[petsc-users] Using MatSetValuesBlocked to build Finite Element Matrices with variable coefficients
Nidish nb25 at rice.edu
Sun Aug 9 21:13:34 CDT 2020
I'm trying to write a simple 1D finite element test case (linear
elasticity). It was given in the manual that using an appropriate DM and
calling MatSetValuesBlocked(). I'm however unable to do this for cases
where I want to take runtime inputs for physical constants in the matrices.
One thing that puzzles me is the use of "const PetscInt*" and "const
PetscScalar*" in the declaration of MatSetValuesBlocked(). I can't think
of why this is done (if I am to loop through the elements and call this
function, I don't see why the indices and/or values must be constant).
The declaration I found was:
    PetscErrorCode  <https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode>  MatSetValues  <https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Mat/MatSetValues.html#MatSetValues>(Mat  <https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Mat/Mat.html#Mat>  mat,PetscInt  <https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/PetscInt.html#PetscInt>  m,constPetscInt  <https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/PetscInt.html#PetscInt>  idxm[],PetscInt  <https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/PetscInt.html#PetscInt>  n,constPetscInt  <https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/PetscInt.html#PetscInt>  idxn[],constPetscScalar  <https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/PetscScalar.html#PetscScalar>  v[],InsertMode  <https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/InsertMode.html#InsertMode>  addv)
Here's the DM setup for my code:
    DM mshdm;
    Mater steel = {1.0, 2e11, 7800, 3.0, 400.0};// A structure with
    {Area, Modulus, Density, Length, Force} (runtime vars)
    KSP ksp;
    DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, N, 1, 1, NULL,
    &mshdm);// N is a runtime variable
    DMSetFromOptions(mshdm);
    DMSetUp(mshdm);
    DMSetApplicationContext(mshdm, &steel);  /* User Context */
    KSPCreate(PETSC_COMM_WORLD, &ksp);
    KSPSetDM(ksp, mshdm);
    KSPSetComputeRHS(ksp, RHSFun, &steel);
    KSPSetComputeOperators(ksp, JACFun, &steel);
    KSPSetFromOptions(ksp);
I have no problems with the ComputeRHS function that I wrote, it seems
to work fine. The ComputeOperators function on the other hand is giving
me an "Argument out of range error" when MatSetValues() is called the
second time (for e=1, discovered by debugging). Here's the function
definition:
    PetscErrorCode JACFun(KSP ksp, Mat J, Mat jac, void* ctx)
       Mater* pblm = (Mater*)ctx;
       PetscInt N, ix, n;
       PetscScalar Le;
       PetscErrorCode ierr;
       MatNullSpace nullspc;
       PetscScalar idx[2], idy[2], elstiff[2][2];// idx, idy are ids for
    MatSetValues()
       DM mshdm;
       ierr = KSPGetDM(ksp, &mshdm);
       ierr = DMDAGetInfo(mshdm, NULL, &N, NULL, NULL, &n, NULL, NULL,
    NULL, NULL, NULL, NULL, NULL, NULL);
       DMDAGetCorners(mshdm, &ix, NULL, NULL, &n, NULL, NULL);
       // Construct Element Stiffness
       Le = pblm->L/N;
       elstiff[0][0] = pblm->A*pblm->E/Le;
       elstiff[0][1] = -pblm->A*pblm->E/Le;
       elstiff[1][0] = -pblm->A*pblm->E/Le;
       elstiff[1][1] = pblm->A*pblm->E/Le;
       for (int e=0; e<N-1; ++e) {
         idx[0] = e; idx[1] = e+1;
         idy[0] = e; idy[1] = e+1;
         // This is the version I want to get working, but throws an
    argument out of range error
         MatSetValuesBlocked(jac, 2, (const PetscInt*)idx, 2, (const
    PetscInt*)idy,
                     (const PetscScalar*)elstiff, ADD_VALUES);
         // This version seemed to not construct the correct matrix
    (overlapped elements were added)
         /* MatSetValue(jac, e, e, elstiff[0][0], ADD_VALUES); */
         /* MatSetValue(jac, e, e+1, elstiff[0][1], ADD_VALUES); */
         /* MatSetValue(jac, e+1, e+1, elstiff[1][0], ADD_VALUES); */
         /* MatSetValue(jac, e+1, e+1, elstiff[1][1], ADD_VALUES); */
       MatAssemblyBegin(jac, MAT_FINAL_ASSEMBLY);
       ierr = MatAssemblyEnd(jac, MAT_FINAL_ASSEMBLY);
       // I'm doing a "free-free" simulation, so constraining out the
    nullspace
    MatNullSpaceCreate(PETSC_COMM_WORLD, PETSC_TRUE, 0, NULL, &nullspc);
       MatSetNullSpace(J, nullspc);
       MatNullSpaceDestroy(&nullspc);
       PetscFunctionReturn(0);
I'd be very grateful if someone could point out what's the issue here.
Thank you,
Nidish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200809/33c0c8ef/attachment.html>
