[petsc-users] Adaptivity Options in ex11.c
MUKKUND SUNJII mukkundsunjii at gmail.com
Mon Apr 13 05:54:57 CDT 2020
Greetings,
I have been trying to add on to the functionality of the adaptive grid solver featured in the ts/tutorials/ex11.c.
I noticed that there is not an option to set the initial, minimum or maximum refinement levels in the adaptToleranceFVM() function where the grid adaption operation takes place. When I use the function DMForestSetMaximumRefinement(…), I am returned with the error saying that the 'DM has already been set up'.
As a result, I looked into the DMForest tests and tutorials. I found that in dm/impls/forest/tests/ex2.c, various DMForests functions are being used. Nevertheless, the flow of operations of the grid adaption process is a bit different. In the test file, three DM objects are used : Base DM - PreForest DM - PostForest DM. Parameters such as the initial, and minimum refinement levels are assigned to the PreForest DM before it is set up. But in adaptToleranceFVM()  in ex11.c, only 2 DM objects are used and hence these parameters cannot be assigned (i.e., the objects used are plex and adaptedDM).
I tried to replicate the Base DM - PreForest DM - PostForest DM structure in adaptToleranceFVM() . However, I am returned with a multitude of errors. I do not include the error statements as I suspect that there is a fundamental problem with my adaption routine and a specific error won’t indicate the bigger problem.
In order to not be verbose in the email, I have included the GitHub link of the code that I have been working on. You can find the adaptToleranceFVM() in lines 1542 to 1739. I’d very much appreciate any feedback or suggestions on this segment.
Github Link : https://github.com/mukkund1996/petsc/blob/cbcf8824f12d1159c0f5dc84d028a4869a2a0594/amr/ex11_adapt_param.c#L1542
Thank you in advanced.
Mukkund Sunjii
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200413/e93af0d8/attachment.html>
