[petsc-users] ParMETIS vs. CHACO when no partitioning is made
Fande Kong fdkong.jd at gmail.com
Mon Aug 17 18:18:00 CDT 2020
For this particular case (one subdoanin), it may be easy to fix in petsc.
We could create a partitioning index filled with zeros.
Fande,
On Mon, Aug 17, 2020 at 5:04 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> IIRC, Chaco does not produce an arbitrary number of subdomains. The number
> needs to be like 2^n.
> ParMETIS and PTScotch are much better, and they are production-level code.
> If there is no particular reason, I would like to suggest staying with
> ParMETIS and PTScotch.
> Thanks,
> Fande,
> On Fri, Aug 14, 2020 at 10:07 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>> Dear Barry,
>> Thank you for answering. I am sending a sample code and a binary file.
>> Thanks!
>> Eda
>> Barry Smith <bsmith at petsc.dev>, 14 Ağu 2020 Cum, 18:49 tarihinde şunu
>> yazdı:
>>>    Could be a bug in Chaco or its call from PETSc for the special case
>>> of one process. Could you send a sample code that demonstrates the problem?
>>>   Barry
>>> > On Aug 14, 2020, at 8:53 AM, Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>>> > Hi all,
>>> > I am trying to try something. I am using the same MatPartitioning
>>> codes for both CHACO and ParMETIS:
>>> > ierr =
>>> MatConvert(SymmA,MATMPIADJ,MAT_INITIAL_MATRIX,&AL);CHKERRQ(ierr);
>>> >   ierr = MatPartitioningCreate(MPI_COMM_WORLD,&part);CHKERRQ(ierr);
>>> >   ierr = MatPartitioningSetAdjacency(part,AL);CHKERRQ(ierr);
>>> >   ierr = MatPartitioningSetFromOptions(part);CHKERRQ(ierr);
>>> >   ierr = MatPartitioningApply(part,&partitioning);CHKERRQ(ierr);
>>> > After obtaining the IS, I apply this to my original nonsymmetric
>>> matrix and try to get an approximate edge cut.
>>> > Except for 1 partitioning, my program completely works for 2,4 and 16
>>> partitionings. However, for 1, ParMETIS gives results where CHACO I guess
>>> doesn't since I am getting errors about the index set.
>>> > What is the difference between CHACO and ParMETIS that one works for 1
>>> partitioning and one doesn't?
>>> > Thanks!
>>> > Eda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200817/a90217bf/attachment.html>
