[petsc-users] reproduced the problem
Balay, Satish balay at mcs.anl.gov
Fri Sep 20 18:24:08 CDT 2019
As the message says - you need to use configure option --with-cxx-dialect=C++11 with --download-superlu_dist
[this requirement is automated in petsc/master so extra configure option is no longer required]
Satish
On Fri, 20 Sep 2019, Povolotskyi, Mykhailo via petsc-users wrote:
> Hello Satish,
> I did what you suggested, now the error is different:
>      UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Cannot use SuperLU_DIST without enabling C++11, see --with-cxx-dialect=C++11
> The updated configure.log is here:
> https://www.dropbox.com/s/tmkksemu294j719/configure.log?dl=0
> On 9/20/2019 4:32 PM, Balay, Satish wrote:
> > TEST checkRuntimeIssues from config.packages.BlasLapack(/depot/kildisha/apps/brown/nemo5/libs/petsc/build-real3.11/config/BuildSystem/config/packages/BlasLapack.py:579)
> > TESTING: checkRuntimeIssues from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:579)
> >    Determines if BLAS/LAPACK routines use 32 or 64 bit integers
> > Checking if BLAS/LAPACK routines use 32 or 64 bit integersExecuting: mpicc -c -o /tmp/petsc-wf99X2/config.packages.BlasLapack/conftest.o -I/tmp/petsc-wf99X2/config.setCompilers -I/tmp/petsc-wf99X2/config.compilers -I/tmp/petsc-wf99X2/config.utilities.closure -I/tmp/petsc-wf99X2/config.headers -I/tmp/petsc-wf99X2/config.utilities.cacheDetails -I/tmp/petsc-wf99X2/config.atomics -I/tmp/petsc-wf99X2/config.libraries -I/tmp/petsc-wf99X2/config.functions -I/tmp/petsc-wf99X2/config.utilities.featureTestMacros -I/tmp/petsc-wf99X2/config.utilities.missing -I/tmp/petsc-wf99X2/config.types -I/tmp/petsc-wf99X2/config.packages.MPI -I/tmp/petsc-wf99X2/config.packages.valgrind -I/tmp/petsc-wf99X2/config.packages.pthread -I/tmp/petsc-wf99X2/config.packages.metis -I/tmp/petsc-wf99X2/config.packages.hdf5 -I/tmp/petsc-wf99X2/config.packages.BlasLapack -fopenmp -fPIC  /tmp/petsc-wf99X2/config.packages.BlasLapack/conftest.c
> > Successful compile:
> > Source:
> > #include "confdefs.h"
> > #include "conffix.h"
> > #include <sys/types.h>
> > #if STDC_HEADERS
> > #include <stdlib.h>
> > #include <stdio.h>
> > #include <stddef.h>
> > #endif
> > int main() {
> > FILE *output = fopen("runtimetestoutput","w");
> > extern double ddot_(const int*,const double*,const int *,const double*,const int*);
> >                    double x1mkl[4] = {3.0,5.0,7.0,9.0};
> >                    int one1mkl = 1,nmkl = 2;
> >                    double dotresultmkl = 0;
> >                    dotresultmkl = ddot_(&nmkl,x1mkl,&one1mkl,x1mkl,&one1mkl);
> >                    fprintf(output, "-known-64-bit-blas-indices=%d",dotresultmkl != 34);;
> >    return 0;
> > Executing: mpicc  -o /tmp/petsc-wf99X2/config.packages.BlasLapack/conftest   -fopenmp -fPIC /tmp/petsc-wf99X2/config.packages.BlasLapack/conftest.o -L/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_core -lm -lstdc++ -ldl -L/apps/brown/openmpi.20190215/2.1.6_gcc-5.2.0/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -L/apps/cent7/gcc/5.2.0/lib/gcc/x86_64-unknown-linux-gnu/5.2.0 -L/apps/cent7/gcc/5.2.0/lib64 -L/apps/cent7/gcc/5.2.0/lib -Wl,-rpath,/apps/brown/openmpi.20190215/2.1.6_gcc-5.2.0/lib -lgfortran -lm -lgomp -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
> > Testing executable /tmp/petsc-wf99X2/config.packages.BlasLapack/conftest to see if it can be run
> > Executing: /tmp/petsc-wf99X2/config.packages.BlasLapack/conftest
> > ERROR while running executable: Could not execute "['/tmp/petsc-wf99X2/config.packages.BlasLapack/conftest']":
> > /tmp/petsc-wf99X2/config.packages.BlasLapack/conftest: error while loading shared libraries: libmkl_intel_lp64.so: cannot open shared object file: No such file or directory
> >                  Defined "HAVE_64BIT_BLAS_INDICES" to "1"
> > Checking for 64 bit blas indices: program did not return therefor assuming 64 bit blas indices
> >              Defined "HAVE_LIBMKL_INTEL_ILP64" to "1"
> > So this test has an error but yet the flag HAVE_64BIT_BLAS_INDICES is set.
> > Is your compiler not returning correct error codes?
> > Does it make a difference if you also specify -Wl,-rpath along with -L in --with-blaslapack-lib option?
> > Satish
> > On Fri, 20 Sep 2019, Povolotskyi, Mykhailo wrote:
> >> Dear Matthew and Satish,
> >> I just wrote that the error disappeared, but it still exists (I had to
> >> wait longer).
> >> The configuration log can be accessed here:
> >> Sorry for the last e-mail.
> >> Michael.
> >> On 09/20/2019 03:53 PM, Balay, Satish wrote:
> >>> --with-64-bit-indices=1 => PetscInt = int64_t
> >>> --known-64-bit-blas-indices=1 => blas specified uses 64bit indices.
> >>> What is your requirement (use case)?
> >>> Satish
> >>>> Does it mean I have to configure petsc with --with-64-bit-indices=1 ?
> >>>> On 09/20/2019 03:41 PM, Matthew Knepley wrote:
> >>>> On Fri, Sep 20, 2019 at 1:55 PM Povolotskyi, Mykhailo via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> >>>> Hello,
> >>>> I'm upgrading petsc from 3.8 to 3.11.
> >>>> In doing so, I see an error message:
> >>>>     UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> >>>> Cannot use SuperLU_DIST with 64 bit BLAS/Lapack indices
> >>>> I wonder why this configuration step worked well for 3.8?  I did not
> >>>> change anything else but version of petsc.
> >>>> This never worked. We are just checking now.
> >>>>     Thanks,
> >>>>       Matt
> >>>> Thank you,
> >>>> Michael.
> >>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> >>>> -- Norbert Wiener
> >>>> https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/%7Eknepley/>
