[petsc-users] dyld: Symbol not found: _MatCreate_MPIAIJViennaCL
Karl Rupp
rupp at iue.tuwien.ac.at
Wed Apr 15 21:43:57 CDT 2020
yes, Satish is right, this build is a CPU-build. Add `--with-opencl=1` :-)
Best regards,
Karli
On 4/16/20 12:31 AM, Satish Balay wrote:
> From prior e-mail - you wanted to use AMD GPU on OSX. This build below is CPU build - not for GPU. [Karl can confirm]
> I think OSX has OpenCL installed by default [perhaps via xcode?] - so you might just need the additional configure option: --with-opencl=1
> Satish
> On Thu, 16 Apr 2020, huabel via petsc-users wrote:
>> Hi Satish, that patch is good, thank you!
>>> On Apr 15, 2020, at 23:58, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --prefix=/Users/fire/opt/petsc313 --with-zlib --with-viennacl=1 --with-viennacl-dir=/Users/fire/opt/viennacl
>>> I guess you are running viennacl (opencl) on CPU.
>>> please try the attached patch.
>>> cd petsc
>>> patch -Np1 < viennacl.patch
>>> Or use branch balay/viennacl-cpu-check/maint in petsc repo
>>> Satish
>>> On Wed, 15 Apr 2020, huabel via petsc-users wrote:
>>>> Dear Users,
>>>> I’m try to use petsc3.13 with ViennaCL , when I try to run src/vec/vec/tutorials/ex1.c, I get next error, thanks.
>>>> Referenced from: /Users/fire/opt/petsc313/lib/libpetsc.3.13.dylib
>>>> Expected in: flat namespace
>>>> in /Users/fire/opt/petsc313/lib/libpetsc.3.13.dylib
>>>> [1] 22602 abort ./ex1
>>>> ➜ tutorials git:(master) ✗ ./ex1 -vec_type viennacl -mat_type aijviennacl
>>>> [1] 23268 abort ./ex1 -vec_type viennacl -mat_type aijviennacl
>>>> Thanks
>>>> Abel Hu
>>> <viennacl.patch>
