[petsc-users] MatAssemblyEnd taking too long
Barry Smith bsmith at petsc.dev
Fri Aug 21 12:32:37 CDT 2020
  There really needs to be a usable extensive MPI test suite that can find these performance issues, we spend time helping users with these problems when it is really the MPI communities job.
> On Aug 21, 2020, at 11:55 AM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> I built petsc with mpich-3.3.2 on my MacBook Pro with Apple clang 11.0.3 and the test is finishing at my end.
> So, it appears that there is some issue with openmpi-4.0.1 on this machine.
> I will now build all my dependency toolchain with mpich and hopefully things will work for my application code.
> Thank you again for your help.
> Regards,
> Manav
>> On Aug 20, 2020, at 10:45 PM, Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>> Manav,
>>  I downloaded your petsc_mat.tgz but could not reproduce the problem, on both Linux and Mac. I used the petsc commit id df0e4300 you mentioned.
>>  On Linux, I have openmpi-4.0.2 + gcc-8.3.0, and petsc is configured  --with-debugging --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort --COPTFLAGS="-g -O0" --FOPTFLAGS="-g -O0" --CXXOPTFLAGS="-g -O0" --PETSC_ARCH=linux-host-dbg
>>  On Mac, I have mpich-3.3.1 + clang-11.0.0-apple, and petsc is configured --with-debugging=1 --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort --with-ctable=0 COPTFLAGS="-O0 -g" CXXOPTFLAGS="-O0 -g" PETSC_ARCH=mac-clang-dbg
>> mpirun -n 8 ./test
>> rank: 1 : stdout.processor.1
>> rank: 4 : stdout.processor.4
>> rank: 0 : stdout.processor.0
>> rank: 5 : stdout.processor.5
>> rank: 6 : stdout.processor.6
>> rank: 7 : stdout.processor.7
>> rank: 3 : stdout.processor.3
>> rank: 2 : stdout.processor.2
>> rank: 1 : Beginning reading nnz...
>> rank: 4 : Beginning reading nnz...
>> rank: 0 : Beginning reading nnz...
>> rank: 5 : Beginning reading nnz...
>> rank: 7 : Beginning reading nnz...
>> rank: 2 : Beginning reading nnz...
>> rank: 3 : Beginning reading nnz...
>> rank: 6 : Beginning reading nnz...
>> rank: 5 : Finished reading nnz
>> rank: 5 : Beginning mat preallocation...
>> rank: 3 : Finished reading nnz
>> rank: 3 : Beginning mat preallocation...
>> rank: 4 : Finished reading nnz
>> rank: 4 : Beginning mat preallocation...
>> rank: 7 : Finished reading nnz
>> rank: 7 : Beginning mat preallocation...
>> rank: 1 : Finished reading nnz
>> rank: 1 : Beginning mat preallocation...
>> rank: 0 : Finished reading nnz
>> rank: 0 : Beginning mat preallocation...
>> rank: 2 : Finished reading nnz
>> rank: 2 : Beginning mat preallocation...
>> rank: 6 : Finished reading nnz
>> rank: 6 : Beginning mat preallocation...
>> rank: 5 : Finished preallocation
>> rank: 5 : Beginning reading and setting matrix values...
>> rank: 1 : Finished preallocation
>> rank: 1 : Beginning reading and setting matrix values...
>> rank: 7 : Finished preallocation
>> rank: 7 : Beginning reading and setting matrix values...
>> rank: 2 : Finished preallocation
>> rank: 2 : Beginning reading and setting matrix values...
>> rank: 4 : Finished preallocation
>> rank: 4 : Beginning reading and setting matrix values...
>> rank: 0 : Finished preallocation
>> rank: 0 : Beginning reading and setting matrix values...
>> rank: 3 : Finished preallocation
>> rank: 3 : Beginning reading and setting matrix values...
>> rank: 6 : Finished preallocation
>> rank: 6 : Beginning reading and setting matrix values...
>> rank: 1 : Finished reading and setting matrix values
>> rank: 1 : Beginning mat assembly...
>> rank: 5 : Finished reading and setting matrix values
>> rank: 5 : Beginning mat assembly...
>> rank: 4 : Finished reading and setting matrix values
>> rank: 4 : Beginning mat assembly...
>> rank: 2 : Finished reading and setting matrix values
>> rank: 2 : Beginning mat assembly...
>> rank: 3 : Finished reading and setting matrix values
>> rank: 3 : Beginning mat assembly...
>> rank: 7 : Finished reading and setting matrix values
>> rank: 7 : Beginning mat assembly...
>> rank: 6 : Finished reading and setting matrix values
>> rank: 6 : Beginning mat assembly...
>> rank: 0 : Finished reading and setting matrix values
>> rank: 0 : Beginning mat assembly...
>> rank: 1 : Finished mat assembly
>> rank: 3 : Finished mat assembly
>> rank: 7 : Finished mat assembly
>> rank: 0 : Finished mat assembly
>> rank: 5 : Finished mat assembly
>> rank: 2 : Finished mat assembly
>> rank: 4 : Finished mat assembly
>> rank: 6 : Finished mat assembly
>> --Junchao Zhang
>> On Thu, Aug 20, 2020 at 5:29 PM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>> I will have a look and report back to you. Thanks.
>> --Junchao Zhang
>> On Thu, Aug 20, 2020 at 5:23 PM Manav Bhatia <bhatiamanav at gmail.com <mailto:bhatiamanav at gmail.com>> wrote:
>> I have created a standalone test that demonstrates the problem at my end. I have stored the indices, etc.  from my problem in a text file for each rank, which I use to initialize the matrix.
>> Please note that the test is specifically for 8 ranks.
>> The .tgz file is on my google drive: https://drive.google.com/file/d/1R-WjS36av3maXX3pUyiR3ndGAxteTVj-/view?usp=sharing <https://drive.google.com/file/d/1R-WjS36av3maXX3pUyiR3ndGAxteTVj-/view?usp=sharing>
>> This contains a README file with instructions on running. Please note that the work directory needs the index files.
>> Please let me know if I can provide any further information.
>> Thank you all for your help.
>> Regards,
>> Manav
>>> On Aug 20, 2020, at 12:54 PM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>>> Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> writes:
>>>> On Thu, Aug 20, 2020 at 11:09 AM Manav Bhatia <bhatiamanav at gmail.com <mailto:bhatiamanav at gmail.com>> wrote:
>>>>> On Aug 20, 2020, at 8:31 AM, Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>>
>>>>> wrote:
>>>>> Can you add a MPI_Barrier before
>>>>> ierr = MatAssemblyBegin(aij->A,mode);CHKERRQ(ierr);
>>>>> With a MPI_Barrier before this function call:
>>>>> —  three of the processes have already hit this barrier,
>>>>> —  the other 5 are inside MatStashScatterGetMesg_Private ->
>>>>> MatStashScatterGetMesg_BTS -> MPI_Waitsome(2 processes)/MPI_Waitall(3
>>>>> processes)
>>> This is not itself evidence of inconsistent state.  You can use
>>>  -build_twosided allreduce
>>> to avoid the nonblocking sparse algorithm.
>>>> Okay, you should run this with -matstash_legacy just to make sure it is not
>>>> a bug in your MPI implementation. But it looks like
>>>> there is inconsistency in the parallel state. This can happen because we
>>>> have a bug, or it could be that you called a collective
>>>> operation on a subset of the processes. Is there any way you could cut down
>>>> the example (say put all 1s in the matrix, etc) so
>>>> that you could give it to us to run?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200821/41f7102f/attachment.html>
