[petsc-users] makefile changes since release 12
Aldo Bonfiglioli
aldo.bonfiglioli at unibas.it
Fri Apr 24 03:33:13 CDT 2020
Hi there,
the makefile I have been using for ages (up to 11.4) now fails with 12.5.
I noticed that there have been several changes in
include $(PETSC_DIR)/lib/petsc/conf/variables
include $(PETSC_DIR)/lib/petsc/conf/rules
btw. the two aforementioned versions.
If I'm not wrong, *.F files should now be compiled with:
> .F.o .F90.o .F95.o:
> ${PETSC_FCOMPILE} -o $@ $<
However, in ${PETSC_FCOMPILE} there are also my ${SOURCEF} fortran sources,
so that I get the following compilation error:
> gfortran -c -fPIC -Wall -ffree-line-length-0
> -Wno-unused-dummy-argument -g -I../../include/ -I.
> -I/home/abonfi/src/petsc-3.12.5/include
> -I/home/abonfi/src/petsc-3.12.5/linux_gnu/include getidx.f
> ApplicationFunction.F ApplicationFunction_t.F bndry_iset.F
> JacobianBoundaryConditions.F RHSFunction.F RHSFunction_t.F
> RHSJacobian.F RHSJacobian_t.F blockdata.f bndvflx.F clearmem.F
> lhsbc5.F lhsbc6.F exgeo.F newgeo.F ghost.F ghost2.F init.F iset.F
> iset_t.F main.F matsch.F MotionSolver.F myTS.F nodres.F nodres_t.F
> noname.f printmat2.F printmat.F printmatmm.F qb.F rdat.F readat.F
> rgrdpts.F rhsbc1.F rhsbc4.F rhsbc5.F rhsbc5c.F sclsch.F
> setbc4laplace.F setibc.F seterr.F setupRHS.F setupRHS_t.F setupLHS_b.F
> solzne.F MatAllocaSeq.F test.F tmodel.F turbini.F turbsch.F update2.F
> update3.F update4.F weakbc.F -o ApplicationFunction_t.o
> gfortran: fatal error: cannot specify ‘-o’ with ‘-c’, ‘-S’ or ‘-E’
> with multiple files
> compilation terminated.
If I remove ${SOURCEF} from the ${PETSC_FCOMPILE} definition in
things work, but I am not sure that this is the right thing to do.
Aldo
PS My makefile is attached
Dr. Aldo Bonfiglioli
Associate professor of Fluid Machines
Scuola di Ingegneria
Universita' della Basilicata
V.le dell'Ateneo lucano, 10 85100 Potenza ITALY
tel:+39.0971.205203 fax:+39.0971.205215
web: http://docenti.unibas.it/site/home/docente.html?m=002423
VERSION = 3.12.0
PROGRAM = eulfs$(VERSION)-$(PETSC_ARCH)
all: $(PROGRAM)
FFLAGS = -I../../include/ -I.
FCPPFLAGS = $(FCPPFLAGS) -I../../include/ -I.
CFLAGS =
# ad hoc fix for SP3
#FCPPFLAGS = ${PETSC_INCLUDE} ${PCONF} ${PETSCFLAGS} ${PETSC_PARCH} \
${FPPFLAGS} -I$(FSPL_DIR)/include/
DEST = $(HOME)/bin/$(PETSC_ARCH)
INSTALL = cp
SOURCEC =
SOURCEF = \
getidx.f \
ApplicationFunction.F \
ApplicationFunction_t.F \
bndry_iset.F \
JacobianBoundaryConditions.F \
RHSFunction.F \
RHSFunction_t.F \
RHSJacobian.F \
RHSJacobian_t.F \
blockdata.f \
bndvflx.F \
clearmem.F \
lhsbc5.F \
lhsbc6.F \
exgeo.F \
newgeo.F \
ghost.F \
ghost2.F \
init.F \
iset.F \
iset_t.F \
main.F \
matsch.F \
MotionSolver.F \
myTS.F \
nodres.F \
nodres_t.F \
noname.f \
printmat2.F \
printmat.F \
printmatmm.F \
qb.F \
rdat.F \
readat.F \
rgrdpts.F \
rhsbc1.F \
rhsbc4.F \
rhsbc5.F \
rhsbc5c.F \
sclsch.F \
setbc4laplace.F \
setibc.F \
seterr.F \
setupRHS.F \
setupRHS_t.F \
setupLHS_b.F \
solzne.F \
MatAllocaSeq.F \
test.F \
tmodel.F \
turbini.F \
turbsch.F \
update2.F \
update3.F \
update4.F \
weakbc.F
SOURCEH =
OBJSC =
OBJSF = \
getidx.o \
ApplicationFunction.o \
ApplicationFunction_t.o \
bndry_iset.o \
JacobianBoundaryConditions.o \
RHSFunction.o \
RHSFunction_t.o \
RHSJacobian.o \
RHSJacobian_t.o \
blockdata.o \
bndvflx.o \
clearmem.o \
lhsbc5.o \
lhsbc6.o \
exgeo.o \
newgeo.o \
ghost.o \
ghost2.o \
init.o \
iset.o \
iset_t.o \
main.o \
matsch.o \
MotionSolver.o \
myTS.o \
nodres.o \
nodres_t.o \
noname.o \
printmat2.o \
printmat.o \
printmatmm.o \
qb.o \
rdat.o \
readat.o \
rgrdpts.o \
rhsbc1.o \
rhsbc4.o \
rhsbc5.o \
rhsbc5c.o \
sclsch.o \
setbc4laplace.o \
setibc.o \
seterr.o \
setupRHS.o \
setupRHS_t.o \
setupLHS_b.o \
solzne.o \
MatAllocaSeq.o \
test.o \
tmodel.o \
turbini.o \
turbsch.o \
update2.o \
update3.o \
update4.o \
weakbc.o
LIBBASE =
#LIBFLAGS = -L$(HOME)/lib/$(PETSC_ARCH) -lfxdr -lport -lmynag -lskit
LIBFLAGS = -L$(HOME)/lib/$(PETSC_ARCH) -lfxdr -lport -lsparse-blas -lskit -ltirpc
LIBS = \
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libscalar.a \
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libeuler.a \
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libspl.a \
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libns.a \
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libturbo.a \
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libgeo.a \
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libchem.a \
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libutil.a
# CLDFILES to be defined only for CRAY
#CLDFILES = dp_lapack.cld dp_blas.cld pat.cld
#look:; @echo $(SOURCEALL) $(OBJSF)
look:; @echo "Look man! Isn't it weird? " $(PETSC_FCOMPILE)
$(PROGRAM): $(OBJSF) $(OBJSC) $(LIBS)
-$(FLINKER) $(CLDFILES) -o $(PROGRAM) $(OBJSF) $(OBJSC) $(LIBS) \
$(PETSC_FORTRAN_LIB) $(PETSC_LIB) $(LIBFLAGS)
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libgeo.a:
cd $(FSPL_DIR)/src/geometry; $(MAKE) install
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libeuler.a:
cd $(FSPL_DIR)/src/euler; $(MAKE) install
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libspl.a:
cd $(FSPL_DIR)/src/schemes; $(MAKE) install
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libns.a:
cd $(FSPL_DIR)/src/navier-stokes; $(MAKE) install
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libscalar.a:
cd $(FSPL_DIR)/src/scalar; $(MAKE) install
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libturbo.a:
cd $(FSPL_DIR)/src/turbo; $(MAKE) install
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libchem.a:
cd $(FSPL_DIR)/src/chemistry; $(MAKE) install
$(FSPL_DIR)/lib/$(PETSC_ARCH)/libutil.a:
cd $(FSPL_DIR)/src/util; $(MAKE) install
#.SUFFIXES:
#.F.o:
# $(U_FC) -c $(FFLAGS) $(FCPPFLAGS) $<
#.f.o:
# $(U_FC) -c $(FFLAGS) $<
checkout:; @co $(SOURCEF)
install: $(PROGRAM)
@echo Installing $(PROGRAM) in $(DEST)
@if [ $(DEST) != . ]; then \
(rm -f $(DEST)/$(PROGRAM); $(INSTALL) $(PROGRAM) $(DEST)); fi
blockdata.o: ../../include/paramt.h ../../include/bnd.h \
../../include/constants.h ../../include/bnd.com \
../../include/conv.com ../../include/implicit.h \
../../include/nboun.com ../../include/three.com
bndvflx.o: ../../include/paramt.h ../../include/constants.h \
../../include/implicit.h ../../include/bnd.h ../../include/bnd.com \
../../include/three.com ../../include/nloc.com ../../include/flags.com \
../../include/stream.com ../../include/io.com
exgeo.o: ../../include/io.com ../../include/constants.h ../../include/nloc.com
iset.o: ../../include/iset.com
lhsbc5.o: ../../include/iset.com
main.o: ../../include/stack.com
matsch.o: ../../include/flags.com
mshcnt.o: ../../include/verbose.com ../../include/io.com
nodres.o: ../../include/paramt.h ../../include/bnd.h ../../include/constants.h \
../../include/bnd.com ../../include/nloc.com ../../include/flags.com \
../../include/stream.com ../../include/conv.com \
../../include/nboun.com ../../include/implicit.h ../../include/io.com
psub.o: ../../include/constants.h ../../include/paramt.h ../../include/nloc.com \
rdat.o: ../../include/paramt.h ../../include/bnd.h ../../include/implicit.h \
../../include/visco.com ../../include/constants.h \
../../include/conv.com ../../include/stream.com \
../../include/chorin.com ../../include/scalar.com \
../../include/flags.com ../../include/turb.com \
../../include/bnd.com ../../include/io.com \
readat.o: ../../include/constants.h ../../include/bnd.h ../../include/paramt.h \
../../include/io.com ../../include/nloc.com ../../include/flags.com \
rhsbc1.o: ../../include/paramt.h ../../include/constants.h \
rhsbc4.o: ../../include/paramt.h ../../include/constants.h \
rhsbc5.o: ../../include/paramt.h ../../include/iset.com \
sclsch.o: ../../include/flags.com
solzne.o: ../../include/io.com
turbcomp.o: ../../include/paramt.h ../../include/constants.h ../../include/nloc.com \
../../include/three.com ../../include/flags.com ../../include/turb.com \
../../include/trip.com ../../include/visco.com \
update2.o: ../../include/constants.h ../../include/paramt.h \
../../include/conv.com ../../include/nloc.com ../../include/verbose.com \
../../include/implicit.h ../../include/iset.com \
../../include/flags.com ../../include/io.com
update3.o: ../../include/constants.h ../../include/paramt.h \
../../include/implicit.h ../../include/conv.com ../../include/nloc.com \
../../include/verbose.com ../../include/iset.com \
update4.o: ../../include/constants.h ../../include/paramt.h \
../../include/conv.com ../../include/nboun.com ../../include/nloc.com \
../../include/verbose.com ../../include/implicit.h ../../include/io.com
weakbc.o: ../../include/paramt.h ../../include/constants.h ../../include/bnd.h \
../../include/bnd.com ../../include/three.com ../../include/nloc.com \
../../include/implicit.h rotaterhs.f rotaterhs2.f
