[petsc-users] Parallelizing Nonlinear Algebraic systems without DM
    Nidish
    nb25 at rice.edu
    Sun Aug  9 01:14:49 CDT 2020
Hello,
My question is related to solving a generic nonlinear algebraic system
in parallel. I'm using the word generic to point to the fact that the
system may or may not be from a finite element/mesh type object - it's
just a residual function and a Jacobian function that I can provide.
I followed the serial example in $PETSC_DIR/src/snes/tutorials/ex1.c
pretty much verbatim (albeit with a slightly different objective
function whose size can be controlled), and have been trying to extend
it to a parallel application (the given example is strictly serial).
When I run my code in serial everything works well and I get the
solution I expect. However, even if I use just two cores, the code
starts returning garbage. I had a feeling it has something to do with
index ordering, but I want to get this code working without using a DM
object. I'm attaching my code with this email.
TL;DR Version: What modifications must be made in
"$PETSC_DIR/src/snes/tutorials/ex1.c" to make it work in Parallel? Is it
possible to make minimal modifications to make it run in parallel too?
Thank You,
Nidish
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200809/0188f4ed/attachment.bin>
