[petsc-users] Code (possibly) not running on GPU with CUDA
Wed Aug 5 12:30:55 CDT 2020
On Wed, Aug 5, 2020 at 1:09 PM GIBB Gordon <g.gibb at epcc.ed.ac.uk> wrote:
> Hi,
> I used nvidia-smi before, essentially a kind of ’top’ for nvidia-gpus.
> The log output I get is:
You can see that all flops are done on the GPU by looking at the last
column:
Event                Count      Time (sec)     Flop
     --- Global ---  --- Stage ----  Total   GPU    - CpuToGpu -   -
GpuToCpu - GPU
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen
 Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count   Size
Count   Size  %F
--- Event Stage 0: Main Stage
VecDot                 4 1.0 7.4222e-05 1.0 1.96e+02 1.0 0.0e+00 0.0e+00
0.0e+00  0  8  0  0  0   0  8  0  0  0     3       3      0 0.00e+00    0
0.00e+00 100
VecNorm                1 1.0 5.4168e-05 1.0 7.30e+01 1.0 0.0e+00 0.0e+00
0.0e+00  0  3  0  0  0   0  3  0  0  0     1       1      0 0.00e+00    0
0.00e+00 100
     Matt
> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
> -fCourier9' to print this document            ***
> ---------------------------------------------- PETSc Performance Summary:
>       #                       WARNING!!!                       #
>       #   This code was compiled with a debugging option.      #
>       #   To get timing results run ./configure                #
>       #   using --with-debugging=no, the performance will      #
>       #   be generally two or three times faster.              #
>       #                       WARNING!!!                       #
>       #   This code was compiled with GPU support but you used #
>       #   an MPI that's not GPU-aware, such Petsc had to copy  #
>       #   data from GPU to CPU for MPI communication. To get   #
>       #   meaningfull timing results, please use a GPU-aware   #
>       #   MPI instead.                                         #
> /lustre/home/z04/gpsgibb/TPLS/petsc/share/petsc/examples/src/vec/vec/tests/./ex28
> on a  named r2i7n0 with 1 processor, by gpsgibb Wed Aug  5 18:05:59 2020
> Using Petsc Release Version 3.13.3, Jul 01, 2020
>                          Max       Max/Min     Avg       Total
> Time (sec):           1.566e-01     1.000   1.566e-01
> Objects:              4.400e+01     1.000   4.400e+01
> Flop:                 2.546e+03     1.000   2.546e+03  2.546e+03
> Flop/sec:             1.626e+04     1.000   1.626e+04  1.626e+04
> Memory:               1.438e+05     1.000   1.438e+05  1.438e+05
> MPI Messages:         0.000e+00     0.000   0.000e+00  0.000e+00
> MPI Message Lengths:  0.000e+00     0.000   0.000e+00  0.000e+00
> MPI Reductions:       0.000e+00     0.000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
>                             e.g., VecAXPY() for real vectors of length N
> --> 2N flop
>                             and VecAXPY() for complex vectors of length N
> --> 8N flop
> Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages
> ---  -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total    Count
> %Total     Avg         %Total    Count   %Total
>  0:      Main Stage: 1.5657e-01 100.0%  2.5460e+03 100.0%  0.000e+00
> 0.0%  0.000e+00        0.0%  0.000e+00   0.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
>    Count: number of times phase was executed
>    Time and Flop: Max - maximum over all processors
>                   Ratio - ratio of maximum to minimum over all processors
>    Mess: number of messages sent
>    AvgLen: average message length (bytes)
>    Reduct: number of global reductions
>    Global: entire computation
>    Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
>       %T - percent time in this phase         %F - percent flop in this
> phase
>       %M - percent messages in this phase     %L - percent message lengths
> in this phase
>       %R - percent reductions in this phase
>    Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over
> all processors)
>    GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU
> time over all processors)
>    CpuToGpu Count: total number of CPU to GPU copies per processor
>    CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per
> processor)
>    GpuToCpu Count: total number of GPU to CPU copies per processor
>    GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per
> processor)
>    GPU %F: percent flops on GPU in this event
>       #                       WARNING!!!                       #
> GpuToCpu - GPU
> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count   Size   Count
>   Size  %F
> 0.00e+00 100
> 0.00e+00 100
> VecSet                83 1.0 9.0480e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> VecAssemblyBegin       1 1.0 2.7206e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> VecAssemblyEnd         1 1.0 2.6403e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> VecSetRandom           1 1.0 1.5260e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> VecReduceArith        52 1.0 1.1307e-03 1.0 2.28e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00  1 89  0  0  0   1 89  0  0  0     2       2      2 4.00e-04    0
> 0.00e+00 100
> VecReduceComm          4 1.0 3.4969e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> VecReduceBegin         1 1.0 2.5639e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> VecReduceEnd           1 1.0 2.5495e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> VecCUDACopyTo          2 1.0 1.7550e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      2 4.00e-04    0
> 0.00e+00  0
> VecCUDACopyFrom       42 1.0 3.7747e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00   42
> 8.40e-03  0
> Memory usage is given in bytes:
> Object Type          Creations   Destructions     Memory  Descendants' Mem.
> Reports information only for process 0.
>               Vector    42             42        75264     0.
>          PetscRandom     1              1          646     0.
>               Viewer     1              0            0     0.
> Average time to get PetscTime(): 3.67989e-08
> #PETSc Option Table entries:
> -log_view
> -use_gpu_aware_mpi 0
> -vec_type cuda
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure options: CC=nvcc FC=mpif90 CXX=mpicxx
> --prefix=/lustre/home/z04/gpsgibb/TPLS/petsc --with-cudac=nvcc
> --with-cuda=1 --with-mpi-dir= --with-batch
> Libraries compiled on 2020-07-31 14:46:25 on r2i7n0
> Machine characteristics:
> Linux-4.18.0-147.8.1.el8_1.x86_64-x86_64-with-centos-8.1.1911-Core
> Using PETSc directory: /lustre/home/z04/gpsgibb/TPLS/petsc
> Using PETSc arch:
> Using C compiler: nvcc  -g
> -I/lustre/home/z04/gpsgibb/TPLS/petsc-3.13.3/include
> Using Fortran compiler: mpif90  -Wall -ffree-line-length-0
> -Wno-unused-dummy-argument -g
> Using include paths: -I/lustre/home/z04/gpsgibb/TPLS/petsc/include
> -I/lustre/sw/nvidia/hpcsdk/Linux_x86_64/cuda/10.2/include
> Using C linker: nvcc
> Using Fortran linker: mpif90
> Using libraries: -L/lustre/home/z04/gpsgibb/TPLS/petsc/lib
> -L/lustre/home/z04/gpsgibb/TPLS/petsc/lib -lpetsc
> -L/lustre/sw/intel/compilers_and_libraries_2019.0.117/linux/mkl
> -L/lustre/sw/nvidia/hpcsdk/Linux_x86_64/cuda/10.2/lib64
> -L/lustre/home/z04/gpsgibb/TPLS/petsc-3.13.3/lib
> -L/opt/hpe/hpc/mpt/mpt-2.22/lib
> -L/lustre/sw/nvidia/hpcsdk/Linux_x86_64/20.5/math_libs/10.2/lib64
> -L/lustre/sw/gcc/6.3.0/lib/gcc/x86_64-pc-linux-gnu/6.3.0
> -L/lustre/sw/gcc/6.3.0/lib64
> -L/lustre/sw/intel/compilers_and_libraries_2019.0.117/linux/mkl/lib/intel64
> -L/lustre/sw/nvidia/hpcsdk/Linux_x86_64/cuda/10.2/bin
> -L/lustre/sw/gcc/6.3.0/lib -lmkl_intel_lp64 -lmkl_core -lmkl_sequential
> -lpthread -lX11 -lcufft -lcublas -lcudart -lcusparse -lcusolver -lcuda
> -lmpi++ -lmpi -lstdc++ -ldl -lpthread -lmpi -lgfortran -lm -lgfortran -lm
> -lgcc_s -lquadmath -lstdc++ -ldl
>       #                       WARNING!!!                       #
>       #   MPI instead.                                         #
>       #                       WARNING!!!                       #
> Dr Gordon P S Gibb
> EPCC, The University of Edinburgh
> Tel: +44 131 651 3459
> On 5 Aug 2020, at 17:58, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 5, 2020 at 12:47 PM GIBB Gordon <g.gibb at epcc.ed.ac.uk> wrote:
>> Hi Matt,
>> It runs, however it doesn’t produce any output, and I have no way of
>> checking to see if it actually ran on the GPU. It was run with:
>> srun -n 1 ./ex28 -vec_type cuda -use_gpu_aware_mpi 0
> 1) How did you check last time?
> 2) You can check using -log_view
>   Thanks,
>      Matt
>> Cheers,
>> Gordon
>> Dr Gordon P S Gibb
>> On 5 Aug 2020, at 17:10, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Aug 5, 2020 at 11:24 AM GIBB Gordon <g.gibb at epcc.ed.ac.uk> wrote:
>>> Hi,
>>> I’ve built PETSc with NVIDIA support for our GPU machine (
>>> https://cirrus.readthedocs.io/en/master/user-guide/gpu.html), and then
>>> compiled our executable against this PETSc (using version 3.13.3). I should
>>> add that the MPI on our system is not GPU-aware so I have to use -use_gpu_aware_mpi
>>> 0
>>> When running this, in the .petscrc I put
>>> -dm_vec_type cuda
>>> -dm_mat_type aijcusparse
>>> as is suggested on the PETSc GPU page (
>>> https://www.mcs.anl.gov/petsc/features/gpus.html) to enable CUDA for
>>> DMs (all our PETSc data structures are with DMs). I have also ensured I'm
>>> using the jacobi preconditioner so that it definitely runs on the GPU
>>> (again, according to the PETSc GPU page).
>>> When I run this, I note that the GPU seems to have memory allocated on
>>> it from my executable, however seems to be doing no computation:
>>> Wed Aug  5 13:10:23 2020
>>> | NVIDIA-SMI 440.64.00    Driver Version: 440.64.00    CUDA Version:
>>> 10.2     |
>>> | GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile
>>> Uncorr. ECC |
>>> | Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util
>>> Compute M. |
>>> |   0  Tesla V100-SXM2...  On   | 00000000:1A:00.0 Off |
>>>   Off |
>>> | N/A   43C    P0    64W / 300W |    490MiB / 16160MiB |      0%
>>> Default |
>>> | Processes:                                                       GPU
>>> Memory |
>>> |  GPU       PID   Type   Process name
>>> Usage      |
>>> |    0     33712      C   .../z04/gpsgibb/TPLS/TPLS-GPU/./twophase.x
>>> 479MiB |
>>> I then ran the same example but without the -dm_vec_type cuda,
>>> -dm_mat_type aijcusparse arguments, and I found the same behaviour (479MB
>>> allocated on the GPU, 0% GPU utilisation).
>>> In both cases the runtime of the example are near identical, suggesting
>>> that both are essentially the same run.
>>> As a further test I compiled PETSc without CUDA support and ran the same
>>> example again, and found the same runtime as with the GPUs, and (as
>>> expected) no GPU memory allocated. I then tried to run the example with the -dm_vec_type
>>> cuda, -dm_mat_type aijcusparse arguments and it ran without complaint.
>>> I would have expected it to throw an error or at least a warning if invalid
>>> arguments were passed to it.
>>> All this suggests to me that PETSc is ignoring my requests to use the
>>> GPUs. For the GPU-aware PETSc it seems to allocate memory on the GPUs but
>>> perform no calculations on them, regardless of whether I requested it to
>>> use the GPUs or not. On non-GPU-aware PETSc it accepts my requests to use
>>> the GPUs, but does not throw an error.
>>> What am I doing wrong?
>> Lets step back to a simpler thing so we can make sure your configuration
>> is correct. Can you run the 2_cuda test from
>> src/vec/vec/tests/ex28.c ? Does it execute on your GPU?
>>   Thanks,
>>     Matt
>>> Thanks in advance,
>>> Gordon
>>> Dr Gordon P S Gibb
>>> The University of Edinburgh is a charitable body, registered in
>>> Scotland, with registration number SC005336.
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200805/d8c96851/attachment-0001.html>
