[petsc-users] strange TS adaptivity behavior
Jed Brown
jed at jedbrown.org
Mon Apr 6 14:48:01 CDT 2020
This typically happens when your model is discontinuous or you activate
some fast transitien. You have a really aggressive lower bound on your
time step so its hard to tell here.
Mark Adams <mfadams at lbl.gov> writes:
> I have a problem that is fairly smooth and when it decreases the time step
> it just keeps decreasing almost forever. I wanted to see if anyone has any
> clue what is going on here.
> This test reaches a quasi equilibrium and the adaptivity uses fairly large
> time steps with dU/dt - F(u,t) = 0. I set a max time step of 10. A source
> starts at one point (dU/dt - F(u,t) = S(t)). It cools pretty fast.
> THe truncation error increase a lot when the source starts but it does not
> decrease the time step immediately because I had a mat time step set:
> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 4
> [0] TSAdaptChoose_Basic(): Estimated scaled local *truncation error
> 0.000214757*, accepting step of size 10.
> TSAdapt basic arkimex 0:1bee step *386* accepted t=2292.68 +
> 1.000e+01 dt=1.000e+01 wlte=0.000215 wltea= -1 wlter= -1
> 0.500399,* accepting step of size 10.
> TSAdapt basic arkimex 0:1bee step *387* accepted t=2302.68 +
> 1.000e+01 dt=1.000e+01 wlte= 0.5 wltea= -1 wlter= -1
> 388) species-0: charge density= -1.6422881272166e+01 z-momentum=
> 7.2180929658011e-03 energy= 9.7881753794625e+05
> It goes for another few time steps before it rejects the time step for the
> first time, and then it just keeps reducing and reducing:
> [0] TSAdaptChoose_Basic(): Estimated scaled local truncation error
> 0.939966, accepting step of size 10.
> TSAdapt basic arkimex 0:1bee step *395* accepted t=2382.68 +
> 1.000e+01 dt=9.283e+00 wlte= 0.94 wltea= -1 wlter= -1
> [0] TSAdaptChoose_Basic(): Estimated scaled local truncation error 1.33533,
> *rejecting* step of size 9.28296
> TSAdapt basic arkimex 0:1bee step *396* rejected t=2392.68 +
> 9.283e+00 dt=7.230e+00 wlte= 1.34 wltea= -1 wlter= -1
> [0] TSAdaptChoose_Basic(): Estimated scaled local truncation error 1.44054,
> *rejecting* step of size 7.22994
> 7.230e+00 dt=2.711e+00 wlte= 1.44 wltea= -1 wlter= -1
> [0] TSAdaptChoose_Basic(): Estimated scaled local truncation error 1.63529,
> *rejecting* step of size 2.71072
> 2.711e+00 dt=9.539e-01 wlte= 1.64 wltea= -1 wlter= -1
> [0] TSAdaptChoose_Basic(): Estimated scaled local truncation error 1.60415,
> *rejecting* step of size 0.953894
> 9.539e-01 dt=5.000e-01 wlte= 1.6 wltea= -1 wlter= -1
> 1.49714, *accepting
> because step size 0.5 is at minimum*
> TSAdapt basic arkimex 0:1bee step *396* accepted t=2392.68 +
> 5.000e-01 dt=5.000e-01 wlte= 1.5 wltea= -1 wlter= -1
> Anyone have any idea what is going on here?
> Thanks,
> Mark
