[petsc-users] makefile changes since release 12
Fri Apr 24 10:27:31 CDT 2020
On Fri, 24 Apr 2020, Jed Brown wrote:
> I'd say yes, that's the right thing.  These are vestigial remnants of
> the legacy make system.
> I believe PETSc doesn't use this anywhere internally, and thus can be
> removed.  I don't know if the following patch would break any existing
> correct usage.
> diff --git i/lib/petsc/conf/variables w/lib/petsc/conf/variables
> index a7de68e2ae..07bc4254c9 100644
> --- i/lib/petsc/conf/variables
> +++ w/lib/petsc/conf/variables
> @@ -36,13 +36,13 @@ F_SH_LIB_PATH	= ${PETSC_F_SH_LIB_PATH}
>  PSOURCEC  = $(SOURCEC:%=`pwd`/%)
>  PSOURCECXX= $(SOURCECXX:%=`pwd`/%)
>  PSOURCECU = $(SOURCECU:%=`pwd`/%)
> -PETSC_COMPILE           = ${PCC} -c ${PCC_FLAGS} ${PFLAGS} ${CCPPFLAGS}  ${PSOURCEC}
> +PETSC_COMPILE           = ${PCC} -c ${PCC_FLAGS} ${PFLAGS} ${CCPPFLAGS}
>  PETSC_CCOMPILE          = ${CC} -c ${CC_FLAGS} ${CPPFLAGS} ${PETSC_CC_INCLUDES}
> -PETSC_CXXCOMPILE        = ${CXX} -c ${CXX_FLAGS} ${CXXFLAGS} ${CXXCPPFLAGS}  ${PSOURCECXX}
> +PETSC_CXXCOMPILE        = ${CXX} -c ${CXX_FLAGS} ${CXXFLAGS} ${CXXCPPFLAGS}
>  PETSC_COMPILE_SINGLE    = ${PCC} -o $*.o -c ${PCC_FLAGS} ${PFLAGS} ${CCPPFLAGS}
>  PETSC_CXXCOMPILE_SINGLE = ${CXX} -o $*.o -c ${CXX_FLAGS} ${CXXFLAGS} ${CXXCPPFLAGS}
> -PETSC_FCOMPILE          = ${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS}  ${SOURCEF} ${SOURCEF90}
> -PETSC_CUCOMPILE         = ${CUDAC} ${CUDAC_FLAGS} -c --compiler-options="${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}" ${PSOURCECU}
> +PETSC_FCOMPILE          = ${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS}
> +PETSC_CUCOMPILE         = ${CUDAC} ${CUDAC_FLAGS} -c --compiler-options="${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}"
>  PETSC_CUCOMPILE_SINGLE  = ${CUDAC} -o $*.o ${CUDAC_FLAGS} -c --compiler-options="${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}"
>  # define OBJSC OBJSCXX and OBJSF OBJSCU
I think Matt's approach is good for maint. Wrt cleanup - likely we just need PETSC_COMPILE_SINGLE and related stuff and not PETSC_COMPILE and related stuff
> Crossing over to dev discussion, I wish we could make these names more
> standard, like the following predefined ones (see `make -p`).
> COMPILE.F = $(FC) $(FFLAGS) $(CPPFLAGS) $(TARGET_ARCH) -c
> %.o: %.F
> #  recipe to execute (built-in):
>         $(COMPILE.F) $(OUTPUT_OPTION) $<
> LINK.F = $(FC) $(FFLAGS) $(CPPFLAGS) $(LDFLAGS) $(TARGET_ARCH)
> %: %.F
>         $(LINK.F) $^ $(LOADLIBES) $(LDLIBS) -o $@
> So we could define PETSC_COMPILE.F, PETSC_LINK.F, etc., and a user could write
> COMPILE.F = PETSC_COMPILE.F
> if all their *.F sources use PETSc, in which case all the standard rules
> would work.  Or, they could use PETSc-enabled build only for a subset of
> their sources:
> $(SOURCES_USING_PETSC:%.F=%.o) : %.o : %.F
> 	$(PETSC_COMPILE.F) $(OUTPUT_OPTION) $<
Hm - I thought we were going to leave the current rules file to be portable - and have gnumakefile syntax available via share/petsc/Makefile.user
Hence we have similar rules [as above] in lib/petsc/conf/test
Satish
> Aldo Bonfiglioli <aldo.bonfiglioli at unibas.it> writes:
> > Hi there,
> > the makefile I have been using for ages (up to 11.4) now fails with 12.5.
> > I noticed that there have been several changes in
> > include $(PETSC_DIR)/lib/petsc/conf/variables
> > include $(PETSC_DIR)/lib/petsc/conf/rules
> > btw. the two aforementioned versions.
> > If I'm not wrong, *.F files should now be compiled with:
> >> .F.o .F90.o .F95.o:
> >>         ${PETSC_FCOMPILE} -o $@ $<
> > However,  in ${PETSC_FCOMPILE} there are also my ${SOURCEF} fortran sources,
> > so that I get the following compilation error:
> >> gfortran -c -fPIC -Wall -ffree-line-length-0
> >> -Wno-unused-dummy-argument -g -I../../include/ -I.
> >> -I/home/abonfi/src/petsc-3.12.5/include
> >> -I/home/abonfi/src/petsc-3.12.5/linux_gnu/include     getidx.f
> >> ApplicationFunction.F ApplicationFunction_t.F bndry_iset.F
> >> JacobianBoundaryConditions.F RHSFunction.F RHSFunction_t.F
> >> RHSJacobian.F RHSJacobian_t.F blockdata.f bndvflx.F clearmem.F
> >> lhsbc5.F lhsbc6.F exgeo.F newgeo.F ghost.F ghost2.F init.F iset.F
> >> iset_t.F main.F matsch.F MotionSolver.F myTS.F nodres.F nodres_t.F
> >> noname.f printmat2.F printmat.F printmatmm.F qb.F rdat.F readat.F
> >> rgrdpts.F rhsbc1.F rhsbc4.F rhsbc5.F rhsbc5c.F sclsch.F
> >> setbc4laplace.F setibc.F seterr.F setupRHS.F setupRHS_t.F setupLHS_b.F
> >> solzne.F MatAllocaSeq.F test.F tmodel.F turbini.F turbsch.F update2.F
> >> update3.F update4.F weakbc.F -o ApplicationFunction_t.o
> >> gfortran: fatal error: cannot specify ‘-o’ with ‘-c’, ‘-S’ or ‘-E’
> >> with multiple files
> >> compilation terminated.
> > If I remove ${SOURCEF} from the ${PETSC_FCOMPILE} definition in
> > things work, but I am not sure that this is the right thing to do.
> > Thanks,
> > Aldo
> > PS My makefile is attached
> > Dr. Aldo Bonfiglioli
> > Associate professor of Fluid Machines
> > Scuola di Ingegneria
> > Universita' della Basilicata
> > V.le dell'Ateneo lucano, 10 85100 Potenza ITALY
> > tel:+39.0971.205203 fax:+39.0971.205215
> > web: http://docenti.unibas.it/site/home/docente.html?m=002423
> > VERSION		= 3.12.0
> > PROGRAM		= eulfs$(VERSION)-$(PETSC_ARCH)
> > all: 		$(PROGRAM)
> > FFLAGS	        = -I../../include/ -I.
> > FCPPFLAGS	= $(FCPPFLAGS) -I../../include/ -I.
> > CFLAGS	        =
> > # ad hoc fix for SP3
> > #FCPPFLAGS       = ${PETSC_INCLUDE} ${PCONF} ${PETSCFLAGS} ${PETSC_PARCH} \
> > 		${FPPFLAGS} -I$(FSPL_DIR)/include/
> > DEST		= $(HOME)/bin/$(PETSC_ARCH)
> > INSTALL		= cp
> > SOURCEC	        =
> > SOURCEF	        = \
> > 		getidx.f \
> > 		ApplicationFunction.F \
> > 		ApplicationFunction_t.F \
> > 		bndry_iset.F \
> > 		JacobianBoundaryConditions.F \
> > 		RHSFunction.F \
> > 		RHSFunction_t.F \
> > 		RHSJacobian.F \
> > 		RHSJacobian_t.F \
> > 		blockdata.f \
> > 		bndvflx.F \
> > 		clearmem.F \
> > 		lhsbc5.F \
> > 		lhsbc6.F \
> > 		exgeo.F \
> > 		newgeo.F \
> > 		ghost.F \
> > 		ghost2.F \
> > 		init.F \
> > 		iset.F \
> > 		iset_t.F \
> > 		main.F \
> > 		matsch.F \
> > 		MotionSolver.F \
> > 		myTS.F \
> > 		nodres.F \
> > 		nodres_t.F \
> > 		noname.f \
> > 		printmat2.F \
> > 		printmat.F \
> > 		printmatmm.F \
> > 		qb.F \
> > 		rdat.F \
> > 		readat.F \
> > 		rgrdpts.F \
> > 		rhsbc1.F \
> > 		rhsbc4.F \
> > 		rhsbc5.F \
> > 		rhsbc5c.F \
> > 		sclsch.F \
> > 		setbc4laplace.F \
> > 		setibc.F \
> > 		seterr.F \
> > 		setupRHS.F \
> > 		setupRHS_t.F \
> > 		setupLHS_b.F \
> > 		solzne.F \
> > 		MatAllocaSeq.F \
> > 		test.F \
> > 		tmodel.F \
> > 		turbini.F \
> > 		turbsch.F \
> > 		update2.F \
> > 		update3.F \
> > 		update4.F \
> > 		weakbc.F
> > SOURCEH	        =
> > OBJSC	        =
> > OBJSF	        = \
> > 		getidx.o \
> > 		ApplicationFunction.o \
> > 		ApplicationFunction_t.o \
> > 		bndry_iset.o \
> > 		JacobianBoundaryConditions.o \
> > 		RHSFunction.o \
> > 		RHSFunction_t.o \
> > 		RHSJacobian.o \
> > 		RHSJacobian_t.o \
> > 		blockdata.o \
> > 		bndvflx.o \
> > 		clearmem.o \
> > 		lhsbc5.o \
> > 		lhsbc6.o \
> > 		exgeo.o \
> > 		newgeo.o \
> > 		ghost.o \
> > 		ghost2.o \
> > 		init.o \
> > 		iset.o \
> > 		iset_t.o \
> > 		main.o \
> > 		matsch.o \
> > 		MotionSolver.o \
> > 		myTS.o \
> > 		nodres.o \
> > 		nodres_t.o \
> > 		noname.o \
> > 		printmat2.o \
> > 		printmat.o \
> > 		printmatmm.o \
> > 		qb.o \
> > 		rdat.o \
> > 		readat.o \
> > 		rgrdpts.o \
> > 		rhsbc1.o \
> > 		rhsbc4.o \
> > 		rhsbc5.o \
> > 		rhsbc5c.o \
> > 		sclsch.o \
> > 		setbc4laplace.o \
> > 		setibc.o \
> > 		seterr.o \
> > 		setupRHS.o \
> > 		setupRHS_t.o \
> > 		setupLHS_b.o \
> > 		solzne.o \
> > 		MatAllocaSeq.o \
> > 		test.o \
> > 		tmodel.o \
> > 		turbini.o \
> > 		turbsch.o \
> > 		update2.o \
> > 		update3.o \
> > 		update4.o \
> > 		weakbc.o
> > LIBBASE	        =
> > #LIBFLAGS      = -L$(HOME)/lib/$(PETSC_ARCH) -lfxdr -lport -lmynag -lskit
> > LIBFLAGS      = -L$(HOME)/lib/$(PETSC_ARCH) -lfxdr -lport -lsparse-blas -lskit -ltirpc
> > LIBS		= \
> > 		$(FSPL_DIR)/lib/$(PETSC_ARCH)/libscalar.a \
> > 		$(FSPL_DIR)/lib/$(PETSC_ARCH)/libeuler.a \
> > 		$(FSPL_DIR)/lib/$(PETSC_ARCH)/libspl.a \
> > 		$(FSPL_DIR)/lib/$(PETSC_ARCH)/libns.a \
> > 		$(FSPL_DIR)/lib/$(PETSC_ARCH)/libturbo.a \
> > 		$(FSPL_DIR)/lib/$(PETSC_ARCH)/libgeo.a \
> > 		$(FSPL_DIR)/lib/$(PETSC_ARCH)/libchem.a \
> > 		$(FSPL_DIR)/lib/$(PETSC_ARCH)/libutil.a
> > # CLDFILES to be defined only for CRAY
> > #CLDFILES	= dp_lapack.cld dp_blas.cld pat.cld
> > #look:;	@echo $(SOURCEALL) $(OBJSF)
> > look:;	@echo "Look man! Isn't it weird? " $(PETSC_FCOMPILE)
> > $(PROGRAM): $(OBJSF) $(OBJSC) $(LIBS)
> > 	-$(FLINKER) $(CLDFILES) -o $(PROGRAM) $(OBJSF) $(OBJSC) $(LIBS) \
> > 	$(PETSC_FORTRAN_LIB) $(PETSC_LIB) $(LIBFLAGS)
> > $(FSPL_DIR)/lib/$(PETSC_ARCH)/libgeo.a:
> > 		cd $(FSPL_DIR)/src/geometry; $(MAKE) install
> > $(FSPL_DIR)/lib/$(PETSC_ARCH)/libeuler.a:
> > 		cd $(FSPL_DIR)/src/euler; $(MAKE) install
> > $(FSPL_DIR)/lib/$(PETSC_ARCH)/libspl.a:
> > 		cd $(FSPL_DIR)/src/schemes; $(MAKE) install
> > $(FSPL_DIR)/lib/$(PETSC_ARCH)/libns.a:
> > 		cd $(FSPL_DIR)/src/navier-stokes; $(MAKE) install
> > $(FSPL_DIR)/lib/$(PETSC_ARCH)/libscalar.a:
> > 		cd $(FSPL_DIR)/src/scalar; $(MAKE) install
> > $(FSPL_DIR)/lib/$(PETSC_ARCH)/libturbo.a:
> > 		cd $(FSPL_DIR)/src/turbo; $(MAKE) install
> > $(FSPL_DIR)/lib/$(PETSC_ARCH)/libchem.a:
> > 		cd $(FSPL_DIR)/src/chemistry; $(MAKE) install
> > $(FSPL_DIR)/lib/$(PETSC_ARCH)/libutil.a:
> > 		cd $(FSPL_DIR)/src/util; $(MAKE) install
> > #.SUFFIXES:
> > #.F.o:
> > #	$(U_FC) -c $(FFLAGS) $(FCPPFLAGS) $<
> > #.f.o:
> > #	$(U_FC) -c $(FFLAGS) $<
> > checkout:;      @co $(SOURCEF)
> > install:        $(PROGRAM)
> > 		@echo Installing $(PROGRAM) in $(DEST)
> > 		@if [ $(DEST) != . ]; then \
> > 		(rm -f $(DEST)/$(PROGRAM); $(INSTALL) $(PROGRAM) $(DEST)); fi
> > blockdata.o: ../../include/paramt.h ../../include/bnd.h \
> > 	../../include/constants.h ../../include/bnd.com \
> > 	../../include/conv.com ../../include/implicit.h \
> > 	../../include/nboun.com ../../include/three.com
> > bndvflx.o: ../../include/paramt.h ../../include/constants.h \
> > 	../../include/implicit.h ../../include/bnd.h ../../include/bnd.com \
> > 	../../include/three.com ../../include/nloc.com ../../include/flags.com \
> > 	../../include/stream.com ../../include/io.com
> > exgeo.o: ../../include/io.com ../../include/constants.h ../../include/nloc.com
> > iset.o: ../../include/iset.com
> > lhsbc5.o: ../../include/iset.com
> > main.o:	../../include/stack.com
> > matsch.o: ../../include/flags.com
> > mshcnt.o: ../../include/verbose.com ../../include/io.com
> > nodres.o: ../../include/paramt.h ../../include/bnd.h ../../include/constants.h \
> > 	../../include/bnd.com ../../include/nloc.com ../../include/flags.com \
> > 	../../include/stream.com ../../include/conv.com \
> > 	../../include/nboun.com ../../include/implicit.h ../../include/io.com
> > psub.o: ../../include/constants.h ../../include/paramt.h ../../include/nloc.com \
> > rdat.o: ../../include/paramt.h ../../include/bnd.h ../../include/implicit.h \
> > 	../../include/visco.com ../../include/constants.h \
> > 	../../include/conv.com ../../include/stream.com \
> > 	../../include/chorin.com ../../include/scalar.com \
> > 	../../include/flags.com ../../include/turb.com \
> > 	../../include/bnd.com ../../include/io.com \
> > readat.o: ../../include/constants.h ../../include/bnd.h ../../include/paramt.h \
> > 	../../include/io.com ../../include/nloc.com ../../include/flags.com \
> > rhsbc1.o: ../../include/paramt.h ../../include/constants.h \
> > rhsbc4.o: ../../include/paramt.h ../../include/constants.h \
> > rhsbc5.o: ../../include/paramt.h ../../include/iset.com \
> > sclsch.o: ../../include/flags.com
> > solzne.o: ../../include/io.com
> > turbcomp.o: ../../include/paramt.h ../../include/constants.h ../../include/nloc.com \
> > 	../../include/three.com ../../include/flags.com ../../include/turb.com \
> > 	../../include/trip.com ../../include/visco.com \
> > update2.o: ../../include/constants.h ../../include/paramt.h \
> > 	../../include/conv.com ../../include/nloc.com ../../include/verbose.com \
> > 	../../include/implicit.h ../../include/iset.com \
> > 	../../include/flags.com ../../include/io.com
> > update3.o: ../../include/constants.h ../../include/paramt.h \
> > 	../../include/implicit.h ../../include/conv.com ../../include/nloc.com \
> > 	../../include/verbose.com ../../include/iset.com \
> > update4.o: ../../include/constants.h ../../include/paramt.h \
> > 	../../include/conv.com ../../include/nboun.com ../../include/nloc.com \
> > 	../../include/verbose.com ../../include/implicit.h ../../include/io.com
> > weakbc.o: ../../include/paramt.h ../../include/constants.h ../../include/bnd.h \
> > 	../../include/bnd.com ../../include/three.com ../../include/nloc.com \
> > 	../../include/implicit.h rotaterhs.f rotaterhs2.f
