[petsc-users] Disable PETSC_HAVE_CLOSURE
Fande Kong fdkong.jd at gmail.com
Mon Aug 24 11:29:00 CDT 2020
Thanks for your reply, Jed.
Barry, do you have any comment?
Fande,
On Thu, Aug 20, 2020 at 9:19 AM Jed Brown <jed at jedbrown.org> wrote:
> Barry, this is a side-effect of your Swift experiment.  Does that need to
> be in a header (even if it's a private header)?
> The issue may be that you test with a C compiler and it gets included in
> C++ source.
> Fande Kong <fdkong.jd at gmail.com> writes:
> > Hi All,
> > We (moose team) hit an error message when compiling PETSc, recently. The
> > error is related to "PETSC_HAVE_CLOSURE." Everything runs well if I am
> > going to turn this flag off by making the following changes:
> > git diff
> > diff --git a/config/BuildSystem/config/utilities/closure.py
> > b/config/BuildSystem/config/utilities/closure.py
> > index 6341ddf271..930e5b3b1b 100644
> > --- a/config/BuildSystem/config/utilities/closure.py
> > +++ b/config/BuildSystem/config/utilities/closure.py
> > @@ -19,8 +19,8 @@ class Configure(config.base.Configure):
> >   includes = '#include <stdio.h>\n'
> >   body = 'int (^closure)(int);'
> >   self.pushLanguage('C')
> > - if self.checkLink(includes, body):
> > - self.addDefine('HAVE_CLOSURE','1')
> > +# if self.checkLink(includes, body):
> > +# self.addDefine('HAVE_CLOSURE','1')
> >  def configure(self):
> >   self.executeTest(self.configureClosure)
> > I was wondering if there exists a configuration option to disable
> "Closure"
> > C syntax?  I did not find one by running "configuration --help"
> > Please let me know if you need more information.
> > Thanks,
> > Fande,
> > In file included from
> /Users/milljm/projects/moose/scripts/../libmesh/src/solvers/petscdmlibmesh.C:25:
> /Users/milljm/projects/moose/petsc/include/petsc/private/petscimpl.h:15:29:
> > warning: 'PetscVFPrintfSetClosure' initialized and declared 'extern'
> >   15 | PETSC_EXTERN PetscErrorCode PetscVFPrintfSetClosure(int (^)(const
> > char*));
> /Users/milljm/projects/moose/petsc/include/petsc/private/petscimpl.h:15:53:
> > error: expected primary-expression before 'int'
> > char*));
> >  CXX   src/systems/libmesh_opt_la-equation_systems_io.lo
> > /Users/milljm/projects/moose/petsc/include/petsc/private/dmimpl.h:7,
> >          from
> /Users/milljm/projects/moose/scripts/../libmesh/src/solvers/petscdmlibmeshimpl.C:26:
> > char*));
> > char*));
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200824/9a95bde4/attachment.html>
