[petsc-users] SUPERLU_DIST in single precision
flw at rzg.mpg.de flw at rzg.mpg.de
Mon Aug 3 10:45:00 CDT 2020
Hi Barry,
Thanks for the branch (and thanks to Sherry as well). I tried to use
the configure example " arch-ci-linux-intel-mkl-single.py" (adding the
--with-batch flag, since I am running on a cluster), but I get the
following error message:
TESTING: check from
config.libraries(config/BuildSystem/config/libraries.py:157)
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
Downloaded ptscotch could not be used. Please check install in
/u/flw/petsc-hash-pkgs/073aec050
(see configure1.log)
Next I tried a minimalistic version using Intel MPI compilers:
./configure --download-superlu_dist --download-metis
--download-parmetis --download-ptscotch  --with-precision=single
--with-batch --with-fc=mpiifort --with-cc=mpiicc --with-cxx=mpiicpc
There I got the following error:
===============================================================================        Compiling and installing SUPERLU_DIST; this may take several minutes        ===============================================================================
for details):
Error running make on  SUPERLU_DIST
(see configure2.log)
Next I tried
--with-batch
--with-mpi-dir=/mpcdf/soft/SLE_12/packages/x86_64/intel_parallel_studio/2018.4/impi/2018.4.274/intel64
Same error message (see configure3.log)
It seems that there is something going on with mkl in case I want to
use Intel compilers for C and C++ (compiling with gcc and g++ seems to
work )
Do you know what is going on there?  (I am running on the Draco
cluster, if that helps
(https://www.mpcdf.mpg.de/services/computing/draco))
Best regards,
Felix
Zitat von Barry Smith <bsmith at petsc.dev>:
> Felix,
>     The branch is ready. Just use
>     git checkout barry/2020-07-28/superlu_dist-single
> and whatever else you use
>   Barry
>   It will automatically get the needed branch of SuperLU_DIST that
> Sherry prepared.
>> On Jul 27, 2020, at 2:10 PM, flw at rzg.mpg.de wrote:
>> Hi Shery,
>> Yes, ideally we would like to compile PETSc in single precision and
>> simply run a single precision version of SUPERLU_DIST just like
>> e.g. MUMPS.
>> Best regards and thanks,
>> Felix
>> Zitat von "Xiaoye S. Li" <xsli at lbl.gov>:
>>> Barry,
>>> I have a branch 'Mixed-precision' working with single precision FP32. I
>>> assume Felix wants to use superlu_dist from petsc.  How do you want to
>>> incorporate it in petsc?
>>> https://github.com/xiaoyeli/superlu_dist
>>> PS1:  in this version, FP32 only works on CPU.  FP64 and complex-FP64 all
>>> work on GPU.
>>> PS2: currently there is no mixed-precision yet, but it is the branch we are
>>> adding mix-prec support.  Will take a while before merging to master.
>>> Sherry
>>> On Wed, Jul 22, 2020 at 6:04 AM <flw at rzg.mpg.de> wrote:
>>>> Hi Barry,
>>>> for now I just want to run everything in single on CPUs only with
>>>> SUPERLU_DIST. Maybe we will also incorporate GPUs in the future, but
>>>> there are no immediate plans yet. So if you could provide the support,
>>>> that would be awesome.
>>>> Best regards,
>>>> Felix
>>>> > Felix,
>>>> >     What are your needs, do you want this for CPUs or for GPUs?  Do
>>>> > you wish to run all your code in single precision or just the
>>>> > SuperLU_Dist solver while the rest of your code double?
>>>> >     If you want to run everything on CPUs using single precision
>>>> > then adding the support is very easy, we can provide that for you
>>>> > any time. The other cases will require more thought.
>>>> >     Barry
>>>> >> On Jul 21, 2020, at 8:58 AM, flw at rzg.mpg.de wrote:
>>>> >> Dear PETSc support team,
>>>> >> some time ago you told me that you are planning on releasing a
>>>> >> version that supports SUPERLU_DIST in single-precision soon. Can
>>>> >> you tell me roughly what time frame you had in mind?
>>>> >> Best regards,
>>>> >> Felix
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200803/ce02cab5/attachment-0003.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200803/ce02cab5/attachment-0004.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200803/ce02cab5/attachment-0005.ksh>
