[petsc-users] TS scheme with different DAs
Manuel Valera
mvalera-w at sdsu.edu
Tue Sep 24 14:58:07 CDT 2019
Hello all,
I finally implemented the TS routine operating in several DAs at the same
time, hacking it as you suggested. I still have a problem with my algorithm
though. It is not DMDA related so there's that.
My algorithm needs to update u,v,w with information from the updated
T,S,rho. My problem, or what I don't understand yet, is how to operate in
the intermediate runge-kutta time integration states inside the
RHSFunction.
If I can be more clear, I would need the intermediate T,S states to obtain
an updated rho (density) to in turn, obtain the correct intermediate
velocities, and keep the loop going. As I understand right now, the RHS
vector is different from this intermediate state, and it would be only the
RHS input to the loop, so operating on this would be incorrect.
As of now, my algorithm still creates artifacts because of this lack of
information to accurately update all of the variables at the same time. The
problem happens as well in serial.
Thanks for your help,
On Wed, Sep 18, 2019 at 4:36 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Sep 17, 2019 at 8:27 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> Don't be too quick to dismiss switching to the DMStag you may find that
>> it actually takes little time to convert and then you have a much less
>> cumbersome process to manage the staggered grid. Take a look at
>> src/dm/impls/stag/examples/tutorials/ex2.c where
>> const PetscInt dof0 = 0, dof1 = 1,dof2 = 1; /* 1 dof on each edge and
>> element center */
>> const PetscInt stencilWidth = 1;
>> ierr =
>> DMStagCreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,7,9,PETSC_DECIDE,PETSC_DECIDE,dof0,dof1,dof2,DMSTAG_STENCIL_BOX,stencilWidth,NULL,NULL,&dmSol);CHKERRQ(ierr);
>> BOOM, it has set up a staggered grid with 1 cell centered variable and 1
>> on each edge. Adding more the cell centers, vertices, or edges is trivial.
>> If you want to stick to DMDA you
>> "cheat". Depending on exactly what staggering you have you make the DMDA
>> for the "smaller problem" as large as the other ones and just track zeros
>> in those locations. For example if velocities are "edges" and T, S are on
>> cells, make your "cells" DMDA one extra grid width wide in all three
>> dimensions. You may need to be careful on the boundaries deepening on the
>> types of boundary conditions.
> Yes, SNES ex30 does exactly this. However, I still recommend looking at
> DMStag. Patrick created it because managing the DMDA
> became such as headache.
> Thanks,
> Matt
>> > On Sep 17, 2019, at 7:04 PM, Manuel Valera via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> > Thanks Matthew, but my code is too complicated to be redone on DMStag
>> now after spending a long time using DMDAs,
>> > Is there a way to ensure PETSc distributes several DAs in the same way?
>> besides manually distributing the points,
>> > Thanks,
>> > On Tue, Sep 17, 2019 at 3:28 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Tue, Sep 17, 2019 at 6:15 PM Manuel Valera via petsc-users <
>> > Hello, petsc users,
>> > I have integrated the TS routines in my code, but i just noticed i
>> didn't do it optimally. I was using 3 different TS objects to integrate
>> velocities, temperature and salinity, and it works but only for small DTs.
>> I suspect the intermediate Runge-Kutta states are unphased and this creates
>> the discrepancy for broader time steps, so I need to integrate the 3
>> quantities in the same routine.
>> > I tried to do this by using a 5 DOF distributed array for the RHS,
>> where I store the velocities in the first 3 and then Temperature and
>> Salinity in the rest. The problem is that I use a staggered grid and T,S
>> are located in a different DA layout than the velocities. This is creating
>> problems for me since I can't find a way to communicate the information
>> from the result of the TS integration back to the respective DAs of each
>> variable.
>> > Is there a way to communicate across DAs? or can you suggest an
>> alternative solution to this problem?
>> > If you have a staggered discretization on a structured grid, I would
>> recommend checking out DMStag.
>> > Thanks,
>> > MAtt
>> > Thanks,
>> > What most experimenters take for granted before they begin their
>> experiments lead.
>> > -- Norbert Wiener
>> > https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190924/34dfa0c2/attachment.html>
