[petsc-users] MatAssemblyEnd taking too long
    Manav Bhatia
    bhatiamanav at gmail.com
    Wed Aug 19 19:30:11 CDT 2020
   I have an application that uses the KSP solver and I am looking at the performance with increasing system size. I am currently running on MacBook Pro with 32 GB memory and Petsc obtained from GitHub (commit df0e43005dbe6ff47eff22a32b336a6c37d02c3a).
   The application runs fine till about 2e6 DoFs using gamg without any problems.
   However, when I try a larger system size, in this case with 5.4e6 DoFs, the application hangs for an hour and I have to kill the MPI processes.
   I tried to use Xcode Instruments to profile the 8 MPI processes and I have attached a screenshot of the recorded results from each process. All processes are stuck inside MatAssemblyEnd, but at different function calls.
   I am not sure how to debug this issue, and would greatly appreciate any guidance.
   For reference, I am calling PETSc with the following options:
  -ksp_type gmres -pc_type gamg -mat_block_size 3 -mg_levels_ksp_max_it 4 -ksp_monitor -ksp_converged_reason
Manav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200819/3ece724d/attachment-0001.html>
Name: Screen Shot 2020-08-19 at 7.16.08 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200819/3ece724d/attachment-0008.png>
Name: Screen Shot 2020-08-19 at 7.16.06 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200819/3ece724d/attachment-0009.png>
Name: Screen Shot 2020-08-19 at 7.16.04 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200819/3ece724d/attachment-0010.png>
Name: Screen Shot 2020-08-19 at 7.16.02 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200819/3ece724d/attachment-0011.png>
Name: Screen Shot 2020-08-19 at 7.15.59 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200819/3ece724d/attachment-0012.png>
Name: Screen Shot 2020-08-19 at 7.15.57 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200819/3ece724d/attachment-0013.png>
Name: Screen Shot 2020-08-19 at 7.15.55 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200819/3ece724d/attachment-0014.png>
Name: Screen Shot 2020-08-19 at 7.15.52 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200819/3ece724d/attachment-0015.png>
