[petsc-users] inserting multiple rows together into a matrix
Matthew Knepley
knepley at gmail.com
Wed Apr 15 20:50:53 CDT 2020
On Wed, Apr 15, 2020 at 9:30 PM Bin Liu <lbllm2018 at hotmail.com> wrote:
> Sure. Thanks for your information. Actually, I used to call MatSetValues
> for each column. Since my matrix is sparse and I am not sure whether the
> non-zeros along each column are identical for each row, I am currently
> wondering if it is possible to insert the entire local dense matrix into
> the global sparse matrix using a single MatSetValues routine. Would it be
> more efficient than I identify the nonzeros and inserting them row-by-row?
> I may also set the “IGNORE_ZERO_ENTRIES” for the global sparse matrix
> before “MatSetValues”. Would it be helpful?
Inserting a dense matrix is likely the wrong thing to do. Generally
row-by-row insertion is good.
Matt
> Thanks for your helps.
> *From:* Matthew Knepley [mailto:knepley at gmail.com]
> *Sent:* Wednesday, 15 April 2020 7:01 PM
> *To:* Bin Liu <lbllm2018 at hotmail.com>
> *Cc:* Junchao Zhang <junchao.zhang at gmail.com>; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] inserting multiple rows together into a
> matrix
> On Wed, Apr 15, 2020 at 1:24 AM Bin Liu <lbllm2018 at hotmail.com> wrote:
> Thanks for your example. My problem is resolved. Meanwhile I am wondering,
> if it is possible to make this example more flexible. I mean what if the
> columns in each row are different? Is there any way to insert them all
> together?
> No. If the columns are different, you make a separate calls to
> MatSetValues().
> Thanks,
> Matt
> Regards
> Bin
> *From:* Junchao Zhang [mailto:junchao.zhang at gmail.com]
> *Sent:* Monday, 13 April 2020 11:33 PM
> *Cc:* petsc-users at mcs.anl.gov
> matrix
> Add two rows 2 ,4, and each row has three nonzeros at column 3, 7, 9
> m=2;
> n=3;
> idxm[] = {2, 4};
> idxn[] = {3, 7, 9};
> v[6] = {0.1, 0.2, ....};
> MatSetValues(mat, m, idxm, n, idxn,v, INSERT_VALUES);
> --Junchao Zhang
> On Mon, Apr 13, 2020 at 9:59 AM Bin Liu <lbllm2018 at hotmail.com> wrote:
> Hi all,
> I know how to insert values in one row into the matrix via routine
> “MatSetValues”. I understand I logically should be able to insert multiple
> rows into the matrix with one call of “MatSetValues”. However, I am not
> sure how to do it. I searched in the PETSc mail list and did not find a
> relevant question answered before. Could anyone help me and give me a
> simple example code?
> Regards
> B.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200415/dbd0b906/attachment-0001.html>
