[petsc-users] Error in configure for --download-<pkg>=mydir
Satish Balay
balay at mcs.anl.gov
Fri Apr 17 17:38:01 CDT 2020
Great! Thanks for the update.
Satish
On Fri, 17 Apr 2020, Santiago Serebrinsky wrote:
> Satish,
> Thank you, it worked.
> Regards,
> Santiago
> On Fri, Apr 17, 2020 at 5:28 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > You might want to check my previous reply more closely.
> > On Fri, 17 Apr 2020, san.temporal at gmail.com wrote:
> > > The point is that I cannot go through a proxy to simply use
> > > --download-<pkg1> --download-<pkg2> ...
> > > So I would:
> > > 1. Run configure with --download-<pkg1> ...
> > > 2. Wait until configure complains about the missing package and get the
> > URL
> > > 3. wget the package
> > Configure complaint [in step 2 above] would have listed either or both:
> > git://https://bitbucket.org/petsc/pkg-fblaslapack
> > https://bitbucket.org/petsc/pkg-fblaslapack/get/v3.4.2-p3.tar.gz
> > However - you are attempting to use:
> > --download-fblaslapack=/home/santiago/Documents/installers/petsc/fblaslapack-3.4.2.tar.gz
> > This is not the same tarball as what configure has instructed you to use.
> > Satish
> > > 4. Add the local file name to --download-<pkg1>=...
> > > Repeat one package after the other until I have all the packages locally.
> > > I guess this should work. But then I get the error reported, starting
> > with
> > > 3.12.
> > > I am attaching configure.log
> > > Thanks!
> > > Santiago
> > > On Fri, Apr 17, 2020 at 12:04 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > > Some package names have changed [when using git repos for both git and
> > > > tarballs] - so its best to use the tarballs [or git repos] that are
> > > > appropriate for the current petsc release.
> > > > balay at sb /home/balay/petsc (maint=)
> > > > $ ./configure --with-packages-download-dir=$HOME/tmp
> > > > --download-fblaslapack --download-mumps --download-scalapack
> > > > Configuring PETSc to compile on your system
> > > > Download the following packages to /home/balay/tmp
> > > > fblaslapack ['git://https://bitbucket.org/petsc/pkg-fblaslapack', '
> > > > https://bitbucket.org/petsc/pkg-fblaslapack/get/v3.4.2-p3.tar.gz']
> > > > mumps ['git://https://bitbucket.org/petsc/pkg-mumps.git', '
> > > > https://bitbucket.org/petsc/pkg-mumps/get/v5.2.1-p2.tar.gz']
> > > > scalapack ['git://https://bitbucket.org/petsc/pkg-scalapack', '
> > > > https://bitbucket.org/petsc/pkg-scalapack/get/v2.1.0-p1.tar.gz']
> > > > Then run the script again
> > > > Satish
> > > > > Dear all,
> > > > > For 3.12 and 3.13, I get
> > > > > $ export PETSC_DIR=/home/user1/installers/petsc/petsc-3.13.0
> > > > > $ export PETSC_ARCH=linux-gnu-opt
> > > > > $ ./configure --with-cc=mpicc --with-fc=mpif90 -with-cxx=mpicxx
> > > > > --prefix=/home/user1/usr/local --with-make-np=10
> > --with-shared-libraries
> > --download-fblaslapack=/home/user1/installers/petsc/fblaslapack-3.4.2.tar.gz
> > > > > --download-mumps=/home/user1/installers/petsc/v5.1.2-p2.tar.gz
> > > > > --download-scalapack=/home/user1/installers/petsc/scalapack-2.0.2.tgz
> > > > > --with-debugging=0 COPTFLAGS='-O -O3 -march=native -mtune=native'
> > > > > FOPTFLAGS='-O -O3 -march=native -mtune=native' CXXOPTFLAGS='-O -O3
> > > > > Trying to
> > download
> > > > > file:///home/user1/installers/petsc/fblaslapack-3.4.2.tar.gz for
> > > > > FBLASLAPACK
> > > > > UNABLE to CONFIGURE with GIVEN OPTIONS (see
> > configure.log for
> > > > > details):
> > > > > Error during download/extract/detection of FBLASLAPACK:
> > > > > Could not locate downloaded package FBLASLAPACK in
> > /home/user1/installers/petsc/petsc-3.13.0/linux-gnu-opt/externalpackages
> > > > > Up to 3.11, these commands worked fine.
> > > > > Am I doing anything wrong?
> > > > > Thanks a lot!
