[petsc-users] Discontinuities in the Jacobian matrix for nonlinear problem
Alexander B Prescott
alexprescott at email.arizona.edu
Mon Apr 6 13:04:42 CDT 2020
Hello,
The non-linear boundary-value problem I am applying PETSc to is a
relatively simple steady-state flow routing algorithm based on the
continuity equation, such that Div(Q) = 0 everywhere (Q=discharge). I use a
finite volume approach to calculate flow between nodes, with Q calculated
as a piecewise smooth function of the local flow depth and the
water-surface slope. In 1D, the residual is calculated as R(x_i)=Q_i-1/2 -
Q_i+1/2.
For example, Q_i-1/2 at x[i]:
Q_i-1/2 proportional to sqrt(x[i-1] + z[i-1] - (x[i] + z[i])),
if x[i-1]+z[i-1] > x[i]+z[i]
Q_i-1/2 proportional to -1.0*sqrt(x[i] + z[i] - (x[i-1] + z[i-1])),
if x[i]+z[i] > x[i-1]+z[i-1]
Where z[i] is local topography and doesn't change over the iterations, and
Q_i+1/2 is computed analogously. So the residual derivatives with respect
to x[i-1], x[i] and x[i+1] are not continuous when the water-surface slope
= 0.
Are there intelligent ways to handle this problem? My 1D trial runs naively
fix any zero-valued water-surface slopes to a small non-zero positive value
(e.g. 1e-12). Solver convergence has been mixed and highly dependent on the
initial guess. So far, FAS with QN coarse solver has been the most robust.
Restricting x[i] to be non-negative is a separate issue, to which I have
applied the SNES_VI solvers. They perform modestly but have been less
robust.
Best,
Alexander
Alexander Prescott
PhD Candidate, The University of Arizona
Department of Geosciences
1040 E. 4th Street
Tucson, AZ, 85721
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200406/e0a9d703/attachment.html>
