[petsc-users] Test convergence with non linear preconditioners
Jed Brown jed at jedbrown.org
Wed Aug 5 15:11:53 CDT 2020
Adolfo Rodriguez <adantra at gmail.com> writes:
> Actually I can set the non-linear pc. My problem relates to the convergence
> test. I have not found a way to set the tolerances for the inner problem,
> are they hard coded?
I suggested code to set a custom convergence test.  Nothing is hard-coded.  What have you done?
