[petsc-users] overlap cpu and gpu?
Barry Smith
bsmith at petsc.dev
Wed Aug 12 04:14:58 CDT 2020
Interesting, we don't see crashes in GAMG. Could you run with
-ksp_view_mat binary -ksp_view_rhs binary
this will create a file called binaryoutput, you can email it to petsc-maint at mcs.anl.gov or if it is too large for email post it somewhere and email the link from this we could possibly recreate the crash to see what is going wrong.
Barry
7383 On entry to __cray_mgm_dgeqrf, parameter 7 had an illegal value (info = -7)
> On Aug 12, 2020, at 3:18 AM, nicola varini <nicola.varini at gmail.com> wrote:
> Dear all, following the suggestions I did resubmit the simulation with the petscrc below.
> However I do get the following error:
> 7362 [592]PETSC ERROR: #1 formProl0() line 748 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/impls/gamg/agg.c
> 7363 [339]PETSC ERROR: Petsc has generated inconsistent data
> 7364 [339]PETSC ERROR: xGEQRF error
> 7365 [339]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
> 7366 [339]PETSC ERROR: Petsc Release Version 3.13.3, Jul 01, 2020
> 7367 [339]PETSC ERROR: /users/nvarini/gbs_test_nicola/bin/gbs_daint_gpu_gnu on a named nid05083 by nvarini Wed Aug 12 10:06:15 2020
> 7368 [339]PETSC ERROR: Configure options --with-cc=cc --with-fc=ftn --known-mpi-shared-libraries=1 --known-mpi-c-double-complex=1 --known-mpi-int64_t=1 --known-mpi-long-double=1 --with-batch=1 --known-64-bit-blas-indices=0 --LIBS=-lstdc++ --with-cxxlib-autodetect=0 --with-scalapa ck=1 --with-cxx=CC --with-debugging=0 --with-hypre-dir=/opt/cray/pe/tpsl/19.06.1/GNU/8.2/haswell --prefix=/scratch/snx3000/nvarini/petsc3.13.3-gpu --with-cuda=1 --with-cuda-c=nvcc --with-cxxlib-autodetect=0 --COPTFLAGS=-I/opt/cray/pe/mpt/7.7.10/gni/mpich-intel/16.0/include - -with-cxx=CC --CXXOPTFLAGS=-I/opt/cray/pe/mpt/7.7.10/gni/mpich-intel/16.0/include
> 7369 [592]PETSC ERROR: #2 PCGAMGProlongator_AGG() line 1063 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/impls/gamg/agg.c
> 7370 [592]PETSC ERROR: #3 PCSetUp_GAMG() line 548 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/impls/gamg/gamg.c
> 7371 [592]PETSC ERROR: #4 PCSetUp() line 898 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/interface/precon.c
> 7372 [592]PETSC ERROR: #5 KSPSetUp() line 376 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/ksp/interface/itfunc.c
> 7373 [592]PETSC ERROR: #6 KSPSolve_Private() line 633 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/ksp/interface/itfunc.c
> 7374 [316]PETSC ERROR: #3 PCSetUp_GAMG() line 548 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/impls/gamg/gamg.c
> 7375 [339]PETSC ERROR: #1 formProl0() line 748 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/impls/gamg/agg.c
> 7376 [339]PETSC ERROR: #2 PCGAMGProlongator_AGG() line 1063 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/impls/gamg/agg.c
> 7377 [339]PETSC ERROR: #3 PCSetUp_GAMG() line 548 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/impls/gamg/gamg.c
> 7378 [339]PETSC ERROR: #4 PCSetUp() line 898 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/interface/precon.c
> 7379 [339]PETSC ERROR: #5 KSPSetUp() line 376 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/ksp/interface/itfunc.c
> 7380 [592]PETSC ERROR: #7 KSPSolve() line 853 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/ksp/interface/itfunc.c
> 7381 [339]PETSC ERROR: #6 KSPSolve_Private() line 633 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/ksp/interface/itfunc.c
> 7382 [339]PETSC ERROR: #7 KSPSolve() line 853 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/ksp/interface/itfunc.c
> 7384 [160]PETSC ERROR: #3 PCSetUp_GAMG() line 548 in /scratch/snx3000/nvarini/petsc-3.13.3/src/ksp/pc/impls/gamg/gamg.c
> I did try other pc_gamg_type but they fails as well.
> #PETSc Option Table entries:
> -ampere_dm_mat_type aijcusparse
> -ampere_dm_vec_type cuda
> -ampere_ksp_atol 1e-15
> -ampere_ksp_initial_guess_nonzero yes
> -ampere_ksp_reuse_preconditioner yes
> -ampere_ksp_rtol 1e-7
> -ampere_ksp_type dgmres
> -ampere_mg_levels_esteig_ksp_max_it 10
> -ampere_mg_levels_esteig_ksp_type cg
> -ampere_mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05
> -ampere_mg_levels_ksp_type chebyshev
> -ampere_mg_levels_pc_type jacobi
> -ampere_pc_gamg_agg_nsmooths 1
> -ampere_pc_gamg_coarse_eq_limit 10
> -ampere_pc_gamg_reuse_interpolation true
> -ampere_pc_gamg_square_graph 1
> -ampere_pc_gamg_threshold 0.05
> -ampere_pc_gamg_threshold_scale .0
> -ampere_pc_gamg_type agg
> -ampere_pc_type gamg
> -dm_mat_type aijcusparse
> -dm_vec_type cuda
> -log_view
> -poisson_dm_mat_type aijcusparse
> -poisson_dm_vec_type cuda
> -poisson_ksp_atol 1e-15
> -poisson_ksp_initial_guess_nonzero yes
> -poisson_ksp_reuse_preconditioner yes
> -poisson_ksp_rtol 1e-7
> -poisson_ksp_type dgmres
> -poisson_log_view
> -poisson_mg_levels_esteig_ksp_max_it 10
> -poisson_mg_levels_esteig_ksp_type cg
> -poisson_mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05
> -poisson_mg_levels_ksp_max_it 1
> -poisson_mg_levels_ksp_type chebyshev
> -poisson_mg_levels_pc_type jacobi
> -poisson_pc_gamg_agg_nsmooths 1
> -poisson_pc_gamg_coarse_eq_limit 10
> -poisson_pc_gamg_reuse_interpolation true
> -poisson_pc_gamg_square_graph 1
> -poisson_pc_gamg_threshold 0.05
> -poisson_pc_gamg_threshold_scale .0
> -poisson_pc_gamg_type agg
> -poisson_pc_type gamg
> -use_mat_nearnullspace true
> #End of PETSc Option Table entries
> Regards,
> Nicola
> Il giorno mar 4 ago 2020 alle ore 17:57 Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> ha scritto:
> On Tue, Aug 4, 2020 at 6:35 AM Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
> Nicola,
> You are actually not using the GPU properly, since you use HYPRE preconditioning, which is CPU only. One of your solvers is actually slower on “GPU”.
> For a full AMG GPU, you can use PCGAMG, with cheby smoothers and with Jacobi preconditioning. Mark can help you out with the specific command line options.
> When it works properly, everything related to PC application is offloaded to the GPU, and you should expect to get the well-known and branded 10x (maybe more) speedup one is expecting from GPUs during KSPSolve
> The speedup depends on the machine, but on SUMMIT, using enough CPUs to saturate the memory bus vs all 6 GPUs the speedup is a function of problem subdomain size. I saw 10x at about 100K equations/process.
> Doing what you want to do is one of the last optimization steps of an already optimized code before entering production. Yours is not even optimized for proper GPU usage yet.
> Also, any specific reason why you are using dgmres and fgmres?
> PETSc has not been designed with multi-threading in mind. You can achieve “overlap” of the two solves by splitting the communicator. But then you need communications to let the two solutions talk to each other.
> Thanks
> Stefano
>> On Aug 4, 2020, at 12:04 PM, nicola varini <nicola.varini at gmail.com <mailto:nicola.varini at gmail.com>> wrote:
>> Dear all, thanks for your replies. The reason why I've asked if it is possible to overlap poisson and ampere is because they roughly
>> take the same amount of time. Please find in attachment the profiling logs for only CPU and only GPU.
>> Of course it is possible to split the MPI communicator and run each solver on different subcommunicator, however this would involve more communication.
>> Did anyone ever tried to run 2 solvers with hyperthreading?
>> Thanks
>> Il giorno dom 2 ago 2020 alle ore 14:09 Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> ha scritto:
>> I suspect that the Poisson and Ampere's law solve are not coupled. You might be able to duplicate the communicator and use two threads. You would want to configure PETSc with threadsafty and threads and I think it could/should work, but this mode is never used by anyone.
>> That said, I would not recommend doing this unless you feel like playing in computer science, as opposed to doing application science. The best case scenario you get a speedup of 2x. That is a strict upper bound, but you will never come close to it. Your hardware has some balance of CPU to GPU processing rate. Your application has a balance of volume of work for your two solves. They have to be the same to get close to 2x speedup and that ratio(s) has to be 1:1. To be concrete, from what little I can guess about your applications let's assume that the cost of each of these two solves is about the same (eg, Laplacians on your domain and the best case scenario). But, GPU machines are configured to have roughly 1-10% of capacity in the GPUs, these days, that gives you an upper bound of about 10% speedup. That is noise. Upshot, unless you configure your hardware to match this problem, and the two solves have the same cost, you will not see close to 2x speedup. Your time is better spent elsewhere.
>> Mark
>> On Sat, Aug 1, 2020 at 3:24 PM Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>> You can use MPI and split the communicator so n-1 ranks create a DMDA for one part of your system and the other rank drives the GPU in the other part. They can all be part of the same coupled system on the full communicator, but PETSc doesn't currently support some ranks having their Vec arrays on GPU and others on host, so you'd be paying host-device transfer costs on each iteration (and that might swamp any performance benefit you would have gotten).
>> In any case, be sure to think about the execution time of each part. Load balancing with matching time-to-solution for each part can be really hard.
>> Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> writes:
>> > Nicola,
>> > This is really viable or practical at this time with PETSc. It is not impossible but requires careful coding with threads, another possibility is to use one half of the virtual GPUs for each solve, this is also not trivial. I would recommend first seeing what kind of performance you can get on the GPU for each type of solve and revist this idea in the future.
>> > Barry
>> >> On Jul 31, 2020, at 9:23 AM, nicola varini <nicola.varini at gmail.com <mailto:nicola.varini at gmail.com>> wrote:
>> >> Hello, I would like to know if it is possible to overlap CPU and GPU with DMDA.
>> >> I've a machine where each node has 1P100+1Haswell.
>> >> I've to resolve Poisson and Ampere equation for each time step.
>> >> I'm using 2D DMDA for each of them. Would be possible to compute poisson
>> >> and ampere equation at the same time? One on CPU and the other on GPU?
>> >> Thanks
>> <out_gpu><out_nogpu>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200812/fcddae6c/attachment.html>
