[petsc-users] Bus Error
Jed Brown jed at jedbrown.org
Mon Aug 24 12:39:15 CDT 2020
Barry Smith <bsmith at petsc.dev> writes:
>>>  So if a BLAS errors with SIGBUS then it is always an input error of just not proper double/complex alignment? Or some other very strange thing?
>> I would suspect memory corruption.
>   Corruption meaning what specifically?
>   The routines crashing are dgemv which only take double precision arrays, regardless of what garbage is in those arrays i don't think there can be BUS errors resulting. They don't take integer arrays whose corruption could result in bad indexing and then BUS errors.
>   So then it can only be corruption of the pointers passed in, correct?
Such as those pointers pointing into data on the stack with incorrect sizes.
