[petsc-users] Modification to ex11.c
Mark Adams
mfadams at lbl.gov
Fri Apr 17 09:57:47 CDT 2020
Line 1528 of dmplexsnes.c ?
On Fri, Apr 17, 2020 at 10:41 AM Matthew Knepley <knepley at gmail.com> wrote:
> Tried it again and works for me.
> Matt
> On Fri, Apr 17, 2020 at 10:39 AM Mark Adams <mfadams at lbl.gov> wrote:
>> Matt, that kink seems messed up.
>> On Fri, Apr 17, 2020 at 9:18 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> Mark is right, you could just add in a source term for each cell this
>>> way.
>>> If you really wanted a lower level interface, it would go here I think:
>>> https://gitlab.com/petsc/petsc/-/blob/master/src/snes/utils/dmplexsnes.c#L1528
>>> What would you want the interface to look like?
>>> Thanks,
>>> Matt
>>> On Fri, Apr 17, 2020 at 7:55 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> You can write your own DMPlexTSComputeRHSFunctionFVM method like this
>>>> and give that to the dm.
>>>> PetscErrorCode foo(DM dm, PetscReal time, Vec locX, Vec F, void *user)
>>>> PetscErrorCode ierr;
>>>> PetscFunctionBegin;
>>>> ierr = DMPlexTSComputeRHSFunctionFVM(dm, time, locX, F, user);CHKERRQ(ierr);
>>>> PetscFunctionReturn(0);
>>>> On Fri, Apr 17, 2020 at 5:28 AM MUKKUND SUNJII <mukkundsunjii at gmail.com>
>>>> wrote:
>>>>> Greetings,
>>>>> I had been working on ts/tutorials/ex11.c as part of my master’s
>>>>> thesis.
>>>>> In ex11.c, there is a 2D Shallow Water Model. I want to modify the
>>>>> model by adding a source term to the model. This source term would factor
>>>>> in the effects of bathymetry or bed elevation in addition to water height.
>>>>> I know how I will be able to achieve this if just use
>>>>> TSSetRHSFunction(). However ex11.c makes use of the Riemann Solver for the
>>>>> computation fluxes at the interfaces (therefore, it uses
>>>>> DMTSSetRHSFunctionLocal(dm, DMPlexTSComputeRHSFunctionFVM, user) ).
>>>>> Is there a routine that allows me to *add* a source term *for every
>>>>> cell* to the RHS function?
>>>>> Thank you in advance!
>>>>> Regards,
>>>>> Mukkund
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200417/9e21f1af/attachment.html>
