[petsc-users] ParMETIS vs. CHACO when no partitioning is made
Eda Oktay
eda.oktay at metu.edu.tr
Fri Aug 14 11:07:25 CDT 2020
Dear Barry,
Thank you for answering. I am sending a sample code and a binary file.
Thanks!
Eda
Barry Smith <bsmith at petsc.dev>, 14 Ağu 2020 Cum, 18:49 tarihinde şunu yazdı:
> Could be a bug in Chaco or its call from PETSc for the special case of
> one process. Could you send a sample code that demonstrates the problem?
> Barry
> > On Aug 14, 2020, at 8:53 AM, Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> > Hi all,
> > I am trying to try something. I am using the same MatPartitioning codes
> for both CHACO and ParMETIS:
> > ierr =
> MatConvert(SymmA,MATMPIADJ,MAT_INITIAL_MATRIX,&AL);CHKERRQ(ierr);
> > ierr = MatPartitioningCreate(MPI_COMM_WORLD,&part);CHKERRQ(ierr);
> > ierr = MatPartitioningSetAdjacency(part,AL);CHKERRQ(ierr);
> > ierr = MatPartitioningSetFromOptions(part);CHKERRQ(ierr);
> > ierr = MatPartitioningApply(part,&partitioning);CHKERRQ(ierr);
> > After obtaining the IS, I apply this to my original nonsymmetric matrix
> and try to get an approximate edge cut.
> > Except for 1 partitioning, my program completely works for 2,4 and 16
> partitionings. However, for 1, ParMETIS gives results where CHACO I guess
> doesn't since I am getting errors about the index set.
> > What is the difference between CHACO and ParMETIS that one works for 1
> partitioning and one doesn't?
> > Thanks!
> > Eda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200814/7915a24b/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200814/7915a24b/attachment.zip>
