[petsc-users] Bus Error
Mon Aug 24 13:06:11 CDT 2020
On Mon, Aug 24, 2020 at 1:46 PM Barry Smith <bsmith at petsc.dev> wrote:
> > On Aug 24, 2020, at 12:39 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Barry Smith <bsmith at petsc.dev> writes:
> >>>> So if a BLAS errors with SIGBUS then it is always an input error of
> just not proper double/complex alignment? Or some other very strange thing?
> >>> I would suspect memory corruption.
> >>  Corruption meaning what specifically?
> >>  The routines crashing are dgemv which only take double precision
> arrays, regardless of what garbage is in those arrays i don't think there
> can be BUS errors resulting. They don't take integer arrays whose
> corruption could result in bad indexing and then BUS errors.
> >>  So then it can only be corruption of the pointers passed in, correct?
> > Such as those pointers pointing into data on the stack with incorrect
> sizes.
> But won't incorrect sizes "usually" lead to SEGV not SEGBUS?
My understanding was that roughly memory errors in the heap are SEGV and
memory errors on the stack are SIGBUS. Is that not true?
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200824/d1ff87a3/attachment.html>
