[petsc-users] Modification to ex11.c
Mark Adams mfadams at lbl.gov
Fri Apr 17 09:38:50 CDT 2020
Matt, that kink seems messed up.
On Fri, Apr 17, 2020 at 9:18 AM Matthew Knepley <knepley at gmail.com> wrote:
> Mark is right, you could just add in a source term for each cell this way.
> If you really wanted a lower level interface, it would go here I think:
> https://gitlab.com/petsc/petsc/-/blob/master/src/snes/utils/dmplexsnes.c#L1528
> What would you want the interface to look like?
>   Thanks,
>     Matt
> On Fri, Apr 17, 2020 at 7:55 AM Mark Adams <mfadams at lbl.gov> wrote:
>> You can write your own DMPlexTSComputeRHSFunctionFVM method like this and
>> give that to the dm.
>> PetscErrorCode foo(DM dm, PetscReal time, Vec locX, Vec F, void *user)
>>   PetscErrorCode ierr;
>>   PetscFunctionBegin;
>>   ierr = DMPlexTSComputeRHSFunctionFVM(dm, time, locX, F, user);CHKERRQ(ierr);
>>   PetscFunctionReturn(0);
>> On Fri, Apr 17, 2020 at 5:28 AM MUKKUND SUNJII <mukkundsunjii at gmail.com>
>> wrote:
>>> Greetings,
>>> I had been working on ts/tutorials/ex11.c as part of my master’s thesis.
>>> In ex11.c, there is a 2D Shallow Water Model. I want to modify the model
>>> by adding a source term to the model. This source term would factor in the
>>> effects of bathymetry or bed elevation in addition to water height.
>>> I know how I will be able to achieve this if just use
>>> TSSetRHSFunction(). However ex11.c makes use of the Riemann Solver for the
>>> computation fluxes at the interfaces (therefore, it uses
>>> DMTSSetRHSFunctionLocal(dm, DMPlexTSComputeRHSFunctionFVM, user) ).
>>> Is there a routine that allows me to *add* a source term *for every
>>> cell* to the RHS function?
>>> Thank you in advance!
>>> Regards,
>>> Mukkund
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200417/8309ecba/attachment.html>
