[petsc-users] Ignoring PETSC_ARCH for make check?
    san.temporal at gmail.com
    Tue Apr 21 04:13:38 CDT 2020
Satish,
Great, thanks.
Santiago
On Sun, Apr 19, 2020 at 12:23 PM Satish Balay <balay at mcs.anl.gov> wrote:
> PETSc supports both inplace multiple builds - and prefix builds. Most
> packages don't support inplace multiple builds. For inplace multiple builds
> - you need the PETSC_ARCH concept. But not for prefix builds.
> i.e: 2 inplace builds.
> ./configure PETSC_ARCH=arch-build1 --with-cc=gcc etc..
> make
> ./configure PETSC_ARCH=arch-build2 --with-cc=icc etc..
> make
> 2 prefix builds
> ./configure --prefix=$HOME/soft/petsc-install-1 PETSC_ARCH=arch-build1
> --with-cc=gcc
> make
> make install
> ./configure --prefix=$HOME/soft/petsc-install-1 PETSC_ARCH=arch-build2
> --with-cc=icc
> make
> make install
> Note: using a different PETSC_ARCH above so that the intermediate build
> files from the first build don't conflict with those from the second build.
> Note: due to same files used in both cases - i.e prefix and inplace [i.e
> petsc sources from build location] for make check - a wrong value of
> 'PETSC_ARCH' can break 'make check'
> The files installed in prefix location don't care about PETSC_ARCH value.
> Satish
> On Sun, 19 Apr 2020, san.temporal at gmail.com wrote:
> >  Ok, the, the second option applies... I had forgotten about this
> > observation from the multiple times I installed PETSc in the past.
> > Then, two questions come to mind:
> > 1. Why is it set up like that?
> > 2. What is the difference in behaviour? I see the same output from both
> > options.
> > Thanks again!
> > On Sat, Apr 18, 2020 at 5:43 PM Jed Brown <jed at jedbrown.org> wrote:
> > > It's intentional and been like this for ages.  Prefix installs have
> only
> > > PETSC_DIR (just a path, like other packages), and *must not* set
> > > PETSC_ARCH.
> > > san.temporal at gmail.com writes:
> > > > Hi all,
> > > > I have just successfully compiled 3.13.0. But with install this is
> what I
> > > > get
> > > >     $ make
> > > PETSC_DIR=/home/santiago/Documents/installers/petsc/petsc-3.13.0
> > > > PETSC_ARCH=arch-linux2-c-opt install
> > > >     *** Using
> > > > PETSC_ARCH=arch-linux2-c-opt ***
> > > >     *** Installing PETSc at prefix location: /home/santiago/usr/local
> > > >     Install complete.
> > > >     Now to check if the libraries are working do (in current
> directory):
> > > >     make PETSC_DIR=/home/santiago/usr/local PETSC_ARCH="" check
> > > >     /usr/bin/make  --no-print-directory -f makefile
> > > > mpi4py-install petsc4py-install libmesh-install mfem-install
> > > slepc-install
> > > > hpddm-install amrex-install
> > > >     make[2]: Nothing to be done for 'mpi4py-install'.
> > > >     make[2]: Nothing to be done for 'petsc4py-install'.
> > > >     make[2]: Nothing to be done for 'libmesh-install'.
> > > >     make[2]: Nothing to be done for 'mfem-install'.
> > > >     make[2]: Nothing to be done for 'slepc-install'.
> > > >     make[2]: Nothing to be done for 'hpddm-install'.
> > > >     make[2]: Nothing to be done for 'amrex-install'.
> > > > What is strange to me is that I am instructed to execute a line with
> > > > PETSC_ARCH=", while my environment has PETSC_ARCH=arch-linux2-c-opt
> > > > Why is that?
> > > > PS: The same happened to me with various other compilations I have
> just
> > > > tested, with 3.9, 3.10, 3.11, 3.12
> > > > PS2: I do not recall seeing this ever before, although I may have
> missed
> > > > it/forgotten.
> > > > Thanks in advance,
> > > > Santiago
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200421/5f0ac959/attachment-0001.html>
