[petsc-users] Bus Error
Mark Lohry
mlohry at gmail.com
Wed Aug 12 13:29:37 CDT 2020
Thanks Matt and Barry. At Matt's suggestion I ran a smaller representative
case with valgrind and didn't see anything alarming (apart from a small
leak in an older boost version I was using:
https://github.com/boostorg/serialization/issues/104 although I don't
think this was causing the issue).
-malloc_debug dumps quite a lot, this is supposed to be empty right? Output
pasted below. It looks like the same sequence of calls is repeated 8 times,
which is how many nonlinear solves occurred in this particular run.
Thoughts?
[ 0]1408 bytes PetscSplitReductionCreate() line 63 in
/home/mlohry/dev/cmake-build/external/petsc/src/vec/vec/utils/comb.c
[ 0]80 bytes PetscSplitReductionCreate() line 57 in
[ 0]16 bytes PetscCommBuildTwoSided_Allreduce() line 169 in
/home/mlohry/dev/cmake-build/external/petsc/src/sys/utils/mpits.c
[ 0]16 bytes ISGeneralSetIndices_General() line 578 in
/home/mlohry/dev/cmake-build/external/petsc/src/vec/is/is/impls/general/general.c
[ 0]16 bytes PetscLayoutSetUp() line 269 in
/home/mlohry/dev/cmake-build/external/petsc/src/vec/is/utils/pmap.c
[ 0]80 bytes PetscLayoutCreate() line 55 in
[ 0]16 bytes PetscStrallocpy() line 187 in
/home/mlohry/dev/cmake-build/external/petsc/src/sys/utils/str.c
[ 0]32 bytes PetscStrallocpy() line 187 in
[ 0]32 bytes PetscFunctionListAdd_Private() line 255 in
/home/mlohry/dev/cmake-build/external/petsc/src/sys/dll/reg.c
[ 0]32 bytes PetscFunctionListAdd_Private() line 222 in
[ 0]16 bytes ISCreate_General() line 647 in
[ 0]896 bytes ISCreate() line 37 in
/home/mlohry/dev/cmake-build/external/petsc/src/vec/is/is/interface/isreg.c
[ 0]272 bytes ISGeneralSetIndices_General() line 578 in
[ 0]880 bytes ISGeneralSetIndices_General() line 578 in
[ 0]960 bytes ISGeneralSetIndices_General() line 578 in
[ 0]976 bytes ISGeneralSetIndices_General() line 578 in
[ 0]1024 bytes ISGeneralSetIndices_General() line 578 in
[ 0]1040 bytes ISGeneralSetIndices_General() line 578 in
[ 0]64 bytes ISColoringGetIS() line 266 in
/home/mlohry/dev/cmake-build/external/petsc/src/vec/is/is/utils/iscoloring.c
[ 0]32 bytes PetscCommDuplicate() line 129 in
/home/mlohry/dev/cmake-build/external/petsc/src/sys/objects/tagm.c
On Wed, Aug 12, 2020 at 1:46 PM Barry Smith <bsmith at petsc.dev> wrote:
> Mark.
> When valgrind is not feasible (like on many centrally controlled batch
> systems) you can run PETSc with an extra flag to do some memory error checks
> -malloc_debug
> this
> 1) fills all malloced memory with Nan so if the code is using
> uninitialized memory it may be detected and
> 2) checks the beginning and end of each alloced memory region for
> out-of-bounds writes at each malloc and free.
> it will slow the code down a little bit but generally not a huge amount.
> It is no where near as good as valgrind or other memory corruption tools
> but it has the advantage you can run it anywhere on any size job.
> Barry
> On Aug 12, 2020, at 7:46 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 12, 2020 at 7:53 AM Mark Lohry <mlohry at gmail.com> wrote:
>> I'm getting seemingly random failures of late:
>> Caught signal number 7 BUS: Bus Error, possibly illegal memory access
> The first thing I would do is run valgrind on as wide an array of tests as
> you can. This will find problems
> on things that run completely fine.
> Thanks,
> Matt
>> Symptoms:
>> 1) Seems to only happen (so far) on larger cases, 400-2000 cores
>> 2) It doesn't happen right away -- this was running happily for several
>> hours over several hundred time steps with no indication of bad health in
>> the numerics
>> 3) At least the total memory consumption seems to be within bounds,
>> though I'm not sure about individual processes. e.g. slurm here reported
>> Memory Efficiency: 75.23% of 1.76 TB (180.00 GB/node)
>> 4) running the same setup twice it fails at different points
>> Any suggestions on what to look for? This is a bit painful to work on as
>> I can only reproduce it on large runs and then it's seemingly random.
>> Thanks,
>> Mark
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200812/78562e3c/attachment-0001.html>
