[petsc-users] Error in configure for --download-<pkg>=mydir
san.temporal at gmail.com
Fri Apr 17 15:17:29 CDT 2020
The point is that I cannot go through a proxy to simply use
--download-<pkg1> --download-<pkg2> ...
So I would:
1. Run configure with --download-<pkg1> ...
2. Wait until configure complains about the missing package and get the URL
3. wget the package
4. Add the local file name to --download-<pkg1>=...
Repeat one package after the other until I have all the packages locally.
I guess this should work. But then I get the error reported, starting with
3.12.
I am attaching configure.log
Thanks!
Santiago
On Fri, Apr 17, 2020 at 12:04 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Some package names have changed [when using git repos for both git and
> tarballs] - so its best to use the tarballs [or git repos] that are
> appropriate for the current petsc release.
> balay at sb /home/balay/petsc (maint=)
> $ ./configure --with-packages-download-dir=$HOME/tmp
> --download-fblaslapack --download-mumps --download-scalapack
> Configuring PETSc to compile on your system
> Download the following packages to /home/balay/tmp
> fblaslapack ['git://https://bitbucket.org/petsc/pkg-fblaslapack', '
> https://bitbucket.org/petsc/pkg-fblaslapack/get/v3.4.2-p3.tar.gz']
> mumps ['git://https://bitbucket.org/petsc/pkg-mumps.git', '
> https://bitbucket.org/petsc/pkg-mumps/get/v5.2.1-p2.tar.gz']
> scalapack ['git://https://bitbucket.org/petsc/pkg-scalapack', '
> https://bitbucket.org/petsc/pkg-scalapack/get/v2.1.0-p1.tar.gz']
> Then run the script again
> Satish
> On Fri, 17 Apr 2020, san.temporal at gmail.com wrote:
> > Dear all,
> > For 3.12 and 3.13, I get
> > $ export PETSC_DIR=/home/user1/installers/petsc/petsc-3.13.0
> > $ export PETSC_ARCH=linux-gnu-opt
> > $ ./configure --with-cc=mpicc --with-fc=mpif90 -with-cxx=mpicxx
> > --prefix=/home/user1/usr/local --with-make-np=10 --with-shared-libraries
> --download-fblaslapack=/home/user1/installers/petsc/fblaslapack-3.4.2.tar.gz
> > --download-mumps=/home/user1/installers/petsc/v5.1.2-p2.tar.gz
> > --download-scalapack=/home/user1/installers/petsc/scalapack-2.0.2.tgz
> > --with-debugging=0 COPTFLAGS='-O -O3 -march=native -mtune=native'
> > FOPTFLAGS='-O -O3 -march=native -mtune=native' CXXOPTFLAGS='-O -O3
> > Trying to download
> > file:///home/user1/installers/petsc/fblaslapack-3.4.2.tar.gz for
> > FBLASLAPACK
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > details):
> > Error during download/extract/detection of FBLASLAPACK:
> > Could not locate downloaded package FBLASLAPACK in
> > /home/user1/installers/petsc/petsc-3.13.0/linux-gnu-opt/externalpackages
> > Up to 3.11, these commands worked fine.
> > Am I doing anything wrong?
> > Thanks a lot!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200417/5443ac71/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200417/5443ac71/attachment-0001.obj>
