[petsc-users] error with xlib
Mon Apr 13 12:19:47 CDT 2020
And here is a p4est build.
Satish
balay at kpro petsc % ./configure --with-mpi-dir=$HOME/soft/mpich-3.3.2 --with-zlib=1 --download-p4est
             Configuring PETSc to compile on your system
===============================================================================        ***** WARNING: You have an older version of Gnu make, it will work,        but may not support all the parallel testing options. You can install the        latest Gnu make with your package manager, such as brew or macports, or use        the --download-make option to get the latest Gnu make *****        ===============================================================================        ======
 =========================================================================        Trying to download git://https://bitbucket.org/petsc/pkg-sowing.git for SOWING        ===============================================================================        ===============================================================================        Running configure on SOWING; this may take several minutes        ===============================================================================        ===========
 ====================================================================        Running make on SOWING; this may take several minutes        ===============================================================================        ===============================================================================        Running make install on SOWING; this may take several minutes        ===============================================================================        ================
 ===============================================================        Trying to download git://https://github.com/tisaac/p4est for P4EST        ===============================================================================        ===============================================================================        Trying to bootstrap p4est using autotools; this may take several minutes        ===============================================================================        =====================
 ==========================================================        Running configure on P4EST; this may take several minutes        ===============================================================================        ===============================================================================        Running make on P4EST; this may take several minutes        ===============================================================================        ==========================
 =====================================================        Running make install on P4EST; this may take several minutes        ===============================================================================        Compilers:
  C Compiler:         /Users/balay/soft/mpich-3.3.2/bin/mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fno-stack-check -Qunused-arguments -fvisibility=hidden -g3
    Version: Apple clang version 11.0.0 (clang-1100.0.33.8)
  C++ Compiler:       /Users/balay/soft/mpich-3.3.2/bin/mpicxx  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fno-stack-check -fvisibility=hidden -g
  Fortran Compiler:   /Users/balay/soft/mpich-3.3.2/bin/mpif90  -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g
    Version: GNU Fortran (Homebrew GCC 9.3.0) 9.3.0
Linkers:
  Shared linker:   /Users/balay/soft/mpich-3.3.2/bin/mpicc  -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fno-stack-check -Qunused-arguments -fvisibility=hidden -g3
  Dynamic linker:   /Users/balay/soft/mpich-3.3.2/bin/mpicc  -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fno-stack-check -Qunused-arguments -fvisibility=hidden -g3
  Libraries linked against:   -lc++ -ldl
make:
  Version:  3.81
  /usr/bin/make
BlasLapack:
  Library:  -llapack -lblas
  Unknown if this uses OpenMP (try export OMP_NUM_THREADS=<1-4> yourprogram -log_view)
  uses 4 byte integers
MPI:
  Version:  3
  Includes: -I/Users/balay/soft/mpich-3.3.2/include
  Mpiexec: /Users/balay/soft/mpich-3.3.2/bin/mpiexec
  MPICH_NUMVERSION: 30302300
pthread:
X:
  Includes: -I/opt/X11/include
  Library:  -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -lX11
zlib:
  Library:  -lz
cmake:
  Version:  3.16.5
  /usr/local/bin/cmake
regex:
p4est:
  Includes: -I/Users/balay/petsc/arch-darwin-c-debug/include
  Library:  -Wl,-rpath,/Users/balay/petsc/arch-darwin-c-debug/lib -L/Users/balay/petsc/arch-darwin-c-debug/lib -lp4est -lsc
sowing:
  Version:  1.1.25
  /Users/balay/petsc/arch-darwin-c-debug/bin/bfort
  Language used to compile PETSc: C
PETSc:
  PETSC_ARCH: arch-darwin-c-debug
  PETSC_DIR: /Users/balay/petsc
  Scalar type: real
  Precision: double
  Integer size: 4 bytes
  shared libraries: enabled
  Memory alignment from malloc(): 16 bytes
xxx=========================================================================xxx
 Configure stage complete. Now build PETSc libraries with:
   make PETSC_DIR=/Users/balay/petsc PETSC_ARCH=arch-darwin-c-debug all
On Mon, 13 Apr 2020, Satish Balay via petsc-users wrote:
> you haven't sent any logs for this issue..
> [../arch-macosx-gnu-O-omp.py script or configure.log with the failure]
> Satish
> ipro:petsc balay$ ./configure --with-fortran-bindings=0 --with-mpi=0 --with-zlib=1
> ===============================================================================        ***** WARNING: You have an older version of Gnu make, it will work,        but may not support all the parallel testing options. You can install the        latest Gnu make with your package manager, such as brew or macports, or use        the --download-make option to get the latest Gnu make *****        ===============================================================================        Comp
 il
>  ers:
>   C Compiler:         gcc  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fno-stack-check -Qunused-arguments -fvisibility=hidden -g3
>     Version: Apple clang version 11.0.3 (clang-1103.0.32.29)
>   C++ Compiler:       g++  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fno-stack-check -fvisibility=hidden -g   -std=c++14
>   Fortran Compiler:   gfortran  -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g
> Linkers:
>   Shared linker:   gcc  -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fno-stack-check -Qunused-arguments -fvisibility=hidden -g3
>   Dynamic linker:   gcc  -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fno-stack-check -Qunused-arguments -fvisibility=hidden -g3
> make:
>   Version:  3.81
>   /usr/bin/make
> BlasLapack:
> pthread:
> zlib:
>   Library:  -lz
> cmake:
>   Version:  3.16.5
> X:
> regex:
> PETSc:
>   Scalar type: real
>   Precision: double
> ipro:petsc balay$
> On Mon, 13 Apr 2020, Mark Adams wrote:
> > On Mon, Apr 13, 2020 at 12:48 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > This is very funky
> > > Configure Options: --configModules=PETSc.Configure
> > > --optionsModule=config.compilerOptions
> > > --with-mpi-dir=/usr/local/Cellar/mpich/3.3.2 COPTFLAGS="-O2 -g
> > > -Xpreprocessor -fopenmp -I"$(brew --prefix libomp)/include" -L"$(brew
> > > --prefix libomp)/lib -lomp"" CXXOPTFLAGS="-O2 -g -Xpreprocessor -fopenmp
> > > -I"$(brew --prefix libomp)/include" -L"$(brew --prefix libomp)/lib -lomp""
> > > FOPTFLAGS="-O2 -g -Xpreprocessor -fopenmp -I"$(brew --prefix
> > > --download-parmetis=1 --download-metis=1 --download-hypre=1
> > > --download-triangle=1 --download-p4est=1 --download-zlib --with-x=0
> > > --download-ctetgen --with-debugging=0 --download-hdf5=1
> > > PETSC_ARCH=arch-macosx-gnu-O-omp --with-openmp=1 --with-log=0
> > > --with-threadsafety --download-chaco
> > > -I"$(brew --prefix libomp)/include" type options to configure doesn't make
> > > sense. You are using bash syntax here - and expecting configure to resolve
> > > it. Its best for your bash shell to evaluate this before passing this info
> > > to configure
> > > Also --download-zlib isn't needed on OSX
> > Hum, I get:
> > 12:52 mark/feature-xgc-interface-rebase *= ~/Codes/petsc$
> > TESTING: configureExternalPackagesDir from
> > config.framework(config/BuildSystem/config/framework.py:911)
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> > details):
> > Package p4est requested but dependency zlib not requested. Perhaps you want
> > --download-zlib
> > > Satish
> > > > Now that I look at it, I see:
> > > > CFLAGS="-fstack-protector -fno-stack-check -Qunused-arguments -O2 -g
> > > > prefix="/Users/markadams/Codes/petsc/arch-macosx-gnu-O-omp"
> > > > Note the two ". That does not look right. I use
> > > > 'COPTFLAGS=-O2 -g  -Xpreprocessor -fopenmp -I"$(brew --prefix
> > > > libomp)/include" -L"$(brew --prefix libomp)/lib -lomp" ',
> > > > I know how to do stuff like:
> > > > '--with-blaslapack-lib=-L' + os.environ['OLCF_NETLIB_LAPACK_ROOT'] +
> > > > '/lib64 -lblas -llapack'
> > > > Is there like and os.exec that I could use like this for my FLAGS?
> > > > On Mon, Apr 13, 2020 at 11:46 AM Matthew Knepley <knepley at gmail.com>
> > > wrote:
> > > > > On Mon, Apr 13, 2020 at 11:34 AM Mark Adams <mfadams at lbl.gov> wrote:
> > > > >> I get this error configuring zlib, osx, with OpenMP.
> > > > >> Any ideas?
> > > > > This failed without output
> > > > > Executing: cd
> > > /Users/markadams/Codes/petsc/arch-macosx-gnu-O-omp/externalpackages/zlib-1.2.11
> > > > > && CC="/usr/local/Cellar/mpich/3.3.2/bin/mpicc"
> > > > > -fno-stack-check -Qunused-arguments -O2 -g -Xpreprocessor -fopenmp
> > > -lomp""
> > > ./configure  &&
> > > > > /usr/bin/make -j7 -l12.0 &&  /usr/bin/make install
> > > > > So execute each step in turn and see what fails.
> > > > >   Thanks,
> > > > >      Matt
> > > > >> Thanks,
> > > > >> Mark
> > > > > What most experimenters take for granted before they begin their
> > > > > experiments is infinitely more interesting than any results to which
> > > their
> > > > > experiments lead.
> > > > > -- Norbert Wiener
> > > > > https://www.cse.buffalo.edu/~knepley/
> > > > > <http://www.cse.buffalo.edu/~knepley/>
