[petsc-users] deactivating x11 in PETSc 3.13.0 with pastix/hwloc
Alfredo Jaramillo
ajaramillopalma at gmail.com
Mon Apr 6 13:23:43 CDT 2020
Hello Satish, Im sorry but I think I tested this workaround with the wrong
installation, my bad.
In fact the libXNVC, X11 libraries are still being linked even with the
--download-hwloc-configure-arguments=--without-x option
Im attaching the config.log file located in
$PETSC_DIR/$PETSC_ARCH/externalpackages/hwloc-2.1.0
you can see that the option --without-x is there (line 7) but by means of
$ ldd foo
I see that the links are still there
On Mon, Apr 6, 2020 at 2:57 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Great!
> Wrt pastix dependency on hwloc -
> config/BuildSystem/config/packages/PaStiX.py has the following comment:
> # PaStiX.py does not absolutely require hwloc, but it performs better
> with it and can fail (in ways not easily tested) without it
> https://gforge.inria.fr/forum/forum.php?thread_id=32824&forum_id=599&group_id=186
> # https://solverstack.gitlabpages.inria.fr/pastix/Bindings.html
> I have a fix in branch balay/fix-hwloc-x-dependency/maint [that does not
> need the extra --download-hwloc-configure-arguments=--without-x option].
> Can you give this a try?
> Satish
> On Mon, 6 Apr 2020, Alfredo Jaramillo wrote:
> > hello Satish,
> > adding
> > worked perfectly
> > thank you!
> > On Mon, Apr 6, 2020 at 2:12 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > you can try:
> > > --download-pastix --download-hwloc
> > > We should fix this to automatically use --with-x=0/1
> > > Satish
> > > > hello everyone,
> > > > I have a fresh installation of the 3.13.0 version with pastix. Like
> with
> > > > previous versions, I'm using the options
> > > > --with-x11=0 --with-x=0 --with-windows-graphics=0
> > > > to disable X11
> > > > however, when compiling my program foo and doing
> > > > $ ldd foo
> > > > between the linked libraries there appear:
> > > > libXNVCtrl.so.0 and libX11.so.6
> > > > the first one related to NVIDIA. I observed that this does not happen
> > > when
> > > > installing PETSc without hwloc. In this new version, PETSc requires
> to
> > > > install hwloc when trying to install pastix. In previous versions of
> > > PETSc
> > > > (eg 3.11.2) that wasn't necessary.
> > > > I'm working in a cluster where I have no access to these X11-related
> > > > libraries and that's why I need them not be linked. Is it there some
> way
> > > to
> > > > disable X11 when installing hwloc? maybe enforcing some configuration
> > > > variables when installing it through petsc or installing it
> > > independently?
> > > > thanks a lot!
> > > > Below the configuration command of the two installations I've tried
> with
> > > > the 3.13.0 version.
> > > > =================== WITH PASTIX ===================
> > > > ./configure --with-make-np=20
> > > > --with-petsc-arch=x64go-3.13-openmpi-4.0.1-pastix-64
> --with-debugging=0
> > > > --doCleanup=0 \
> > > > --with-mpi=1 \
> > > > --with-valgrind=1
> --with-valgrind-dir=$PATH_TO_VALGRIND/valgrind-3.15.0 \
> > > > --download-scalapack \
> > > > --download-openblas \
> > > > --download-mumps \
> > > > --download-superlu_dist \
> > > > --download-metis \
> > > > --download-parmetis \
> > > > --download-ptscotch \
> > > > --download-hypre \
> > > > *--download-pastix \--download-hwloc \*
> > > > --with-64-bit-indices=1 \
> > > > LDFLAGS=$LDFLAGS CPPFLAGS=$CPPFLAGS \
> > > > --with-cxx-dialect=C++11 \
> > > > --with-x11=0 --with-x=0 --with-windows-graphics=0 \
> > > > COPTFLAGS="-O3 -march=native -mtune=native" \
> > > > CXXOPTFLAGS="-O3 -march=native -mtune=native" \
> > > > FOPTFLAGS="-O3 -march=native -mtune=native"
> > > > =================== WITHOUT PASTIX ===================
> > > > the same as above but the options "--download-pastix
> --download-hwloc"
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200406/8ddd2fe7/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200406/8ddd2fe7/attachment-0001.bin>
