[petsc-users] DMPlex partition problem
Matthew Knepley
knepley at gmail.com
Wed Apr 8 18:50:32 CDT 2020
On Wed, Apr 8, 2020 at 7:47 PM Danyang Su <danyang.su at gmail.com> wrote:
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Wednesday, April 8, 2020 at 4:41 PM
> *To: *Danyang Su <danyang.su at gmail.com>
> *Cc: *PETSc <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] DMPlex partition problem
> On Wed, Apr 8, 2020 at 5:52 PM Danyang Su <danyang.su at gmail.com> wrote:
> Hi Matt,
> I am one step closer now. When run the ex1 code with ‘-interpolate’, the
> partition is good, without it, it’s weird.
> Crap! That did not even occur to me. Yes, the dual graph construction
> will not work for uninterpolated wedges.
> So, do you really need an uninterpolated mesh? If so, I can put it on the
> buglist.
> For Prism mesh, I am afraid so. For 2D triangle mesh and 3D tetra mesh,
> the partition is pretty good without interpolate. That’s why I didn’t have
> problem for all my previous simulations using the other cell types.
What I mean is, are you avoiding interpolating the mesh for memory? The
amount of memory is usually small compared to
fields on the mesh.
Matt
> Thanks,
> Danyang
> Thanks,
> Matt
> Thanks,
> Danyang
> *From: *Danyang Su <danyang.su at gmail.com>
> *Date: *Wednesday, April 8, 2020 at 2:12 PM
> *To: *Matthew Knepley <knepley at gmail.com>
> Hi Matt,
> Attached is another prism mesh using 8 processors. The partition of the
> lower mesh does not looks good.
> Thanks,
> Danyang
> *Date: *Wednesday, April 8, 2020 at 1:50 PM
> Hi Matt,
> Here is what I get using ex1c with stencil 0. There is no change in the
> source code. I just compile and run the code in different ways. By using
> ‘make -f ./gmakefile ….’, it works as expected. However, by using ‘make
> ex1’ and then run the code using ‘mpiexec -n …’, the partition does not
> looks good. My code has the same problem as this one if I use prism mesh.
> I just wonder what makes this difference, even without overlap.
> Thanks,
> Danyang
> *Date: *Wednesday, April 8, 2020 at 1:32 PM
> *Date: *Wednesday, April 8, 2020 at 12:50 PM
> On Wed, Apr 8, 2020 at 3:22 PM Danyang Su <danyang.su at gmail.com> wrote:
> Hi Matt,
> Here is something pretty interesting. I modified ex1.c file with output of
> number of nodes and cells (as shown below) . And I also changed the
> stencil size to 1.
> /* get coordinates and section */
> ierr = DMGetCoordinatesLocal(*dm,&gc);CHKERRQ(ierr);
> ierr = DMGetCoordinateDM(*dm,&cda);CHKERRQ(ierr);
> ierr = DMGetSection(cda,&cs);CHKERRQ(ierr);
> ierr = PetscSectionGetChart(cs,&istart,&iend);CHKERRQ(ierr);
> num_nodes = iend-istart;
> num_cells = istart;
> /* Output rank and processor information */
> printf("rank %d: of nprcs: %d, num_nodes %d, num_cess %d\n", rank, size,
> num_nodes, num_cells);
> If I compile the code using ‘make ex1’ and then run the test using ‘mpiexec
> -n 2 ./ex1 -filename basin2layer.exo’, I get the same problem as the
> modified ex1f90 code I sent.
> *➜* *tests* mpiexec -n 2 ./ex1 -filename basin2layer.exo
> rank 1: of nprcs: 2, num_nodes 699, num_cess 824
> rank 0: of nprcs: 2, num_nodes 699, num_cess 824
> Ah, I was not looking closely. You are asking for a cell overlap of 1 in
> the partition. That is why these numbers sum to more than
> the total in the mesh. Do you want a cell overlap of 1?
> Yes, I need cell overlap of 1 in some circumstance. The mesh has two
> layers of cells with 412 cells per layer and three layers of nodes with
> 233 nodes per layer. The number of cells looks good to me. I am confused
> why the same code generates pretty different partition. If I set the
> stencil to 0, I get following results. The first method looks good and the
> second one is not a good choice, with much more number of ghost nodes.
> *➜* *petsc-3.13.0* make -f ./gmakefile test
> globsearch="dm_impls_plex_tests-ex1_cylinder" EXTRA_OPTIONS="-filename
> ./basin2layer.exo -dm_view hdf5:$PWD/mesh.h5 -dm_partition_view" NP=2
> # > rank 1: of nprcs: 2, num_nodes 354, num_cess 392
> # > rank 0: of nprcs: 2, num_nodes 384, num_cess 432
> ➜ tests mpiexec -n 2 ./ex1 -filename basin2layer.exo
> rank 0: of nprcs: 2, num_nodes 466, num_cess 412
> rank 1: of nprcs: 2, num_nodes 466, num_cess 412
> I think this might just be a confusion over interpretation. Here is how
> partitioning works:
> 1) We partition the mesh cells using ParMetis, Chaco, etc.
> 2) We move those cells (and closures) to the correct processes
> 3) If you ask for overlap, we mark a layer of adjacent cells on remote
> processes and move them to each process
> The original partitions are the same, Then we add extra cells, and their
> closures, to each partition. This is what you are asking for.
> You would get the same answer with GMsh if it gave you an overlap region.
> Thanks,
> Matt
> Thanks,
> Danyang
> Thanks,
> Matt
> *➜* *tests* mpiexec -n 4 ./ex1 -filename basin2layer.exo
> rank 1: of nprcs: 4, num_nodes 432, num_cess 486
> rank 0: of nprcs: 4, num_nodes 405, num_cess 448
> rank 2: of nprcs: 4, num_nodes 411, num_cess 464
> rank 3: of nprcs: 4, num_nodes 420, num_cess 466
> However, if I compile and run the code using the script you shared, I get
> reasonable results.
> # > rank 0: of nprcs: 2, num_nodes 429, num_cess 484
> # > rank 1: of nprcs: 2, num_nodes 402, num_cess 446
> ./basin2layer.exo -dm_view hdf5:$PWD/mesh.h5 -dm_partition_view" NP=4
> # > rank 1: of nprcs: 4, num_nodes 246, num_cess 260
> # > rank 2: of nprcs: 4, num_nodes 264, num_cess 274
> # > rank 3: of nprcs: 4, num_nodes 264, num_cess 280
> # > rank 0: of nprcs: 4, num_nodes 273, num_cess 284
> Is there some difference in compiling or runtime options that cause the
> difference? Would you please check if you can reproduce the same problem
> using the modified ex1.c?
> Thanks,
> Danyang
> *Date: *Wednesday, April 8, 2020 at 9:37 AM
> *Date: *Wednesday, April 8, 2020 at 9:20 AM
> On Wed, Apr 8, 2020 at 12:13 PM Danyang Su <danyang.su at gmail.com> wrote:
> *Date: *Wednesday, April 8, 2020 at 6:45 AM
> On Wed, Apr 8, 2020 at 7:25 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Apr 8, 2020 at 12:48 AM Danyang Su <danyang.su at gmail.com> wrote:
> Dear All,
> Hope you are safe and healthy.
> I have a question regarding pretty different partition results of prism
> mesh. The partition in PETSc generates much more ghost nodes/cells than the
> partition in Gmsh, even though both use metis as partitioner. Attached
> please find the prism mesh in both vtk and exo format, the test code
> modified based on ex1f90 example. Similar problem are observed for larger
> dataset with more layers.
> I will figure this out by next week.
> I have run your mesh and do not get those weird partitions. I am running
> in master. What are you using? Also, here is an easy way
> to do this using a PETSc test:
> cd $PETSC_DIR
> make -f ./gmakefile test globsearch="dm_impls_plex_tests-ex1_cylinder"
> EXTRA_OPTIONS="-filename ${HOME}/Downloads/basin2layer.exo -dm_view
> hdf5:$PWD/mesh.h5 -dm_partition_view" NP=5
> ./lib/petsc/bin/petsc_gen_xdmf.py mesh.h5
> and then load mesh.xmf into Paraview. Here is what I see (attached). Is it
> possible for you to try the master branch?
> Hi Matt,
> Thanks for your quick response. If I use your script, the partition looks
> good, as shown in the attached figure. I am working on PETSc 3.13.0 release
> version on Mac OS.
> Does the above script use code /petsc/src/dm/label/tutorials/ex1c.c?
> It uses $PETSC_DIR/src/dm/impls/plex/tests/ex1.c
> I looked at your code and cannot see any difference. Also, no changes are
> in master that are not in 3.13. This is very strange.
> I guess we will have to go one step at a time between the example and your
> code.
> I will add mesh output to the ex1f90 example and check if the cell/vertex
> rank is exactly the same. I wrote the mesh output myself based on the
> partition but there should be no problem in that part. The number of ghost
> nodes and cells is pretty easy to check. Not sure if there is any
> difference between the C code and Fortran code that causes the problem.
> Anyway, I will keep you updated.
> Thanks,
> Matt
> Thanks,
> Matt
> Thanks,
> Matt
> For example, in Gmsh, I get partition results using two processors and
> four processors as shown below, which are pretty reasonable.
> However, in PETSc, the partition looks a bit weird. Looks like it takes
> layer partition first and then inside layer. If the number of nodes per
> layer is very large, this kind of partitioning results into much more ghost
> nodes/cells.
> Anybody know how to improve the partitioning in PETSc? I have tried
> parmetis and chaco. There is no big difference between them.
> Thanks,
> Danyang
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/89c5d34a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/89c5d34a/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/89c5d34a/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/89c5d34a/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/89c5d34a/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200408/89c5d34a/attachment-0009.png>
