[petsc-users] Reuse compiled packages
san.temporal at gmail.com
Sun Apr 26 10:34:00 CDT 2020
So the point is I was relying on a flag that is possibly non-working.
I confirm that, given the line that I had previously used
./configure PETSC_ARCH=arch-pkgs --prefix=$HOME/petsc-pkgs ...
--download-fblaslapack --download-mumps --download-scalapack ...
(I didn't need to do this again), I could reuse my compiled packages with
--with-fblaslapack-dir=/home/santiago/usr/local
--with-mumps-dir=$HOME/petsc-pkgs --with-scalapack-dir=$HOME/petsc-pkgs ...
and it worked fine. (I assume in your second ./configure command you meant
PETSC_ARCH=arch-pkgs, as I used).
This used previously compiled versions of fblaslapack, mumps and scalapack:
BlasLapack:
Library: -Wl,-rpath,/home/santiago/usr/local/lib
-L/home/santiago/usr/local/lib -lflapack -lfblas
uses 4 byte integers
MPI:
Version: 3
Mpiexec: mpiexec
OMPI_VERSION: 2.1.1
pthread:
fblaslapack:
cmake:
Version: 3.10.2
/usr/bin/cmake
X:
Library: -lX11
regex:
MUMPS:
Version: 5.2.1
Includes: -I/home/santiago/usr/local/include
-L/home/santiago/usr/local/lib -lcmumps -ldmumps -lsmumps -lzmumps
-lmumps_co mmon -lpord
scalapack:
-L/home/santiago/usr/local/lib -lscalapack
I guess this can also be used to compile fblaslapack, mumps, scalapack (all
the same versions as I am working with now), with whatever options I want,
and then use these to configure PETSc.
Thanks.
Santiago
On Sat, Apr 25, 2020 at 11:54 AM Satish Balay <balay at mcs.anl.gov> wrote:
> On Sat, 25 Apr 2020, san.temporal at gmail.com wrote:
> > Hi all,
> > While compiling 3.13.0 I have previously run
> > $ ./configure ... --download-mumps --download-scalapack ...
> > and now I have
> > $ ls arch-linux2-c-opt/externalpackages/
> > fblaslapack-3.4.2/ petsc-pkg-fblaslapack-e8a03f57d64c/
> > petsc-pkg-mumps-d1a5c931b762/ petsc-pkg-scalapack-3ba8f741b828/
> > Are there any flags for configure that let me reuse the compiled
> versions I
> > have?
> By default - if you use the same PETSC_ARCH and same download options -
> the installed packages won't get rebuilt.
> However - if you want to have a single install of externalpackages shared
> across multiple petsc builds - its best
> to install externalpackages in a prefix location. And then use this for
> subsequent builds.
> ./configure PETSC__ARCH=arch-use-pkgs --with-mumps-dir=$HOME/petsc-pkgs
> --with-packages-search-path options hardly ever gets used - so will have
> to check if its broken or not.
> Satish
> > I did not try separate --with-mumps-include and --with-mumps-lib, as I
> > think there should be a more rational approach
> > All the combinations I tried failed (<loc> stands for the current dir):
> > 1.
> > --with-packages-search-path=<loc> --with-mumps
> > (what I would like best, as it would allow for a single search path for
> all
> > external packages already compiled)
> > 2.
> > --with-packages-search-path=<loc>/arch-linux2-c-opt --with-mumps
> > 3.
> > --with-packages-search-path=<loc>/arch-linux2-c-opt/externalpackages
> > --with-mumps
> > 4.
> --with-packages-search-path=<loc>/arch-linux2-c-opt/externalpackages/petsc-pkg-mumps-d1a5c931b762
> > --with-mumps
> > 5.
> --with-mumps-dir=<loc>/arch-linux2-c-opt/externalpackages/petsc-pkg-mumps-d1a5c931b762
> > --with-mumps
> > Note that the directory is well written. If that weren't the case,
> > --with-packages-search-path would simply not find it, but
> --with-mumps-dir
> > would complain.
> > Thanks in advance,
> > Santiago
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200426/cc524252/attachment-0001.html>
