[petsc-users] dyld: Symbol not found: _MatCreate_MPIAIJViennaCL
Satish Balay
balay at mcs.anl.gov
Wed Apr 15 17:31:12 CDT 2020
>From prior e-mail - you wanted to use AMD GPU on OSX. This build below is CPU build - not for GPU. [Karl can confirm]
I think OSX has OpenCL installed by default [perhaps via xcode?] - so you might just need the additional configure option: --with-opencl=1
Satish
On Thu, 16 Apr 2020, huabel via petsc-users wrote:
> Hi Satish, that patch is good, thank you!
> > On Apr 15, 2020, at 23:58, Satish Balay <balay at mcs.anl.gov> wrote:
> >> Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --prefix=/Users/fire/opt/petsc313 --with-zlib --with-viennacl=1 --with-viennacl-dir=/Users/fire/opt/viennacl
> > I guess you are running viennacl (opencl) on CPU.
> > please try the attached patch.
> > cd petsc
> > patch -Np1 < viennacl.patch
> > Or use branch balay/viennacl-cpu-check/maint in petsc repo
> > Satish
> > On Wed, 15 Apr 2020, huabel via petsc-users wrote:
> >> Dear Users,
> >> I’m try to use petsc3.13 with ViennaCL , when I try to run src/vec/vec/tutorials/ex1.c, I get next error, thanks.
> >> Referenced from: /Users/fire/opt/petsc313/lib/libpetsc.3.13.dylib
> >> Expected in: flat namespace
> >> in /Users/fire/opt/petsc313/lib/libpetsc.3.13.dylib
> >> [1] 22602 abort ./ex1
> >> ➜ tutorials git:(master) ✗ ./ex1 -vec_type viennacl -mat_type aijviennacl
> >> [1] 23268 abort ./ex1 -vec_type viennacl -mat_type aijviennacl
> >> Thanks
> >> Abel Hu
> > <viennacl.patch>
