[petsc-users] DMPlex cell number containing a point in space
Swarnava Ghosh
swarnava89 at gmail.com
Mon Sep 23 19:45:44 CDT 2019
Hi Matt,
I am trying to get this working. However, It seems that this does not work
for 3D. I have tets as elements, and the dmplex is serial. I get the
following error:
0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: I have only coded this for 2D
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
Is there a work around to this? would you please let me know?
Also here is my code
PetscSF cellSF=NULL;
Vec v;
PetscErrorCode ierr;
// create v;
VecCreate(PETSC_COMM_SELF,&v);
VecSetSizes(v,PETSC_DECIDE,3);
VecSetBlockSize(v,3);
VecSetFromOptions(v);
VecSetValue(v,0,0.0,INSERT_VALUES);
VecSetValue(v,1,0.1,INSERT_VALUES);
VecSetValue(v,2,0.12,INSERT_VALUES);
VecAssemblyBegin(v);
VecAssemblyEnd(v);
PetscInt bs;
VecGetBlockSize(v,&bs);
printf("Block size of v=%d \n",bs);
ierr=DMLocatePoints(pCgdft->dmatom,v,DM_POINTLOCATION_NEAREST,&cellSF);
// print vector
VecView(v,PETSC_VIEWER_STDOUT_SELF);
Sincerely,
SG
On Mon, Sep 16, 2019 at 6:37 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 6, 2019 at 6:07 PM Swarnava Ghosh via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear Petsc developers and users,
>> I have a DMPlex mesh in 3D. Given a point with (x,y,z) coordinates, I am
>> trying the find the cell number in which this point lies, and the vertices
>> of the cell. Is there any DMPlex function that will give me the cell number?
> Sorry, I lost this mail.
> In serial, you can just use DMLocatePoint(). If you have some points and
> you are not
> sure which process they might be located on, then you need a
> DMInterpolation context.
> Thanks,
> Matt
>> Thank you,
>> SG
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190923/8cf85a67/attachment.html>
