[petsc-users] Ignoring PETSC_ARCH for make check?
Jed Brown
jed at jedbrown.org
Sat Apr 18 15:43:57 CDT 2020
It's intentional and been like this for ages. Prefix installs have only
PETSC_DIR (just a path, like other packages), and *must not* set
PETSC_ARCH.
san.temporal at gmail.com writes:
> Hi all,
> I have just successfully compiled 3.13.0. But with install this is what I
> get
> $ make PETSC_DIR=/home/santiago/Documents/installers/petsc/petsc-3.13.0
> PETSC_ARCH=arch-linux2-c-opt install
> *** Using
> PETSC_ARCH=arch-linux2-c-opt ***
> *** Installing PETSc at prefix location: /home/santiago/usr/local ***
> Install complete.
> Now to check if the libraries are working do (in current directory):
> make PETSC_DIR=/home/santiago/usr/local PETSC_ARCH="" check
> /usr/bin/make --no-print-directory -f makefile
> mpi4py-install petsc4py-install libmesh-install mfem-install slepc-install
> hpddm-install amrex-install
> make[2]: Nothing to be done for 'mpi4py-install'.
> make[2]: Nothing to be done for 'petsc4py-install'.
> make[2]: Nothing to be done for 'libmesh-install'.
> make[2]: Nothing to be done for 'mfem-install'.
> make[2]: Nothing to be done for 'slepc-install'.
> make[2]: Nothing to be done for 'hpddm-install'.
> make[2]: Nothing to be done for 'amrex-install'.
> What is strange to me is that I am instructed to execute a line with
> PETSC_ARCH=", while my environment has PETSC_ARCH=arch-linux2-c-opt
> Why is that?
> PS: The same happened to me with various other compilations I have just
> tested, with 3.9, 3.10, 3.11, 3.12
> PS2: I do not recall seeing this ever before, although I may have missed
> it/forgotten.
> Thanks in advance,
> Santiago
