[petsc-users] dyld: Symbol not found: _MatCreate_MPIAIJViennaCL
Satish Balay
balay at mcs.anl.gov
Wed Apr 15 10:58:11 CDT 2020
> Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --prefix=/Users/fire/opt/petsc313 --with-zlib --with-viennacl=1 --with-viennacl-dir=/Users/fire/opt/viennacl
I guess you are running viennacl (opencl) on CPU.
please try the attached patch.
cd petsc
patch -Np1 < viennacl.patch
Or use branch balay/viennacl-cpu-check/maint in petsc repo
Satish
On Wed, 15 Apr 2020, huabel via petsc-users wrote:
> Dear Users,
> I’m try to use petsc3.13 with ViennaCL , when I try to run src/vec/vec/tutorials/ex1.c, I get next error, thanks.
> Referenced from: /Users/fire/opt/petsc313/lib/libpetsc.3.13.dylib
> Expected in: flat namespace
> in /Users/fire/opt/petsc313/lib/libpetsc.3.13.dylib
> [1] 22602 abort ./ex1
> ➜ tutorials git:(master) ✗ ./ex1 -vec_type viennacl -mat_type aijviennacl
> [1] 23268 abort ./ex1 -vec_type viennacl -mat_type aijviennacl
> Thanks
> Abel Hu
diff --git a/config/BuildSystem/config/packages/viennacl.py b/config/BuildSystem/config/packages/viennacl.py
index aa614c7af8..9e3076cb50 100644
--- a/config/BuildSystem/config/packages/viennacl.py
+++ b/config/BuildSystem/config/packages/viennacl.py
@@ -41,10 +41,10 @@ class Configure(config.package.Package):
shutil.copytree(srcdir,destdir)
except RuntimeError as e:
raise RuntimeError('Error installing ViennaCL include files: '+str(e))
+ return self.installDir
+ def configureLibrary(self):
+ config.package.Package.configureLibrary(self)
#check for CUDA:
if not self.cuda.found:
self.addDefine('HAVE_VIENNACL_NO_CUDA', 1)
- return self.installDir
