[petsc-users] [petsc-maint] petsc ksp solver hangs
Michael Wick
michael.wick.1980 at gmail.com
Sun Sep 29 00:28:49 CDT 2019
Thank you all for the reply.
I am trying to get the backtrace. However, the code hangs totally randomly,
and it hangs only when I run large simulations (e.g. 72 CPUs for this one).
I am trying very hard to get the error message.
So far, I can pin-point that the issue is related with hypre, and a static
build of the petsc library. Switching to a dynamic build works fine so far.
Also, using a naked gmres works. Does anyone have similar issues before?
On Sat, Sep 28, 2019 at 6:28 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> In my experience, an hanging execution may results from seterrq being
> called with the wrong communicator. Anyway, it would be useful to get the
> output of -log_trace .
> Also, does it hang when -pc_type none is specified?
> Il Sab 28 Set 2019, 16:22 Zhang, Junchao via petsc-users <
> petsc-users at mcs.anl.gov> ha scritto:
>> Does it hang with 2 or 4 processes? Which PETSc version do you use
>> (using the latest is easier for us to debug)? Did you configure PETSc with
>> --with-debugging=yes COPTFLAGS="-O0 -g" CXXOPTFLAGS="-O0 -g"
>> After attaching gdb to one process, you can use bt to see its stack
>> trace.
>> --Junchao Zhang
>> On Sat, Sep 28, 2019 at 5:33 AM Michael Wick <michael.wick.1980 at gmail.com>
>> wrote:
>>> I attached a debugger to my run. The code just hangs without throwing an
>>> error message, interestingly. I uses 72 processors. I turned on the ksp
>>> monitor. And I can see it hangs either at the beginning or the end of KSP
>>> iteration. I also uses valgrind to debug my code on my local machine, which
>>> does not detect any issue. I uses fgmres + fieldsplit, which is really a
>>> standard option.
>>> Do you have any suggestions to do?
>>> On Fri, Sep 27, 2019 at 8:17 PM Zhang, Junchao <jczhang at mcs.anl.gov>
>>> wrote:
>>>> How many MPI ranks did you use? If it is done on your desktop, you can
>>>> just attach a debugger to a MPI process to see what is going on.
>>>> --Junchao Zhang
>>>> On Fri, Sep 27, 2019 at 4:24 PM Michael Wick via petsc-maint <
>>>> petsc-maint at mcs.anl.gov> wrote:
>>>>> Hi PETSc:
>>>>> I have been experiencing a code stagnation at certain KSP iterations.
>>>>> This happens rather randomly, which means the code may stop at the middle
>>>>> of a KSP solve and hangs there.
>>>>> I have used valgrind and detect nothing. I just wonder if you have any
>>>>> suggestions.
>>>>> Thanks!!!
>>>>> M
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190928/a2f8f20e/attachment.html>
