[petsc-users] MatZeroRows
    Anthony Paul Haas
    aph at email.arizona.edu
    Thu Aug 13 02:16:32 CDT 2020
Hello,
I am using MatZeroRows for imposing a known forcing into my equations in
conjunction with rhs and by setting the diagonal of the matrix to 1.
I am using Fortran. I have used:
! only local processors set their own zeros
call MatSetOption(self%fieldLHSMat_ps, MAT_NO_OFF_PROC_ZERO_ROWS,
PETSC_TRUE, ierr)
call MatSetOption(self%fieldLHSMat_ps, MAT_KEEP_NONZERO_PATTERN,
PETSC_TRUE, ierr)
call MatZeroRows(self%fieldLHSMat_ps, numrows, glob_row_idx, diag,
PETSC_NULL_OBJECT, PETSC_NULL_OBJECT, ierr)
Is numrows above the local (on each proc.) number of rows to remove, or is
it the global number of rows to remove?
Also on some processors, I have no rows to remove, hence the array glob_row_idx
is not allocated. How can I tell Petsc? Should I pass PETSC_NULL_OBJECT
instead of glob_row_idx in this case?
Finally, does using the option MAT_KEEP_NONZERO_PATTERN have an influence
on the time the MatZeroRows call will take?
Best regards,
Anthony
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200813/cadf4101/attachment-0001.html>
