[petsc-users] Question on matrix assembly
Barry Smith bsmith at petsc.dev
Fri Aug 14 13:43:51 CDT 2020
   Sajid,
   Are the rows truly compute from first to last in order and all entries for a row are available together?
   Barry
> On Aug 14, 2020, at 1:00 PM, Sajid Ali <sajidsyed2021 at u.northwestern.edu> wrote:
> @Matthew Knepley <mailto:knepley at gmail.com> : Thanks for the explanation on preallocation.
> >However, why not have a flag so that on the first pass you do not compute entries, just the indices?
> The matrix computes the projection of an image onto a detector so generating this involves computing all possible ray-rectangle intersections and computing the values only differs from computing the indices by a call to calculate intersection lengths. The process to set up the geometry and check for intersections is the same to generate indices and values.
> So, in this case the tradeoff would be to either compute everything twice and save on storage cost or compute everything once and use more memory (essentially compute the matrix rows on each rank, preallocate and then set the matrix values).
> @Stefano Zampini <mailto:stefano.zampini at gmail.com> : Yes, I only need MatMult and MatMultTranspose in the TAO objective/gradient evaluation but in the current state it's cheaper to use a matrix instead of computing the intersections for each objective/gradient evaluation. About ~70% of the application time is spent in MatMult and MatMultTranspose so we're hoping that this would benefit from running on GPU's.
> Thanks for the pointer to MatShell, implementing a matrix free method is something we might pursue in the future.
> Sajid Ali | PhD Candidate
> Applied Physics
> Northwestern University
> s-sajid-ali.github.io <http://s-sajid-ali.github.io/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200814/f77856a2/attachment.html>
