[petsc-users] J^T J p calculation
Jed Brown jed at jedbrown.org
Thu Apr 9 16:20:24 CDT 2020
"Park, Heeho via petsc-users" <petsc-users at mcs.anl.gov> writes:
> Hi PETSc developers,
> I am trying to formulate
> p^T J^T J p
> where p is a solution vector length n, J is Jacobian n-by-n matrix.
> Ref: https://en.wikipedia.org/wiki/Gauss%E2%80%93Newton_algorithm under Large-scale optimization
> It is known that for parallel computations, the best way to perform this computation (with csr matrix) is
> J^T J p = SUM_i [ c_i ( c_i dot p) ] which results in a vector.
Sounds like you just want to apply J^T J to a vector, not compute it as
a matrix (e.g., for preconditioning).  You can solve such systems with
KSPLSQR, but the preconditioner is normally constructed using J^T J (or
an approximation thereof).
If you wast want to apply the operator to a matrix, use J^T (J p), which
is much more efficient ("it is known" notwithstanding).
