[petsc-users] Parallelizing Nonlinear Algebraic systems without DM
Sun Aug 9 13:43:51 CDT 2020
On Sun, Aug 9, 2020 at 2:37 PM Nidish <nb25 at rice.edu> wrote:
> On 8/9/20 1:45 AM, Barry Smith wrote:
> On Aug 9, 2020, at 1:14 AM, Nidish <nb25 at rice.edu> <nb25 at rice.edu> wrote:
> Hello,
> My question is related to solving a generic nonlinear algebraic system in parallel. I'm using the word generic to point to the fact that the system may or may not be from a finite element/mesh type object - it's just a residual function and a Jacobian function that I can provide.
> I followed the serial example in $PETSC_DIR/src/snes/tutorials/ex1.c pretty much verbatim (albeit with a slightly different objective function whose size can be controlled), and have been trying to extend it to a parallel application (the given example is strictly serial).
> When I run my code in serial everything works well and I get the solution I expect. However, even if I use just two cores, the code starts returning garbage. I had a feeling it has something to do with index ordering, but I want to get this code working without using a DM object. I'm attaching my code with this email.
> TL;DR Version: What modifications must be made in "$PETSC_DIR/src/snes/tutorials/ex1.c" to make it work in Parallel? Is it possible to make minimal modifications to make it run in parallel too?
>   This is wrong:
>   VecGetSize(x, &N);
>   VecGetOwnershipRange(x, &is, &ie);
>   /* VecGetArrayRead(x, &xx); */
>   VecGetArray(x, &xx);
>   for (int i=is; i<ie; ++i)
>   You appear to be trying to mimic a DM example but without a DM.
>    VecGetArray() always returns an array with indices from 0 to VecGetLocalSize()
>    Thus you need to make your loops over local indices, not global indices.
>    In addition you are likely to need "ghost" values of the input vectors. If you are not using DM then you need to have code that determines what ghost values are needed and create a VecScatter to manage communicating those ghost values. Look for examples that use VecScatterBegin in the formfunction routine for how this may be done.
>   Barry
> I wasn't accounting for the ghost values! My compiler wasn't giving
> segfaults when I was accessing the arrays returned by VecGetArray beyond
> the allocation size. (the loop indices was me trying to be smart, I was
> accessing xx by xx[i -is] and so on).
> I've changed my implementation with VecCreateGhost - the code's slightly
> longer but it works, thank you for this!
> I also had another related question about the storage of the arrays from
> VecGetArray() calls. Do these functions allocate new locations in memory
> (and can be expected to be slow)? Even for the ghosted vectors I found
> distinct addresses for the ghost values. I'm assuming the addresses are
> distinct to accommodate for cluster programming, but should a user be
> judicious in calls to VecGetArray() ?
No. For the vectors you are using, this is a no-copy operation.
    Matt
> Thank you,
> Nidish
> Thank You,
> Nidish
> <sness.c>
> Nidish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200809/97079f02/attachment.html>
