[petsc-users] Error Installing Petsc4Py
Lisandro Dalcin dalcinl at gmail.com
Thu Apr 2 15:47:28 CDT 2020
Please note that I have not released yet petsc4py-3.13, so pip install will
not work with latest PETSc release 3.13
On Thu, 2 Apr 2020 at 20:48, Satish Balay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Which version of petsc and which version of petsc4py is this?
> Lisandro can help with pip issues.
> Just want to mention an alternate mode that you might want to try:
> --download-petsc4py option to petsc configure
> Satish
> On Thu, 2 Apr 2020, Kyle Michael Booker wrote:
> > Hello,
> > I've been trying to install petsc4py for the past several days and have
> had the following errors installing:
> > "Command "/usr/bin/python -u -c "import setuptools,
> tokenize;__file__='/tmp/pip-build-0eWEiE/petsc4py/setup.py';f=getattr(tokenize,
> 'open', open)(__file__);code=f.read().replace('\r\n',
> '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record
> /tmp/pip-oUZMRL-record/install-record.txt
> --single-version-externally-managed --compile --user --prefix=" failed with
> error code 1 in /tmp/pip-build-0eWEiE/petsc4py/"
> > I currently have petsc installed correctly as well as mpich, it is just
> getting petsc4py installed that I have problems with. Any help would be
> greatly appreciated.
> > Sincerely,
> > Kyle
Lisandro Dalcin
Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200402/31681ffa/attachment.html>
