[petsc-users] SuperLU + GPUs
Mark Adams
mfadams at lbl.gov
Sun Apr 19 07:16:51 CDT 2020
On Sat, Apr 18, 2020 at 9:04 PM Xiaoye S. Li <xsli at lbl.gov> wrote:
> That works, but your previous email showed the following:
Ah, so PETSc must switch internally.
Is there any reason why we should not use superlu_dist all of the time?
> SuperLU:
> Version: 5.2.1
> Includes: -I/ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/include
> Library: -Wl,-rpath,/ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib
> -L/ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib -lsuperlu
> which is serial superlu, not superlu_dist. These are 2 different codes.
> Sherry
> On Sat, Apr 18, 2020 at 4:54 PM Mark Adams <mfadams at lbl.gov> wrote:
>> On Sat, Apr 18, 2020 at 3:05 PM Xiaoye S. Li <xsli at lbl.gov> wrote:
>>> Mark,
>>> It seems you are talking about serial superlu? There is no GPU support
>>> in it. Only superlu_dist has GPU.
>> I am using superlu_dist on one processor. Should that work?
>>> But I don't know why there is a crash.
>>> Sherry
>>> On Sat, Apr 18, 2020 at 11:44 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> Sherry, I did rebase with master this week:
>>>> SuperLU:
>>>> Version: 5.2.1
>>>> Library:
>>>> I see the same thing with a debug build.
>>>> If anyone is interested in looking at this, I was also able to see that
>>>> plex/ex10 in my branch, which is a very simple test , also does not crash
>>>> and also does not seem to use GPUs in SuperLU.
>>>> On Sat, Apr 18, 2020 at 11:46 AM Xiaoye S. Li <xsli at lbl.gov> wrote:
>>>>> When you install "-download-superlu_dist", that is from 'master'
>>>>> branch?
>>>>> In the error trace, I recognized this:
>>>>> > [h50n09:102287] [ 9] /ccs/home/adams/petsc/arch-
>>>>> summit-opt-gnu-cuda-omp/lib/libsuperlu_dist.so.6(dDestroy_
>>>>> LU+0xc4)[0x20000195aff4]
>>>>> This is to free the L and U data structures at the end of the program.
>>>>> Sherry
>>>>> On Sat, Apr 18, 2020 at 7:24 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> Back to SuperLU + GPUs (adding Sherry)
>>>>>> I get this error (appended) running 'check', as I said before. It
>>>>>> looks like ex19 is *failing* with CUDA but it is not clear it has
>>>>>> anything to do with SuperLU. I can not find these diagnostics that got
>>>>>> printed after the error in PETSc or SuperLU.
>>>>>> So this is a problem, but moving on to my code (plex/ex11 in
>>>>>> mark/feature-xgc-interface-rebase-v2, configure script appended). It runs.
>>>>>> I use superlu and GPUs, but they do not seem to be used in SuperLU:
>>>>>> Event Count Time (sec) Flop
>>>>>> --- Global --- --- Stage ---- Total GPU - CpuToGpu - -
>>>>>> GpuToCpu - GPU
>>>>>> Max Ratio Max Ratio Max Ratio Mess
>>>>>> AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s Mflop/s Count Size
>>>>>> Count Size %F
>>>>>> MatLUFactorNum 12 1.0 *2.3416e+01* 1.0 0.00e+00 0.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 31 0 0 0 0 31 0 0 0 0 0 0 *0
>>>>>> 0.00e+00 0 0.00e+00 0*
>>>>>> No CUDA version. The times are the same and no GPU
>>>>>> communication above. So SuperLU does not seem to be using GPUs.
>>>>>> MatLUFactorNum 12 1.0 *2.3421e+01* 1.0 0.00e+00 0.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 5 0 0 0 0 5 0 0 0 0 0
>>>>>> There are some differences: ex19 use DMDA and I use DMPlex, 'check'
>>>>>> is run in my home directory, where files can not be written, and I run my
>>>>>> code in the project areas.
>>>>>> The timings are different without superlu so I think superlu is being
>>>>>> used. THis is how I run this (w and w/o -mat_superlu_equil -dm_mat_type
>>>>>> sell)
>>>>>> jsrun -n 1 -a 1 -c 2 -g 1 ./ex113d_no_cuda -dim 3 -dm_view
>>>>>> hdf5:re33d.h5 -vec_view hdf5:re33d.h5::append -test_type spitzer -Ez 0
>>>>>> -petscspace_degree 2 -mass_petscspace_degree 2 -petscspace_poly_tensor 1
>>>>>> -mass_petscspace_poly_tensor 1 -dm_type p8est -ion_masses 4 -ion_charges 2
>>>>>> -thermal_temps 4,4 -n 1,.5 -n_0 1e20 -ts_monitor -ts_adapt_monitor
>>>>>> -snes_rtol 1.e-6 -snes_stol 1.e-9 -snes_monitor -snes_converged_reason
>>>>>> -snes_max_it 15 -ts_type arkimex -ts_exact_final_time stepover
>>>>>> -ts_arkimex_type 1bee -ts_max_snes_failures -1 -ts_rtol 1e-3 -ts_dt 1e-1
>>>>>> -ts_adapt_clip .25,1.05 -ts_adapt_dt_max 10 -ts_adapt_dt_min 2e-2
>>>>>> -ts_max_time 3200 -ts_max_steps 1 -ts_adapt_scale_solve_failed 0.75
>>>>>> -ts_adapt_time_step_increase_delay 5 -pc_type lu -ksp_type preonly
>>>>>> -amr_levels_max 11 -amr_re_levels 0 -amr_z_refine1 0 -amr_z_refine2 0
>>>>>> -amr_post_refine 0 -domain_radius -.95 -re_radius 4 -z_radius1 8 -z_radius2
>>>>>> .1 -plot_dt .10 -impurity_source_type pulse -pulse_start_time 2600
>>>>>> -pulse_width_time 100 -pulse_rate 1e+0 -t_cold .005 -info :dm,tsadapt:
>>>>>> -sub_thread_block_size 4 -options_left -log_view -pc_factor_mat_solver_type
>>>>>> superlu -mat_superlu_equil -dm_mat_type sell
>>>>>> So there is a bug in ex19 on SUMMIT and I am not getting GPUs turned
>>>>>> on in SuperLU.
>>>>>> Thoughts?
>>>>>> Thanks,
>>>>>> Mark
>>>>>> 09:28 mark/feature-xgc-interface-rebase-v2 *= ~/petsc$ make
>>>>>> PETSC_DIR=/ccs/home/adams/petsc PETSC_ARCH=arch-summit-opt-gnu-cuda-omp
>>>>>> check
>>>>>> Running check examples to verify correct installation
>>>>>> Using PETSC_DIR=/ccs/home/adams/petsc and
>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>>>> process
>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>>>> processes
>>>>>> 2c2,39
>>>>>> < Number of SNES iterations = 2
>>>>>> *> ex19: cudahook.cc:762: CUresult host_free_callback(void*):
>>>>>> Assertion `cacheNode != __null' failed.*> [h50n09:102287] ***
>>>>>> Process received signal ***
>>>>>> > CUDA version: v 10010
>>>>>> > CUDA Devices:
>>>>>> > 0 : Tesla V100-SXM2-16GB 7 0
>>>>>> > Global memory: 16128 mb
>>>>>> > Shared memory: 48 kb
>>>>>> > Constant memory: 64 kb
>>>>>> > Block registers: 65536
>>>>>> > [h50n09:102287] Signal: Aborted (6)
>>>>>> > [h50n09:102287] Associated errno: Unknown error 1072693248
>>>>>> (1072693248)
>>>>>> > [h50n09:102287] Signal code: User function (kill, sigsend, abort,
>>>>>> etc.) (0)
>>>>>> > [h50n09:102287] [ 0] [0x2000000504d8]
>>>>>> > [h50n09:102287] [ 1] /lib64/libc.so.6(abort+0x2b4)[0x200021bf2094]
>>>>>> > [h50n09:102287] [ 2] /lib64/libc.so.6(+0x356d4)[0x200021be56d4]
>>>>>> > [h50n09:102287] [ 3]
>>>>>> /lib64/libc.so.6(__assert_fail+0x64)[0x200021be57c4]
>>>>>> > [h50n09:102287] [ 4]
>>>>>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/container/../lib/libpami_cudahook.so(_Z18host_free_callbackPv+0x2d8)[0x2000000cd2c8]
>>>>>> > [h50n09:102287] [ 5]
>>>>>> /autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/container/../lib/libpami_cudahook.so(cuMemFreeHost+0xb0)[0x2000000c3cc0]
>>>>>> > [h50n09:102287] [ 6]
>>>>>> /sw/summit/cuda/10.1.243/lib64/libcudart.so.10.1(+0x42f50)[0x20000ed02f50]
>>>>>> > [h50n09:102287] [ 7]
>>>>>> /sw/summit/cuda/10.1.243/lib64/libcudart.so.10.1(+0x11db8)[0x20000ecd1db8]
>>>>>> > [h50n09:102287] [ 8]
>>>>>> /sw/summit/cuda/10.1.243/lib64/libcudart.so.10.1(cudaFreeHost+0x74)[0x20000ed12ea4]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libsuperlu_dist.so.6(dDestroy_LU+0xc4)[0x20000195aff4]
>>>>>> > [h50n09:102287] [10]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.013(+0x7cdb70)[0x2000008bdb70]
>>>>>> > [h50n09:102287] [11]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.013(MatLUFactorNumeric+0x1ec)[0x2000005f1a8c]
>>>>>> > [h50n09:102287] [12]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.013(+0xbf8270)[0x200000ce8270]
>>>>>> > [h50n09:102287] [13]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.013(PCSetUp+0x1a4)[0x200000d8d5a4]
>>>>>> > [h50n09:102287] [14]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.013(KSPSetUp+0x40c)[0x200000dc498c]
>>>>>> > [h50n09:102287] [15]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.013(+0xcd56fc)[0x200000dc56fc]
>>>>>> > [h50n09:102287] [16]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.013(KSPSolve+0x20)[0x200000dc8260]
>>>>>> > [h50n09:102287] [17]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.013(+0xe0a170)[0x200000efa170]
>>>>>> > [h50n09:102287] [18]
>>>>>> /ccs/home/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.013(SNESSolve+0x814)[0x200000ebd394]
>>>>>> > [h50n09:102287] [19] ./ex19[0x10001a6c]
>>>>>> > [h50n09:102287] [20] /lib64/libc.so.6(+0x25200)[0x200021bd5200]
>>>>>> > [h50n09:102287] [21]
>>>>>> /lib64/libc.so.6(__libc_start_main+0xc4)[0x200021bd53f4]
>>>>>> > [h50n09:102287] *** End of error message ***
>>>>>> > ERROR: One or more process (first noticed rank 0) terminated with
>>>>>> signal 6
>>>>>> /ccs/home/adams/petsc/src/snes/tutorials
>>>>>> Possible problem with ex19 running with superlu_dist, diffs above
>>>>>> #!/usr/bin/env python
>>>>>> if __name__ == '__main__':
>>>>>> import sys
>>>>>> import os
>>>>>> sys.path.insert(0, os.path.abspath('config'))
>>>>>> import configure
>>>>>> configure_options = [
>>>>>> '--with-fc=0',
>>>>>> '--COPTFLAGS=-g -O2 -fPIC -fopenmp',
>>>>>> '--CXXOPTFLAGS=-g -O2 -fPIC -fopenmp',
>>>>>> '--FOPTFLAGS=-g -O2 -fPIC -fopenmp',
>>>>>> '--CUDAOPTFLAGS=-O2 -g',
>>>>>> '--with-ssl=0',
>>>>>> '--with-batch=0',
>>>>>> '--with-cxx=mpicxx',
>>>>>> '--with-mpiexec=jsrun -g1',
>>>>>> '--with-cuda=1',
>>>>>> '--with-cudac=nvcc',
>>>>>> '--download-p4est=1',
>>>>>> '--download-zlib',
>>>>>> '--download-hdf5=1',
>>>>>> '--download-metis',
>>>>>> '--download-superlu',
>>>>>> '--download-superlu_dist',
>>>>>> '--with-make-np=16',
>>>>>> # '--with-hwloc=0',
>>>>>> '--download-parmetis',
>>>>>> # '--download-hypre',
>>>>>> '--download-triangle',
>>>>>> # '--download-amgx',
>>>>>> # '--download-fblaslapack',
>>>>>> '--with-blaslapack-lib=-L' +
>>>>>> os.environ['OLCF_NETLIB_LAPACK_ROOT'] + '/lib64 -lblas -llapack',
>>>>>> '--with-cc=mpicc',
>>>>>> # '--with-fc=mpif90',
>>>>>> '--with-shared-libraries=1',
>>>>>> # '--known-mpi-shared-libraries=1',
>>>>>> '--with-x=0',
>>>>>> '--with-64-bit-indices=0',
>>>>>> '--with-debugging=0',
>>>>>> 'PETSC_ARCH=arch-summit-opt-gnu-cuda-omp',
>>>>>> '--with-openmp=1',
>>>>>> '--with-threadsaftey=1',
>>>>>> '--with-log=1'
>>>>>> configure.petsc_configure(configure_options)
>>>>>> On Wed, Apr 15, 2020 at 9:58 PM Satish Balay <balay at mcs.anl.gov>
>>>>>> wrote:
>>>>>>> The crash is inside Superlu_DIST - so don't know what to suggest.
>>>>>>> Might have to debug this via debugger and check with Sherry.
>>>>>>> Satish
>>>>>>> On Wed, 15 Apr 2020, Mark Adams wrote:
>>>>>>> > Ah, OK 'check' will test SuperLU. Semi worked:
>>>>>>> > s20:13 mark/feature-xgc-interface-rebase *= ~/petsc$ make
>>>>>>> PETSC_ARCH=arch-summit-dbg-gnu-cuda-omp
>>>>>>> > check
>>>>>>> process
>>>>>>> processes
>>>>>>> > 2c2,38
>>>>>>> > > CUDA Devices:
>>>>>>> Assertion
>>>>>>> > > [h16n07:78357] *** Process received signal ***
>>>>>>> > > [h16n07:78357] Signal: Aborted (6)
>>>>>>> > > [h16n07:78357] Signal code: (1704218624)
>>>>>>> > > [h16n07:78357] [ 0] [0x2000000504d8]
>>>>>>> > > [h16n07:78357] [ 1] /lib64/libc.so.6(abort+0x2b4)[0x200023992094]
>>>>>>> > > [h16n07:78357] [ 2] /lib64/libc.so.6(+0x356d4)[0x2000239856d4]
>>>>>>> > > [h16n07:78357] [ 3]
>>>>>>> /lib64/libc.so.6(__assert_fail+0x64)[0x2000239857c4]
>>>>>>> > > [h16n07:78357] [ 4]
>>>>>>> > > [h16n07:78357] [ 5]
>>>>>>> > > [h16n07:78357] [ 6]
>>>>>>> /sw/summit/cuda/10.1.243/lib64/libcudart.so.10.1(+0x42f50)[0x200010aa2f50]
>>>>>>> > > [h16n07:78357] [ 7]
>>>>>>> /sw/summit/cuda/10.1.243/lib64/libcudart.so.10.1(+0x11db8)[0x200010a71db8]
>>>>>>> > > [h16n07:78357] [ 8]
>>>>>>> /sw/summit/cuda/10.1.243/lib64/libcudart.so.10.1(cudaFreeHost+0x74)[0x200010ab2ea4]
>>>>>>> > > [h16n07:78357] [ 9]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libsuperlu_dist.so.6(dDestroy_LU+0x150)[0x200003188058]
>>>>>>> > > [h16n07:78357] [10]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libpetsc.so.3.013(+0x12ebc6c)[0x2000013dbc6c]
>>>>>>> > > [h16n07:78357] [11]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libpetsc.so.3.013(MatLUFactorNumeric+0x934)[0x200000d2fae4]
>>>>>>> > > [h16n07:78357] [12]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libpetsc.so.3.013(+0x1cca7a4)[0x200001dba7a4]
>>>>>>> > > [h16n07:78357] [13]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libpetsc.so.3.013(PCSetUp+0xde0)[0x200001f3f990]
>>>>>>> > > [h16n07:78357] [14]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libpetsc.so.3.013(KSPSetUp+0x1848)[0x200001fc5594]
>>>>>>> > > [h16n07:78357] [15]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libpetsc.so.3.013(+0x1ed9908)[0x200001fc9908]
>>>>>>> > > [h16n07:78357] [16]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libpetsc.so.3.013(KSPSolve+0x5d0)[0x200001fcc690]
>>>>>>> > > [h16n07:78357] [17]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libpetsc.so.3.013(+0x21e16ac)[0x2000022d16ac]
>>>>>>> > > [h16n07:78357] [18]
>>>>>>> /ccs/home/adams/petsc/arch-summit-dbg-gnu-cuda-omp/lib/libpetsc.so.3.013(SNESSolve+0x23f4)[0x2000022255c0]
>>>>>>> > > [h16n07:78357] [19] ./ex19[0x10002ac8]
>>>>>>> > > [h16n07:78357] [20] /lib64/libc.so.6(+0x25200)[0x200023975200]
>>>>>>> > > [h16n07:78357] [21]
>>>>>>> > /lib64/libc.so.6(__libc_start_main+0xc4)[0x2000239753f4]
>>>>>>> > > [h16n07:78357] *** End of error message ***
>>>>>>> with signal
>>>>>>> > 6
>>>>>>> > On Wed, Apr 15, 2020 at 5:58 PM Satish Balay <balay at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>> > > Please send configure.log
>>>>>>> > > This is what I get on my linux build:
>>>>>>> > > [balay at p1 petsc]$ ./configure
>>>>>>> > > --with-mpi-dir=/home/petsc/soft/openmpi-4.0.2-cuda --with-cuda=1
>>>>>>> > > --with-openmp=1 --download-superlu-dist=1 && make && make check
>>>>>>> > > <snip>
>>>>>>> > > Using PETSC_DIR=/home/balay/petsc and
>>>>>>> PETSC_ARCH=arch-linux-c-debug
>>>>>>> MPI process
>>>>>>> MPI processes
>>>>>>> > > 1a2,19
>>>>>>> > > > CUDA version: v 10020
>>>>>>> > > > CUDA Devices:
>>>>>>> > > > 0 : Quadro T2000 7 5
>>>>>>> > > > Global memory: 3911 mb
>>>>>>> > > > CUDA Devices:
>>>>>>> > > /home/balay/petsc/src/snes/tutorials
>>>>>>> > > Fortran example src/snes/tutorials/ex5f run successfully with 1
>>>>>>> MPI process
>>>>>>> > > Completed test examples
>>>>>>> > > > On Wed, Apr 15, 2020 at 5:17 PM Satish Balay <
>>>>>>> balay at mcs.anl.gov> wrote:
>>>>>>> > > > > The build should work. It should give some verbose info [at
>>>>>>> runtime]
>>>>>>> > > > > regarding GPUs - from the following code.
>>>>>>> > > > I don't see that and I am running GPUs in my code and have
>>>>>>> gotten
>>>>>>> > > cusparse
>>>>>>> > > > LU to run. Should I use '-info :sys:' ?
>>>>>>> > > > > >>>>> SRC/cublas_utils.c >>>>>>>>>>>
>>>>>>> > > > > void DisplayHeader()
>>>>>>> > > > > const int kb = 1024;
>>>>>>> > > > > const int mb = kb * kb;
>>>>>>> > > > > // cout << "NBody.GPU" << endl << "=========" << endl <<
>>>>>>> endl;
>>>>>>> > > > > printf("CUDA version: v %d\n",CUDART_VERSION);
>>>>>>> > > > > //cout << "Thrust version: v" << THRUST_MAJOR_VERSION <<
>>>>>>> > > > > THRUST_MINOR_VERSION << endl << endl;
>>>>>>> > > > > int devCount;
>>>>>>> > > > > cudaGetDeviceCount(&devCount);
>>>>>>> > > > > printf( "CUDA Devices: \n \n");
>>>>>>> > > > > <snip>
>>>>>>> > > > > Satish
>>>>>>> > > > > On Wed, 15 Apr 2020, Junchao Zhang wrote:
>>>>>>> > > > > > I remember Barry said superlu gpu support is broken.
>>>>>>> > > > > > --Junchao Zhang
>>>>>>> > > > > > On Wed, Apr 15, 2020 at 3:47 PM Mark Adams <
>>>>>>> > > > > > > How does one use SuperLU with GPUs. I don't seem to get
>>>>>>> any GPU
>>>>>>> > > > > > > performance data so I assume GPUs are not getting turned
>>>>>>> on. Am I
>>>>>>> > > wrong
>>>>>>> > > > > > > about that?
>>>>>>> > > > > > > I configure with:
>>>>>>> > > > > > > configure options: --with-fc=0 --COPTFLAGS="-g -O2 -fPIC
>>>>>>> -fopenmp"
>>>>>>> > > > > > > --CXXOPTFLAGS="-g -O2 -fPIC -fopenmp" --FOPTFLAGS="-g
>>>>>>> -O2 -fPIC
>>>>>>> > > > > -fopenmp"
>>>>>>> > > > > > > --CUDAOPTFLAGS="-O2 -g" --with-ssl=0 --with-batch=0
>>>>>>> > > --with-cxx=mpicxx
>>>>>>> > > > > > > --with-mpiexec="jsrun -g1" --with-cuda=1
>>>>>>> --with-cudac=nvcc
>>>>>>> > > > > > > --download-p4est=1 --download-zlib --download-hdf5=1
>>>>>>> > > --download-metis
>>>>>>> > > > > > > --download-superlu --download-superlu_dist
>>>>>>> --with-make-np=16
>>>>>>> > > > > > > --download-parmetis --download-triangle
>>>>>>> --with-blaslapack-lib="-L/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/netlib-lapack-3.8.0-wcabdyqhdi5rooxbkqa6x5d7hxyxwdkm/lib64
>>>>>>> > > > > > > -lblas -llapack" --with-cc=mpicc
>>>>>>> > > --with-x=0
>>>>>>> > > > > > > --with-64-bit-indices=0 --with-debugging=0
>>>>>>> > > > > > > PETSC_ARCH=arch-summit-opt-gnu-cuda-omp --with-openmp=1
>>>>>>> > > > > > > --with-threadsaftey=1 --with-log=1
>>>>>>> > > > > > > Thanks,
>>>>>>> > > > > > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200419/9ed8f88d/attachment-0001.html>
