[petsc-users] Problems about tolerances set in TS
Yingjie Wu
yjwu16 at gmail.com
Thu Apr 30 06:22:54 CDT 2020
I'm sorry for dropping the mailing list in previous mail.
I went over the code and made sure I didn't set the maximum number or final
time to zero for TS. And I found a very similar example in
petsc/src/ts/tutorials/ex8.c.
I made the following changes:
1. TSSetMaxStepRejections
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSetMaxStepRejections.html#TSSetMaxStepRejections>(ts,10);
-> TSSetMaxStepRejections
(ts,*0*);
2. TSSetMaxSNESFailures
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSetMaxSNESFailures.html#TSSetMaxSNESFailures>(ts,-1);
-> TSSetMaxSNESFailures
(ts,*0*);
These changes adjust the Rejections and SNESFailures to the default state.
Then test the following commands: mpiexec -n 1 ./ex8 -ts_atol 1e-2 -ts_rtol
1e-2 -ts_max_time 15 -ts_type arkimex -ts_arkimex_type 2e -problem_type
orego -ts_arkimex_initial_guess_extrapolate 0
-ts_adapt_time_step_increase_delay 4 -ts_monitor -snes_monitor
-snes_converged_reason
The output on the screen is:
7 TS dt 6.86235 time 3.47215
0 SNES Function norm 2.000433909025e-01
1 SNES Function norm 1.991123862317e-01
2 SNES Function norm 1.975627926780e-01
3 SNES Function norm 1.946057832068e-01
4 SNES Function norm 1.900556025613e-01
5 SNES Function norm 1.840284735193e-01
6 SNES Function norm 1.767727556549e-01
7 SNES Function norm 1.685779659858e-01
8 SNES Function norm 1.597281513554e-01
9 SNES Function norm 1.504796576996e-01
10 SNES Function norm 1.410521859210e-01
11 SNES Function norm 1.316269768177e-01
12 SNES Function norm 1.223486899848e-01
13 SNES Function norm 1.127512649756e-01
14 SNES Function norm 1.020567711262e-01
15 SNES Function norm 8.979527463515e-02
16 SNES Function norm 7.508859688939e-02
17 SNES Function norm 7.355450203066e-02
18 SNES Function norm 2.927834451754e-06
19 SNES Function norm 4.107891676938e-15
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 19
0 SNES Function norm 1.349799651143e-01
1 SNES Function norm 1.333235099246e-01
2 SNES Function norm 1.314928290684e-01
3 SNES Function norm 1.295004620848e-01
4 SNES Function norm 1.273561109747e-01
5 SNES Function norm 1.250670006052e-01
6 SNES Function norm 1.226381484156e-01
7 SNES Function norm 1.200604281861e-01
8 SNES Function norm 1.173313259697e-01
9 SNES Function norm 1.144768440013e-01
10 SNES Function norm 1.141593852677e-01
11 SNES Function norm 1.121207287132e-01
12 SNES Function norm 1.087640960519e-01
13 SNES Function norm 1.044397486143e-01
14 SNES Function norm 9.944173247962e-02
15 SNES Function norm 9.401107464556e-02
16 SNES Function norm 8.834148211449e-02
17 SNES Function norm 8.258574767211e-02
18 SNES Function norm 7.686203062639e-02
19 SNES Function norm 7.076716424793e-02
20 SNES Function norm 6.389435437215e-02
21 SNES Function norm 5.587963465672e-02
22 SNES Function norm 4.597296586383e-02
23 SNES Function norm 3.649153890859e-02
24 SNES Function norm 1.112024137036e-06
25 SNES Function norm 1.368410750160e-14
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 25
8 TS dt 7.74608 time 10.3345
0 SNES Function norm 2.851716167826e-01
1 SNES Function norm 2.827877334190e-01
2 SNES Function norm 2.803985313138e-01
3 SNES Function norm 2.780035928632e-01
4 SNES Function norm 2.756024874780e-01
5 SNES Function norm 2.731947705882e-01
6 SNES Function norm 2.707799825757e-01
7 SNES Function norm 2.683576476261e-01
8 SNES Function norm 2.659272724924e-01
9 SNES Function norm 2.634883451605e-01
10 SNES Function norm 2.610403334061e-01
11 SNES Function norm 2.585826832306e-01
12 SNES Function norm 2.561148171641e-01
13 SNES Function norm 2.536361324179e-01
14 SNES Function norm 2.511459988719e-01
15 SNES Function norm 2.486437568755e-01
16 SNES Function norm 2.461287148411e-01
17 SNES Function norm 2.461031613348e-01
18 SNES Function norm 2.455705375830e-01
19 SNES Function norm 2.445878823765e-01
20 SNES Function norm 2.432027776816e-01
21 SNES Function norm 2.414549711706e-01
22 SNES Function norm 2.393776915919e-01
23 SNES Function norm 2.369987079777e-01
24 SNES Function norm 2.343411787922e-01
25 SNES Function norm 2.314243298882e-01
26 SNES Function norm 2.282639927909e-01
27 SNES Function norm 2.248730282013e-01
28 SNES Function norm 2.212616539034e-01
29 SNES Function norm 2.174376914167e-01
30 SNES Function norm 2.134067415679e-01
31 SNES Function norm 2.091722954520e-01
32 SNES Function norm 2.047263028819e-01
33 SNES Function norm 2.000468148325e-01
34 SNES Function norm 1.951751560520e-01
35 SNES Function norm 1.946187817680e-01
36 SNES Function norm 1.912149142781e-01
37 SNES Function norm 1.856377137631e-01
38 SNES Function norm 1.784574187852e-01
39 SNES Function norm 1.701485679136e-01
40 SNES Function norm 1.611004146461e-01
41 SNES Function norm 1.516277627394e-01
42 SNES Function norm 1.419813980321e-01
43 SNES Function norm 1.323577340278e-01
44 SNES Function norm 1.224961331340e-01
45 SNES Function norm 1.115622228182e-01
46 SNES Function norm 9.910072225366e-02
47 SNES Function norm 8.425984823824e-02
48 SNES Function norm 6.475245098809e-02
49 SNES Function norm 2.817391391875e-02
50 SNES Function norm 2.187931938195e-06
Nonlinear solve did not converge due to DIVERGED_MAX_IT iterations 50
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR:
[0]PETSC ERROR: TSStep has failed due to DIVERGED_STEP_REJECTED
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.12.4, unknown
[0]PETSC ERROR: ./ex8 on a arch-linux2-c-debug named ubuntu103 by wuyj Thu
Apr 30 10:40:07 2020
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-mpich --download-fblaslapack
[0]PETSC ERROR: #1 TSStep() line 3596 in
/home/wuyj/petsc/src/ts/interface/ts.c
[0]PETSC ERROR: #2 TSSolve() line 3768 in
[0]PETSC ERROR: #3 main() line 416 in ex8.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -problem_type orego
[0]PETSC ERROR: -snes_converged_reason
[0]PETSC ERROR: -snes_monitor
[0]PETSC ERROR: -ts_adapt_time_step_increase_delay 4
[0]PETSC ERROR: -ts_arkimex_initial_guess_extrapolate 0
[0]PETSC ERROR: -ts_arkimex_type 2e
[0]PETSC ERROR: -ts_atol 1e-2
[0]PETSC ERROR: -ts_max_time 15
[0]PETSC ERROR: -ts_monitor
[0]PETSC ERROR: -ts_rtol 1e-2
[0]PETSC ERROR: -ts_type arkimex
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 91) - process 0
At the eighth time step, the maximum iterations number of SNES resulting in
the failure of the time step calculation, the program reported errors.
Then I tested the following commands: mpiexec -n 1 ./ex8 -ts_atol 1e-2
-ts_rtol 1e-2 -ts_max_time 15 -ts_type arkimex -ts_arkimex_type 2e
-problem_type orego -ts_arkimex_initial_guess_extrapolate 0
-ts_adapt_time_step_increase_delay 4 -snes_monitor
-snes_converged_reason *-ts_monitor
-ts_error_if_step_fails 0 *
The output in screen:
9 TS dt 1.93652 time 10.3345
steps 9 (1 rejected, 1 SNES fails), ftime 10.3345, nonlinits 126, linits 126
Although the program did not report errors, but end the operation after the
eighth time step, and output results.
Note that the program did not reach the set termination time (-ts_max_time
15).
This indicates that the command *-ts_error_if_step_fails 0*, while avoiding
program errors, ends TS solving after a failed SNES and does not proceed to
the next step.
And I'd like to continue the next step with the result after a failed SNES
time step (although this result is not converged).
In addition, I would like to ask the function of these two functions:
and
I looked it up in manualpages/singleindex.html, but there were very few
explanations, and I still didn't quite understand the meaning of Rejection
and SNES Failures variables.
Thank you very much for your reply and I hope you can help me to answer
these questions.
Yingjie
Zhang, Hong <hongzhang at anl.gov> 于2020年4月30日周四 下午1:22写道:
> Please do not drop the mailing list when replying.
> It looks like the max steps or the final time has been set to zero for TS.
> You might want to check your code to see if the TS settings are correct or
> if they are overwritten in some callback functions by mistake.
> Hong (Mr.)
> > On Apr 29, 2020, at 10:16 PM, Yingjie Wu <yjwu16 at gmail.com> wrote:
> > Command: mpiexec -n 1 ./SGts -snes_fd -pc_type lu
> -ts_error_if_step_fails 0 -ts_monitor -snes_monitor \
> > -ksp_monitor \
> > -ksp_converged_reason \
> > -snes_converged_reason \
> > -snes_rtol 1.e-2 \
> > -ksp_rtol 1.e-5 \
> > -snes_max_it 2 \
> > -snes_view
> > Output: Timestep 0:
> > CurrentTime 0.:
> > 0 TS dt 1. time 0.
> > iter = 0, SNES Function norm 245.204
> > 0 SNES Function norm 2.452043863308e+02
> > 0 KSP Residual norm 1.641317090793e+04
> > 1 KSP Residual norm 2.717662845608e-10
> > Linear solve converged due to CONVERGED_RTOL iterations 1
> > iter = 1, SNES Function norm 170.58
> > 1 SNES Function norm 1.705802879797e+02
> > 0 KSP Residual norm 1.146216600447e+04
> > 1 KSP Residual norm 3.272076151518e-11
> > iter = 2, SNES Function norm 140.625
> > 2 SNES Function norm 1.406249065994e+02
> > Nonlinear solve did not converge due to DIVERGED_MAX_IT iterations 2
> > SNES Object: 1 MPI processes
> > type: newtonls maximum iterations=2, maximum function
> evaluations=-1530494976
> > tolerances: relative=0.01, absolute=1e-50, solution=1e-08
> > total number of linear solver iterations=2
> > total number of function evaluations=1063
> > norm schedule ALWAYS
> > Jacobian is built using finite differences one column at a time
> > SNESLineSearch Object: 1 MPI processes
> > type: bt
> > interpolation: cubic
> > alpha=1.000000e-04
> > maxstep=1.000000e+08, minlambda=1.000000e-12
> > tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
> > maximum iterations=40
> > KSP Object: 1 MPI processes
> > type: gmres
> > restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> > happy breakdown tolerance 1e-30
> > maximum iterations=10000, initial guess is zero
> > tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> > left preconditioning
> > using PRECONDITIONED norm type for convergence test
> > PC Object: 1 MPI processes
> > type: lu
> > out-of-place factorization
> > tolerance for zero pivot 2.22045e-14
> > matrix ordering: nd
> > factor fill ratio given 5., needed 2.84376
> > Factored matrix follows:
> > Mat Object: 1 MPI processes
> > type: seqaij rows=528, cols=528
> > package used to perform factorization: petsc
> > total: nonzeros=7863, allocated nonzeros=7863
> > total number of mallocs used during MatSetValues calls=0
> > not using I-node routines
> > linear system matrix = precond matrix:
> > total: nonzeros=2765, allocated nonzeros=5280
> > Timestep 1:
> > CurrentTime 0.:
> > 1 TS dt 1. time 0.
> > Number of timesteps = 1 final time 0.00e+00
> > After the first time step, the program directly ends the TS solution
> process. I've set up 50 time steps, so the program is not running properly.
> > Although the program accepted that first time step SNES did not achieve
> convergence, and there is no error information, but did not continue to go
> to the next time step calculation, chose to end the program. I hope that
> when the SNES not converge at a certain time step and reaches the set
> maximum number SNES iteration steps, it can go to the next time step
> calculation.
> > I am looking forward to your suggestion.
> > Thanks,
> > Yingjie
> > Zhang, Hong <hongzhang at anl.gov> 于2020年4月29日周三 下午11:26写道:
> > Please send the list of your command line options and the screen output
> with -ts_monitor.
> > Hong (Mr.)
> >> On Apr 28, 2020, at 11:00 PM, Yingjie Wu <yjwu16 at gmail.com> wrote:
> >> Thank you very much for your reply.
> >> I tried both switches, but unfortunately they didn't seem to meet my
> needs.
> >> -ts_adapt_always_accept
> >> The switch doesn't seem to work, reporting errors
> >> when the maximum number of steps is reached without convergence, then
> the program exits.
> >> -ts_error_if_step_fails 0 This switch accepts the
> non-convergence time step and outputs the result, but does not continue
> into the next time step calculation (
> >> The time step hasn't reached the maximum time step I set
> >> And I wonder if the variable behind this switch is optional? What does
> it mean?
> >> I hope to achieve in the case of non-convergence Newton step( for
> example, the maximum number of Newton iteration steps reached -snes_max_it
> 50), can go in the next time step calculation.
> >> Thanks,
> >> Yingjie
> >> Zhang, Hong <hongzhang at anl.gov> 于2020年4月28日周二 下午10:51写道:
> >> You might want to find out why the nonlinear solver does not converge
> first. If you have a hand-written Jacobian, you can validate it with
> -snes_test_jacobian 1 (for a small test case).
> >> Hong (Mr.)
> >> > On Apr 28, 2020, at 8:21 AM, Yingjie Wu <yjwu16 at gmail.com> wrote:
> >> > Dear PETSc developers
> >> > Hi,
> >> > I have recently used TS to solve nonlinear equations with time terms.
> since the convergence of my model is not very good, i would like to set to
> iterative fixed nonlinear steps per time step. If the problem does not meet
> the SNES convergence criteria after fixed number of nonlinear steps , then
> go to the next time step calculation. I tried -snes_max_it , but didn't
> achieve the effect I wanted, and the program stopped after iterating the
> fixed number of steps. How should I set up in the program?
> >> > Thanks,
> >> > Yingjie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200430/39c5593a/attachment-0001.html>
