[petsc-users] DIVERGED_LINEAR_SOLVE in SNES
Li Luo li.luo at kaust.edu.sa
Sat Sep 28 05:22:44 CDT 2019
Thank you! It works.
Best,
Li
On Sat, Sep 28, 2019 at 8:12 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 27, 2019 at 9:19 AM Li Luo via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Thank you for the suggestions, I'll try it.
> I think an easier way to do what you want is
>   -snes_max_linear_solve_fail 10
> from
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetMaxLinearSolveFailures.html
>   Thanks,
>      Matt
>> Best,
>> Li
>> On Fri, Sep 27, 2019 at 5:27 AM Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>>>   Li,
>>>    It is possible, but as Hong said probably never appropriate.
>>> Especially if KSP has iterated for 10,000 iterations. If you want SNES to
>>> "try" the direction given by a failed solve you should use a much smaller
>>> maximum number of iterations for KSP.
>>>    Anways, to do what you desire
>>> #include <petsc/private/kspimpl.h>
>>> call KSPSetPostSolve() and in your post solve() function simply do
>>> ksp->reason = KSP_CONVERGED_ITS.
>>>  Barry
>>> > On Sep 26, 2019, at 10:58 AM, Zhang, Hong via petsc-users <
>>> > Li :
>>> > You can use '-ksp_max_it 20000' to change maximum iteration count.
>>> However, it does not make sense to continue after it fails at 10000
>>> iterations. You should figure out why linear solver diverges. Run your code
>>> with '-ksp_monitor' or '-ksp_monitor_true_residual'.
>>> > Hong
>>> > Dear developer,
>>> > I am using SNES for solving a nonlinear system.  For some cases, SNES
>>> diverged -3 with "DIVERGED_LINEAR_SOLVE" when the linear solver reached its
>>> maximum iteration count (i.e -ksp_max_it 10000).
>>> > Is that possible to let SNES continue even though the linear solver
>>> reaches the maximum number of iterations? Just take the result at 10000 for
>>> the Jacobian solution and then update the Newton step?
>>> > Best,
>>> > Li
>>> > This message and its contents, including attachments are intended
>>> solely for the original recipient. If you are not the intended recipient or
>>> have received this message in error, please notify me immediately and
>>> delete this message from your computer system. Any unauthorized use or
>>> distribution is prohibited. Please consider the environment before printing
>>> this email.
>> Postdoctoral Fellow
>> Extreme Computing Research Center
>> King Abdullah University of Science & Technology
>> https://sites.google.com/site/rolyliluo/
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this email.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Postdoctoral Fellow
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190928/c1a5eb98/attachment-0001.html>
