nvars
>>>>>>>> ierr = TSSetRHSFunction(ts,PETSC_NULL,PetscRHSFunctionImpl,&context);
>>>>>>>> CHKERRQ(ierr);
>>>>>>>> SNES snes;
>>>>>>>> KSP ksp;
>>>>>>>> PC pc;
>>>>>>>> SNESType snestype;
>>>>>>>> ierr = TSGetSNES(ts,&snes); CHKERRQ(ierr);
>>>>>>>> ierr = SNESGetType(snes,&snestype); CHKERRQ(ierr);
>>>>>>>> flag_mat_a = 1;
>>>>>>>> ierr = MatCreateShell(MPI_COMM_WORLD,total_size,total_size,
>>>>>>>> PETSC_DETERMINE,
>>>>>>>> PETSC_DETERMINE,&context,&A); CHKERRQ(ierr);
>>>>>>>> context.jfnk_eps = 1e-7;
>>>>>>>> ierr = PetscOptionsGetReal(NULL,NULL,"-jfnk_epsilon",&context.
>>>>>>>> jfnk_eps,NULL); CHKERRQ(ierr);
>>>>>>>> ierr = MatShellSetOperation(A,MATOP_MULT,(void (*)(void))
>>>>>>>> PetscJacobianFunction_JFNK); CHKERRQ(ierr);
>>>>>>>> ierr = MatSetUp(A); CHKERRQ(ierr);
>>>>>>>> context.flag_use_precon = 0;
>>>>>>>> ierr = PetscOptionsGetBool(PETSC_NULL,PETSC_NULL,"-with_pc",(
>>>>>>>> PetscBool*)(&context.flag_use_precon),PETSC_NULL); CHKERRQ(ierr);
>>>>>>>> /* Set up preconditioner matrix */
>>>>>>>> flag_mat_b = 1;
>>>>>>>> ierr = MatCreateAIJ(MPI_COMM_WORLD,total_size,total_size,
>>>>>>>> PETSC_DETERMINE,PETSC_DETERMINE,
>>>>>>> (solver->ndims*2+1)*solver->nvars,NULL,
>>>>>>>> 2*solver->ndims*solver->nvars,NULL,&B); CHKERRQ(ierr);
>>>>>>>> ierr = MatSetBlockSize(B,solver->nvars);
>>>>>>>> /* Set the RHSJacobian function for TS */
>>>>>>> ierr = TSSetIJacobian(ts,A,B,PetscIJacobian,&context); CHKERRQ(ierr
>>>>>>>> Eng, MSc, PhD
>>>>>>>> Research Engineer
>>>>>>>> CEA/CESTA
>>>>>>>> 33114 LE BARP
>>>>>>>> Tel.: (+33)557046924
>>>>>>>> Mob.: (+33)611025322
>>>>>>>> Mail: thibault.bridelbertomeu at gmail.com
>>>>>>>> Le jeu. 20 août 2020 à 18:43, Jed Brown <jed at jedbrown.org> a
>>>>>>>> écrit :
>>>>>>>>> Matthew Knepley <knepley at gmail.com> writes:
>>>>>>>>> > I could never get the FVM stuff to make sense to me for implicit
>>>>>>>>> methods.
>>>>>>>>> > Here is my problem understanding. If you have an FVM method, it
>>>>>>>>> decides
>>>>>>>>> > to move "stuff" from one cell to its neighboring cells depending
>>>>>>>>> on the
>>>>>>>>> > solution to the Riemann problem on each face, which computed the
>>>>>>>>> flux. This
>>>>>>>>> > is
>>>>>>>>> > fine unless the timestep is so big that material can flow
>>>>>>>>> through into the
>>>>>>>>> > cells beyond the neighbor. Then I should have considered the
>>>>>>>>> effect of the
>>>>>>>>> > Riemann problem for those interfaces. That would be in the
>>>>>>>>> Jacobian, but I
>>>>>>>>> > don't know how to compute that Jacobian. I guess you could do
>>>>>>>>> everything
>>>>>>>>> > matrix-free, but without a preconditioner it seems hard.
>>>>>>>>> So long as we're using method of lines, the flux is just
>>>>>>>>> instantaneous flux, not integrated over some time step. It has the same
>>>>>>>>> meaning for implicit and explicit.
>>>>>>>>> An explicit method would be unstable if you took such a large time
>>>>>>>>> step (CFL) and an implicit method will not simultaneously be SSP and higher
>>>>>>>>> than first order, but it's still a consistent discretization of the problem.
>>>>>>>>> It's common (done in FUN3D and others) to precondition with a
>>>>>>>>> first-order method, where gradient reconstruction/limiting is skipped.
>>>>>>>>> That's what I'd recommend because limiting creates nasty nonlinearities and
>>>>>>>>> the resulting discretizations lack h-ellipticity which makes them very hard
>>>>>>>>> to solve.
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> Eng, MSc, PhD
>>>> Research Engineer
>>>> CEA/CESTA
>>>> 33114 LE BARP
>>> <petsc_fvm_part_timedisc_v2.pdf><petsc_fvm_part_petscdefs_v2.pdf>
>> Eng, MSc, PhD
>> Research Engineer
>> CEA/CESTA
>> 33114 LE BARP
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200825/8790fae1/attachment-0001.html>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200825/8790fae1/attachment-0001.pdf>
