[petsc-users] [EXT]Re: MatZeroRows
Anthony Paul Haas
aph at email.arizona.edu
Thu Aug 13 16:47:06 CDT 2020
Awesome! thanks to all.
Cheers
On Thu, Aug 13, 2020 at 2:19 PM Barry Smith <bsmith at petsc.dev> wrote:
> *External Email*
> Anthony,
> Keeping the nonzero locations (with zero in them) will be a bit faster
> in the call to MatZeroRows() because otherwise it has to shift all the
> entries in the sparse matrix arrays data structures to "remove" the
> unneeded locations.
> But the real question is how it affects times in later function calls
> 1) If you do the MatSetValues()/MatAssemblyBegin/End() repeatedly it will
> be much faster if you keep the nonzero locations (with zero in them).
> 2) Time for MatMult() will be a bit faster if you remove the locations,
> but the depending on the preconditioner the preconditioner may be more or
> less effective and a bit slower or faster.
> So, rule of thumb is if you only do MatZeroRows() once you might
> generally remove the locations but if it is done in a loop with the same
> matrix (over time-steps for example, or even in SNES) you want to keep the
> nonzero locations.
> Barry
> Note: in both cases the memory usage is the same because PETSc does not
> "return" the excessive memory.
> On Aug 13, 2020, at 8:07 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Aug 13, 2020 at 3:17 AM Anthony Paul Haas <aph at email.arizona.edu>
> wrote:
>> Hello,
>> I am using MatZeroRows for imposing a known forcing into my equations in
>> conjunction with rhs and by setting the diagonal of the matrix to 1.
>> I am using Fortran. I have used:
>> ! only local processors set their own zeros
>> call MatSetOption(self%fieldLHSMat_ps, MAT_NO_OFF_PROC_ZERO_ROWS,
>> PETSC_TRUE, ierr)
>> call MatSetOption(self%fieldLHSMat_ps, MAT_KEEP_NONZERO_PATTERN,
>> PETSC_TRUE, ierr)
>> call MatZeroRows(self%fieldLHSMat_ps, numrows, glob_row_idx, diag,
>> PETSC_NULL_OBJECT, PETSC_NULL_OBJECT, ierr)
>> Is numrows above the local (on each proc.) number of rows to remove, or
>> is it the global number of rows to remove?
> Local.
>> Also on some processors, I have no rows to remove, hence the array glob_row_idx
>> is not allocated. How can I tell Petsc? Should I pass PETSC_NULL_OBJECT
>> instead of glob_row_idx in this case?
> If you pass numrows = 0, it should not matter what is in the next slot, as
> long as it type checks.
>> Finally, does using the option MAT_KEEP_NONZERO_PATTERN have an influence
>> on the time the MatZeroRows call will take?
> I don't think it makes much of a difference, but I have not measured it.
> Thanks,
> Matt
>> Thanks,
>> Best regards,
>> Anthony
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200813/8bc0eabf/attachment-0001.html>
