[petsc-users] MatAssemblyEnd taking too long
Manav Bhatia bhatiamanav at gmail.com
Thu Aug 20 17:23:52 CDT 2020
I have created a standalone test that demonstrates the problem at my end. I have stored the indices, etc.  from my problem in a text file for each rank, which I use to initialize the matrix.
Please note that the test is specifically for 8 ranks.
The .tgz file is on my google drive: https://drive.google.com/file/d/1R-WjS36av3maXX3pUyiR3ndGAxteTVj-/view?usp=sharing <https://drive.google.com/file/d/1R-WjS36av3maXX3pUyiR3ndGAxteTVj-/view?usp=sharing>
This contains a README file with instructions on running. Please note that the work directory needs the index files.
Please let me know if I can provide any further information.
Thank you all for your help.
Manav
> On Aug 20, 2020, at 12:54 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> writes:
>> On Thu, Aug 20, 2020 at 11:09 AM Manav Bhatia <bhatiamanav at gmail.com> wrote:
>>> On Aug 20, 2020, at 8:31 AM, Stefano Zampini <stefano.zampini at gmail.com>
>>> wrote:
>>> Can you add a MPI_Barrier before
>>> ierr = MatAssemblyBegin(aij->A,mode);CHKERRQ(ierr);
>>> With a MPI_Barrier before this function call:
>>> —  three of the processes have already hit this barrier,
>>> —  the other 5 are inside MatStashScatterGetMesg_Private ->
>>> MatStashScatterGetMesg_BTS -> MPI_Waitsome(2 processes)/MPI_Waitall(3
>>> processes)
> This is not itself evidence of inconsistent state.  You can use
>  -build_twosided allreduce
> to avoid the nonblocking sparse algorithm.
>> Okay, you should run this with -matstash_legacy just to make sure it is not
>> a bug in your MPI implementation. But it looks like
>> there is inconsistency in the parallel state. This can happen because we
>> have a bug, or it could be that you called a collective
>> operation on a subset of the processes. Is there any way you could cut down
>> the example (say put all 1s in the matrix, etc) so
>> that you could give it to us to run?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200820/b134d4c1/attachment.html>
